How long will it take for the Earth to become tidally locked to the Moon?
The Earth is expected to eventually become tidally locked to the Moon, similar to how the Moon is currently locked to the Earth. Tidal braking is currently slowing Earth's rotation by about a millisecond per century, but this process will take an impractically long time, potentially outlasting the Sun's lifespan. The assumption of constant tidal braking is flawed, as the Moon is receding from Earth, reducing the braking effect over time. Additionally, Earth's oceans are predicted to evaporate in a few billion years, further diminishing tidal braking. Consequently, the process of tidal locking is effectively projected to take nearly eternity.
mofobro
According to an article I read,
http://www.badastronomy.com/bad/misc/tides.html
the Earth will one day become tidally locked to the moon the way the moon is locked to the Earth today, so that the same face of the Earth always faces the moon.
If this is true, how long will that process take?
Astronomy news on Phys.org
Tidal braking is slowing the Earth's rotation by about a millisecond per century. Assuming that was to remain constant, it would take so long for Earth to become tidally locked with the moon, our sun would have long since become a white dwarf. We do, however, know the assumption of constant braking is invalid. Tidal braking also causes the moon to receed from Earth which will diminish the braking effect over time. We also know that Earth will lose its oceans within a few billion years, which will eliminate the source of most tidal braking. In short, the answer effectively becomes nearly eternity.
A slightly better rule-of-thumb is that the Earth loses a third of its rotational energy per billion years. Over 5 billion years, that yields a factor of (2/3)^5 ~ 32/243 ~ 1/7.5 and hence a factor of between 2.5 and 3 for the rotational period (inverse square dependence on energy). So, if things were to continue going smoothly, the day would be some 60 hours long by the end. However, as Chronos said, the oceans are expected to evaporate long before that, which will make further braking far less effective.
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
