| Thread Closed |
quantum gravity workshop at perimeter institute |
Share Thread | Thread Tools |
| Nov17-04, 03:58 PM | #18 |
Whoever wants to check connections between the two approaches has, i guess, to look for analogy between these three papers:
Daniele Oriti The Feynman propagator for spin foam quantum gravity http://arxiv.org/abs/gr-qc/0410134 J. Ambjorn, J. Jurkiewicz, R. Loll Emergence of a 4D World from Causal Quantum Gravity http://arxiv.org/hep-th/0404156 Semiclassical Universe from First Principles J. Ambjorn, J. Jurkiewicz, R. Loll 15 pages, 4 figures http://arxiv.org/abs/hep-th/0411152 Abstract: "Causal Dynamical Triangulations in four dimensions provide a background-independent definition of the sum over space-time geometries in nonperturbative quantum gravity. We show that the macroscopic four-dimensional world which emerges in the Euclidean sector of this theory is a bounce which satisfies a semiclassical equation. After integrating out all degrees of freedom except for a global scale factor, we obtain the ground state wave function of the universe as a function of this scale factor." ========= It looks to me like AJL are stabilizing their nomenclature they are calling what they do "causal dynamical triangulations" over the years research in this direction has been called various things: simplicial gravity, simplicial quantum geometry, quantum gravity---sometimes Lorentzian instead of causal---as in "Lorentzian dynamical triangulations". ===== the idea is simple they gamble with the geometry of the universe or more precisely with the whole history of the geometry of the universe ======= imagine you have 200,000 small tetrahedra---little 3sided pyramids---jumbled into a box and there are coils so you can suddenly turn on a magnetic field in the box and make the tets want to stick together so you say "Tets, cohere!" and you throw the switch and they all jump up out of their heap and fit together (triangular side to triangular side, vertex touching vertex) and this gives you a random geometry and as an experiment, you do that over and over again and photograph the result each time-----so eventually you get an idea of the probabilities of various configurations and an idea of average properties etc. ====== they have an idea of causal ordering, so they only allow a certain kind of assembly. so their game is not quite as free as what i described. but it is a game and falls in the category of "Monte Carlo methods" ======= Notice that a 3sided pyramid has FOUR triangular faces because you have to count the bottom too. so it is called a Tet (to indicate the four-ness) A triangle is what you use to triangulate a 2D surface A tetrahedron is what you use to triangulate a 3D region What is it called that you use to triangulate a 4D spacetime what is the analog of a tetrahedron in 4D? It could be called a "pent" because it has FIVE faces (each of which is a tetrahedron) and pent indicates five-ness. Technically it is called a 4-simplex. and a 4-simplex has 5 faces, each of which is a 3D solid, namely a tetrahedron. So if you want to play the AJL game in 4D then you have to have a heap of "pents" in a box. you have to have a heap of 4-simplexes. A computer finds it very easy to imagine a 4-simplex. But I do not. therefore I imagine them as little tetrahedra----a bit like hard cream-colored plastic dice. AJL use large numbers of them: 100 thousand or 200 thousand, the most this time seems to have been 360 thousand When you say "Pents! Cohere!" they all jump together and form a random 4D shape. Then the computer can project that for you into lower dimension so you can have the experience of viewing it. Or it can calculate statistics of certain measures and features, and keep a record. then you do it over and over again and get an idea of the probabilities. ======= and AJL have some extra rules in how they can fit together having to do with causality. ======= So the question is HOW CLOSE IS Oriti spin foam model to this AJL Causal Dynamations "pent" random geometry game? Can you get similar results? AJL report a kind of Epiphany when a semiclassical Lagrangian for the scalefactor of the universe appeared to them out of the midst of Monte Carlo randomness. they didnt put it in. A familiar Lagrangian came to dinner uninvited. This is quite interesting. I didnt yet hear of anything like this happening with Spin Foam. So it seems like an urgent question to put to Daniele Oriti. Can he assimilate or link to anything in the AJL program? |
| Nov22-04, 10:18 PM | #19 |
| Dec8-04, 07:33 PM | #20 |
today there were two that appeared. by Daniele Oriti and by V.Husain and O.Winkler. In both cases the titles of the papers are virtually identical to those of the talks given at the Halloween conference at perimeter 1. http://arxiv.org/gr-qc/0412035 The Feynman propagator for quantum gravity: spin foams, proper time, orientation, causality and timeless-ordering Daniele Oriti 8 pages; to appear in the Proceedings of the DICE 2004 Workshop "From Decoherence and Emergent Classicality to Emergent Quantum Mechanics" "We discuss the notion of causality in Quantum Gravity in the context of sum-over-histories approaches, in the absence therefore of any background time parameter. In the spin foam formulation of Quantum Gravity, we identify the appropriate causal structure in the orientation of the spin foam 2-complex and the data that characterize it; we construct a generalised version of spin foam models introducing an extra variable with the interpretation of proper time and show that different ranges of integration for this proper time give two separate classes of spin foam models: one corresponds to the spin foam models currently studied, that are independent of the underlying orientation/causal structure and are therefore interpreted as a-causal transition amplitudes; the second corresponds to a general definition of causal or orientation dependent spin foam models, interpreted as causal transition amplitudes or as the Quantum Gravity analogue of the Feynman propagator of field theory, implying a notion of ''timeless ordering''." * 2. http://arxiv.org/gr-qc/0412039 Quantum black holes Viqar Husain, Oliver Winkler 4 pages "Using a recently developed quantization of spherically symmetric gravity coupled to a scalar field, we give a construction of horizon operators that allow a definition of general, fully dynamical quantum black holes. These operators capture the intuitive idea that classical black holes are defined by the presence of trapped surfaces, that is surfaces from which light cannot escape outward. They thus provide a mechanism for classifying quantum states of the system into those that describe quantum black holes and those that do not. We find that quantum horizons fluctuate, confirming long-held heuristic expectations. We also give explicit examples of quantum black hole states. The stage is thus set for addressing all the puzzles of black hole physics in a fully quantized dynamical setting." * |
| Thread Closed |
| Thread Tools | |
Similar Threads for: quantum gravity workshop at perimeter institute
| Thread | Forum | Replies | ||
| Them old quantum gravity, topological quantum field thereah blues | Beyond the Standard Model | 1 | ||
| Perimeter Institute Streaming Seminars | General Physics | 0 | ||
| Vacuum Selection-quantum hydrodynamics vs quantum gravity | Quantum Physics | 0 | ||
| Quantum Information Theory Workshop | General Physics | 0 | ||
| Workshop on Weinberg's Theory of Quantum Fields | General Physics | 11 | ||
