Notions of simultaneity in strongly curved spacetime
  • Context: Graduate
  • Thread starter Thread starter PAllen
    Simultaneity Spacetime
The discussion revolves around the concept of simultaneity in strongly curved spacetime, particularly in the context of general relativity (GR). Participants explore various notions of simultaneity, their implications in different spacetime geometries, and the challenges posed by high densities of matter and field. The conversation includes theoretical considerations and interpretations of GR, as well as questions about the validity of the theory under extreme conditions.
  • Some participants propose that simultaneity is undefinable in a preferred way in general relativity and is not observable or measurable.
  • One participant suggests a classification of simultaneity notions based on causal past and future, introducing terms like past inclusive, future inclusive, and causal inclusive simultaneity.
  • Another participant questions the extent to which simultaneity can be analyzed in strongly curved spacetime, referencing Einstein's views on the limitations of GR in extreme conditions.
  • Concerns are raised about the significance of field equations and variables in regions of high density, with some arguing that GR remains valid for black holes of sufficient mass.
  • Participants express uncertainty about what constitutes 'large' densities of matter and field, discussing the implications for stellar mass black holes versus supermassive black holes.
  • There is a suggestion that any quantum theory of gravity must reconcile with the predictions of GR regarding event horizons and black holes.
Participants do not reach a consensus on the definitions and implications of simultaneity in curved spacetime. Multiple competing views remain regarding the validity of GR under extreme conditions and the interpretation of density thresholds.
Limitations include the dependence on definitions of simultaneity, unresolved questions about the nature of high-density regions, and the challenge of reconciling classical GR with quantum theories.
  • #31
PAllen said:
OK, if you assume a transparent pressure less dust, and do this radially from infinity, you get this SC time slicing outside and something similar inside. The whole point of this thread is that neither SR nor GR say this is the only allowed way to slice spacetime. And it is provable that you have hole in spacetime (world lines of particles that just end for no reason, at finite proper time along them), or a region not covered by these coordinates.
There is no hole in spacetime with SC type time slicing for collapsing mass. EH forms at infinite future i.e. never. So there is no hole in spacetime.
And wordlines of particles do not end. They just extend toward infinite future.
You would not claim that there is some problem with this expression, right?
[tex]\lim_{t\to\infty}f(t)=a[/tex]
Let's say that t is coordinate time and f(t) is proper time of infalling particle.
PAllen said:
The point of this thread, is that you can choose many other intuitive simultaneity conventions for a distant observe (and simultaneity convention identically equals time sicing), which don't have a hole, and assign finite time coordinates to events inside the EH, which itself labeled with a finite time coordinate.
You can choose different simultaneity conventions but then we need good understanding of the things that depend on simultaneity convention as they would change along with it.
And I think that in order to improve that understanding it would be good idea to start with some examples from flat spacetime.
  • #32
I thought it would be useful to do something Peter Donis suggested in another thread. That is, to look classically at the complete geometry of a collapsing shell of matter, which is like the Krauss case. I found a couple of references, and have done some order of magnitude calculations based on the arxiv paper (adjusted for a matter shell rather than a null dust shell).
The follwoing gives a Kruskal diagram (and other coordinates) for a collapsing shell. This one is pressure-less, and only the final stages (where the matter is almost light like) is shown (the r=0 line and the shell line need to slanted closer to vertical to consider a collapse from rest not too far from the SC radius):
http://casa.colorado.edu/~ajsh/collapse.html
This paper discusses collapse of a null dust shell, including Kruskal coordinates (section 4):
http://arxiv.org/abs/gr-qc/0502040
While this is not quite the case of interest, the techniques shown for matching interior and exterior are general.
I think the interesting case to consider is a clock sitting inertially at the center of a collapsing shell, under the further assumption that the shell is transparent. There are a number of interesting features:
- The spacetime inside the shell is pure Minkowski flat spacetime; there are no tidal forces at all. There is no matter density at all. In the whole region inside the shell, SR physics applies. The analog of this is obviously true for Newtonian physics; it is also well known that this is exactly true for GR as well (that inside a spherical shell, physics is indistinguishable from SR with no gravity).
- The clock inside operates according to SR physics, time locally flowing normally, until shell collapse reaches singularity. The clock at the center cannot detect the shell passing the event horizon. Nothing about physics within the shell changes on approach to or passing the event horizion - the interior is pure SR until the singularity.
- The clock at the center sees the external 'universe' proceeding normally except highly (but finitely) blue shifted until the moment of singularity. Here, the clock world line ends for a very physical reason: the shell has collapsed to a singularity, bringing the clock with it. One of the things I wanted to get right here was the blueshift relation. Unlike an O-S collapse, where an infaller (with right trajectory) can have very mild or even no blue shift relative to the outside universe, the boundary matching conditions for a shell collapse require that the whole interior (for observers stationary with respect to shell center) experiences (in the limit of zero thickness shell) the same blueshift as a clock riding exactly on the shell.
