What is the relationship between nucleus deformation and fission requirements?
  • Thread starter Thread starter mitch_1211
    Fission
mitch_1211
So I think, as a rule of thumb that for fission to be possible \frac{Z^2}{A}\geq47
I want to be able to derive this relationship though..
If a nucleus deforms into an ellipsoid, its surface area can be described by
4\piR2(1+\frac{2}{5}\epsilon^2 + ...) call this X
And its Coulomb energy can be described as
\frac{3Z^2}{20\pi\epsilon_0R}(1-\frac{1}{5}\epsilon^2 + ...) call this Y
And so ΔBE = X-Y
For fission to occur set ΔBE ≤ 0
Once I've done all this I'm not sure how to get ΔBE in terms of A and Z only. I know R = r0A1/3
thanks
I should mention that \epsilon is an arbitrary deformation parameter associated with the ellipsoid and can be factored out
You can use that formula for R and solve for ##\frac{\partial (X-Y)}{\partial \epsilon}=0##.
I would expect that this overestimates the required Z^2/A - if that derivative is negative, the nucleus should not form at all or decay within less than a femtosecond.
