Error propagation with two functions, two unknowns.
The discussion centers on error propagation involving two independent variables, x and y, and two measurements, m1 and m2, each with associated errors. The user faces challenges in deriving x and y from complicated functions f and g, which do not yield simple solutions. They seek methods to calculate the errors for x and y when using numerical solutions instead. A suggestion is made to evaluate the derivatives of f and g at the measured values, allowing the user to express the errors in terms of these derivatives and subsequently solve for δx and δy. The importance of checking second-order terms to ensure accuracy in the error calculations is also highlighted.
Hepth
If I have two independent variables x,y, and two measurements, m1, m2 with errors. And the dependence is thus:
<br /> m_1 \pm \delta m_1 = f[x,y]<br />
<br /> m_2 \pm \delta m_2 = g[x,y]<br />
Now in my case, f and g are complicated expressions of x and y with no simple solution. (Actually I think i can solve one for x, but not for y).
Now if the equations were easy, I could solve for x and y:
<br /> x \pm \delta_x = F[m_1, m_2,...]<br />
<br /> y \pm \delta_y = G[m_1, m_2,...]<br />
And from there add the errors in quadrature to get the x and y errors.
BUT if I can't solve for x and y independently, and I must use numerical solutions to get the results ( I can, its easy). How can I go about getting the ERRORS? Is there another way I can solve for the errors and numerically solve for them, or a different method?
I have Mathematica if that helps.
You should explain what you mean by "error". Are you doing numerical approximations that involve an error in that sense? Are you doing a stochastic simulation where randomness causes an "error"? Or are you teking physical measurements with equipment that has a specified precision?
Not sure if I've understood completely, but see if this helps.
Are f, g differentiable? Can you evaluate the derivatives at (m1, m2)? If so, can write \delta m_1 = \delta f = f_x \delta x + f_y \delta y; \delta m_2 = \delta g = g_x \delta x + g_y \delta y
Evaluating fx etc. at (m1, m2), solve to find δx, δy.
Will need to check that the second order terms are not important.