- A distant observer, of course, never sees the shell reach the event horizon. Similarly, they see the inside clock stop at a time before the clock hits the singularity.
- Later free fall clocks will be seen, from a distance, to stop on reaching the event horizon. Such a clock, itself, will experience no such thing, and its time will progress further until it hits the singularity (the shell is 'long gone' into the singularity).
Classically, one may ask by what possible rationale should one declare that a clock operating according to pure SR physics, be declared to stop for no local physical reason? What does what a distant observer sees have anything to do with their local, pure SR physics?
All of the above is indisputable for classical GR. The Krauss paper, by choice, only covered what the outside observer sees, for the classical case, because of what they discovered about the quantum case. The quantum analysis (if true) showed that, a lot of the above does not happen in our universe. It shows, instead, that (no matter what coordinates are used), the interior clock actually evaporates into not quite thermal radiation well before its classical end. The Kruskal diagram changes in significant ways as a result. Only with this justification, does it make any sense to 'chop' the classical analysis based on Schwarzschild time coordinate.
Note, that in the classical analysis without the quantum chop, perfectly reasonable, physically based simultaneity conventions, establish simultaneity between the interior clock and exterior clocks well after the shell has crossed the event horizon. One simple example is:
https://www.physicsforums.com/showpost.php?p=4165220&postcount=23
  • #33
You think that this is a logical proof, but it isn't. What you have actually proven is only that there is no hole in the region of spacetime covered by the SC type time slicing. You have *not* proven that that region of spacetime is the entire spacetime, and in fact it's easy to prove that it's not. See below.
No, they don't, at least not the way you mean. When you have extended an infalling worldline all the way to t = infinity by your clock, that worldline still only has a *finite* length. "Length" for worldlines means proper time, and the proper time for an object to fall to the horizon is finite.
This isn't quite the right expression. The right expression is:
[tex]\lim_{t\to\infty} \int_{t_0}^t dt' f(t')[/tex]
where [itex]t_0[/itex] is the time by the distant observer's clock that the infalling object starts falling. Substitute the correct function f(t'), for the proper time of the infalling object, do the integral, and take the limit. You will find that it gives a finite answer. This shows that "extending the worldline to infinity" by the distant observer's clock only extends it by a finite length. The SC time coordinate is so distorted at the horizon that it makes finite lengths look like infinite lengths.
This also shows why the region of spacetime covered by the SC time slicing can't be the entire spacetime: what happens to the worldlines once they reach the horizon? They have only covered a finite length, and spacetime is perfectly smooth and well-behaved at the horizon: the curvature is finite, there is nothing there that would stop the objects from going further. The only physically reasonable conclusion is that they *do* go further; that is, that there is a region of spacetime on the other side of the horizon, where the infalling objects go, but which can't be covered by the SC time slicing.
This is a good idea; do you have any suggestions? I would suggest comparing the description of flat spacetime in Rindler coordinates to its description in Minkowski coordinates.
  • #34
This is false. You detect readily in SC coorinates that there is a hole in space time. You integrate proper time along an infall trajectory and find that proper time stops at a finite value (unlike for various other world lines). You ask, what stops the clock? There is no local physics to stop the clock - tidal gravity may be very small; curvature tensor components are finite. The infinite coordinate time is not a physical quantity in GR. Einstein spoke of rulers and clocks, as Harrylin likes to point out. This clock stops for no conceivable local reason. If you add SC interior coordinates, and use limiting calculations, you smoothly extend this world line to the real singularity (with infinite curvature). All of this is exactly as if you chopped a disk around the pole from a sphere - you would find geodesics ending for no reason.
There is no physical observable, anywhere in SR or GR, that depends on simultaneity convention at all. This is part of what Pervect was saying above. Belief that simultaneity convention has physical consequence reflects complete, total, misunderstanding of SR and GR.
As for flat spacetime, the Rindler example Dr. Greg has posted beautiful pictures of, is relevant. The belief that there is no hole in SC exterior coordinates is 100% equivalent to the belief that most of the universe doesn't exist because a uniformly accelerating rocket can't see it.
  • #35
pervect said:
Mathematically: the maps of SR and GR preserve the Lorentz interval.
This is where I keep feeling the communication is lacking - but many people who say they "get" this point obviously don't :-(.
I would like get this point better and as I understand you are confident about your understanding of that point.
Transformations between inertial SR coordinates preserve Lorentz interval. And they don't change metric just as well.
But in GR transformations between coordinates don't have to preserve metric intact. That's how Lorentz interval is left the same, right?
  • #36
No. GR coordinate transformations leave the metric intact; at least, they do in the normal meaning of that term, that geometric invariants are preserved. The metric may *look* different, as a formula, in a different coordinate chart; for example, the metric of the exterior vacuum region of Schwarzschild spacetime looks different in Painleve coordinates than it does in Schwarzschild coordinates. But if you calculate any geometric invariant, such as the length of a curve, in different coordinate charts, you will get the same answer.
