Can complex numbers solve x^x = i and what is (-1)^{\sqrt{2}}?
A complex number x exists such that x^x = i, but finding it requires the Lambert W function for a solution. The expression (-1)^{\sqrt{2}} can be evaluated using polar form, resulting in e^{i\pi\sqrt{2}}, which simplifies to approximately 0.99 + 0.077i. The discussion highlights the complexity of solving these equations, particularly the need for advanced mathematical functions. For the equation x^x = i, specific values of θ yield solutions in defined intervals. Overall, both problems illustrate the intricate nature of complex number calculations.
limitkiller
1- is there any complex number, x ,such that x^x=i?
2- (-1)^(\sqrt{2})=?
Mathematics news on Phys.org
Yes, but finding it is non-trivial, involving, I think, the Lambert W function.
We can write -1 in "polar form" as e^{i\pi} and then (-1)^{\sqrt{2}}= (e^{i\pi})^{\sqrt{2}}= e^{i\pi\sqrt{2}}= cos(\pi\sqrt{2})+ i sin(\pi\sqrt{2})
or about .99+ .077i.
Thanks.
Writing z = re, zz = i gives θ sec(θ) eθ tan(θ) = π/2 + 2πn and r = eθ tan(θ). For n = 0, θ has a solution in (π/6, π/4), and probably infinitely many for each n.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
10K
