Why do we use external pressure to calculate work in gas cylinders?
In a gas-filled cylinder with a piston, the calculation of work done is based on external pressure rather than internal gas pressure. This is because internal pressures fluctuate during processes, except in isobaric conditions, while external pressure remains constant, making it easier to understand the work done by the surroundings on the system. The internal forces within the gas cancel each other out, allowing the piston to move due to the net effect of external pressure. When considering work done by the gas during expansion, the relationship is expressed as dW = pressure x area x distance, leading to the integral work equation Work = ∫ V1 to V2 pdV. For isothermal expansion, this can be further simplified using the ideal gas law, resulting in Work = nRT ln(V2/V1).
sodium.dioxid
In a cylinder (with a piston) containing gas, why do we use the external pressure, instead of the pressure of the gas, to calculate work?
Chemistry news on Phys.org
I think it would be because all the internal forces cancel each other out.
Then why does the piston move up due to internal pressure?
Internal pressure changes in all processes except isobaric. External pressure does not. Also, the work done on the system by the surrounding is easier to understand in terms of external pressure.
And if the original question is on the work done by the system.
That is, the pressure of the gas in the cylinder expanding against the piston.
Then dW = Force x distance = pressure x Area x distance = p dV
And with PV = n RT
Work = nRT ln V2/V1
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
