What Is the Point of Finding the Relative Error in a Vector?
The discussion centers on the concept of relative error in vectors, specifically questioning its utility when individual entry errors may exceed the overall vector error threshold. It highlights that while the maximum norm can provide a general relative error for a vector, it fails to account for discrepancies in individual components. An example illustrates that even if the overall relative error is acceptable, some entries may still exceed the defined error margin. The conversation also touches on the implications of relative error for solutions to linear systems, emphasizing the limitations of bounding individual entry errors based on vector-level assessments. Ultimately, the inquiry seeks clarity on the practical significance of calculating relative error in vectors when it does not guarantee accuracy for each component.
andresc889
Hi all,
I have a general question about relative error. Suppose that we have a vector of measurements \hat{b}=\left(\hat{b_{1}},\hat{b_{2}},...,\hat{b_{n}}\right). Furthermore, suppose that these measurements are accurate to 10%.
My natural interpretation of this statement is that there is a "true" vector b=\left(b_{1},b_{2},...,b_{n}\right) such that \frac{\left|b_{1}-\hat{b_{1}}\right|}{\left|b_{1}\right|}, \frac{\left|b_{2}-\hat{b_{2}}\right|}{\left|b_{2}\right|}, ..., \frac{\left|b_{n}-\hat{b_{n}}\right|}{\left|b_{n}\right|}≤0.1.
I have seen in the literature that we can use the maximum norm of a vector to define the relative error. So, the relative error in \hat{b} could be defined as \frac{\left\|b-\hat{b}\right\|}{\left\|b\right\|} where \left\|v\right\|=\max\limits_{i} \left|v_i\right|.
The problem that I find with this is the fact that we can't conclude anything about the individual entries from this definition. For example, if b=\left(1,2,3\right) and \hat{b}=\left(1.14,1.9,3.15\right), then \frac{\left\|b-\hat{b}\right\|}{\left\|b\right\|}=\frac{0.15}{3}=0.05≤0.1 which indicates that the relative error in \hat{b} is less than 10%. On the other hand, the relative error in the first entry of \hat{b} is \frac{0.14}{1}=0.14≥0.1.
Now, suppose we solve the systems A\hat{x}=\hat{b} and Ax=b where A is invertible. According to the literature,
\frac{\left\|\hat{x}-x\right\|}{\left\|x\right\|}≤\left\|A^{-1}\right\|\left\|A\right\|\frac{\left\|\hat{b}-b\right\|}{\left\|b\right\|}
Where the norm of a matrix A is defined to be \max\limits_{i} \sum\limits_{j} \left|a_{ij}\right|.
If we know that the relative error in \hat{b} is less than 10%, then we can put a bound on the relative error in \hat{x}:
\frac{\left\|\hat{x}-x\right\|}{\left\|x\right\|}≤0.1\left\|A^{-1}\right\|\left\|A\right\|
But as shown above, this does not put a bound on the relative error in the individual entries of \hat{x}. So my question is, what is the point of finding the relative error in the vector if we cannot use that to put a bound on the relative error of the individual entries? Maybe I'm misinterpreting something here?
Thanks!
Mathematics news on Phys.org
For your example, with ##b = <1, 2, 3>## and ##\hat b = <1.14, 1.9, 3.15>## a vector of the absolute values of the relative errors would be ##<\frac {.14} 1, \frac {.1}2, \frac {.15} 3> = < .14, .05, .05>##. The mean of these values is .24/3 = .08 which is less than .1.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