  • #37
If you have two events in space-time, everyone who can see both events agrees on the Lorentz interval between them. So you don't really need to focus overmuch on the coordinates, the Lorentz interval doesn't depend on your coordinate choices.
In Newtonian physics you used to be able to say that about distance. For instance, if you were doing plain plane geometry, you might not use coordinates at all, but Euclid's axioms - though you could use analytic geometry as a fill-in.
In relativistic physics distance is no longer an invariant, but the Lorentz interval is.
Distance is a geometric invariant of Newtonian physics the Lorentz interval is a geometric invariant of special and general relativity.
As far as the metric tensor goes, in some abstract sense it's always the same geometrical object, but the components in any given coordinate system do change as you change the coordinates.
  • #38
PeterDonis said:
I honestly haven't seen this in what I've seen of the reputable physics community (which is not a lot as I am not an academic). There is certainly a lot of disagreement, but it doesn't look to me like disagreement about which coordinate systems are valid. It looks to me like disagreement on which physical principles should be retained, and which discarded, when they conflict. [...]
By mere chance the first paper on this topic that I read (which was very recently), was Vachaspati's paper in Physical Review D. He first summarizes the standard solution based on Schwartzschild's "map". Just as Oppenheimer who found that "it is impossible for a singularity to develop in a finite time", also Vachapati concludes that "it takes an infinite time for objects to fall into a pre-existing black hole as viewed by an asymptotic observer".
This looks so easy to verify that I also did this today on a piece of paper with a pocket calculator.
However, Hamilton claims - based on other maps - that it is possible for a singularity to develop. Maybe he believes in multiple universes? :eek: The contradiction is shouting at me, but I have only read a few papers and seen a few web sites, so I don't know how other people interpret this - except for Einstein, who regarded it as a problem that cannot occur, and Vachaspati who argues the same on other grounds.
If I understand it correctly and calculated it correctly, then this is like my Earth map illustration, which I also imagined for this purpose. I will thus elaborate on that, because I continue to see an unsolved issue repeated again and again and I want to get to the bottom of it.
The first Earth cartographer - let's call him Schwarzy - makes a map according to which nobody can get North of the North pole. Schwarzy would agree that you cannot literally see someone walk North of the North pole; however that completely misses the point. According to Schwarzy's map it can never happen.
Then comes along a second cartographer - let's call him CalCross - who makes a map based on Mercator that eliminates that impossibility, so that on his map that "unphysical" limit is removed and people can walk on beyond the North Pole. According to his map the events that cannot happen following Schwarzy, happen smoothly, without any problem.
In my world (but perhaps not yours), those maps contradict each other. I have no doubt that Schwarzy's map is perfectly conform Flatland's Earth Science, and Mercator's map is just a conformal copy of the same; but I wonder about CalCross's map, which is some kind of an extension of the last. And that brings me to the logical request:
The follwoing gives a Kruskal diagram (and other coordinates) for a collapsing shell. [..] [/url]
I think that there is no doubt that Schwarzschild etc (incl. Einstein, O-S and Vachaspati) used a valid GR model. However I don't know at all the physics behind a Kruskal diagram. And these models look to me just as contradictory - and roughly in the same way - as the Earth maps in my example.
Please clarify what reference system the Kruskal diagram portrays. Also, I wonder if it is a valid reference system according to Einstein's GR, or only according to the mathematical equations that are used in Einstein's GR; or if it is in fact no reference system at all, but more a kind of transformation map. In the last case, the same questions would need to be asked for every point on that map.
  • #39
Look carefully at his statement: "as viewed by and asymptotic observer". This wording is not accidental. An asymptotic observer is one who is 'infinitely far' from the BH. SC type time coordinate represents proper time only for this observer (that is, times they assign to events along a world line at asymptotic infinity). For any other observer, to get clock time, you integrate along some trajectory. For free faller, using these coordinate or any other, you would find finite clock time to reach the event horizon. If you fill in the space time hole in these coordinates (e.g. using SC interior type coordinates) you can continue the infall world line to the singularity in finite additional time as well.
Classically, there is no contradiction. What you have is the analog of the situation I described of removing a disk from the pole of a 2-sphere. You have a coordinate chart that only covers the 2-sphere minus the disk, versus other charts the cover the whole sphere. They agree on the parts they both cover. The incomplete chart simply cannot make predictions about the region it doesn't cover.
Krauss, et. al. then provide a reason to consider the missing region of spacetime irrelevant - that quantum mechanics says bodies on the incomplete world lines actually end by evaporation before reaching the event where the incomplete chart chops them.
Einstein's argument (from a valid calculation) is considered invalid. No one, on any side BH related debates uses it any more. The calculation showed matter particles would have to go the speed of light before reaching SC radius to maintain stability. The correct conclusion is that then matter can't be stable inside a critical radius; if the particles cannot exceed local c, they must proceed with collapse. Einstein argued that 'something' must stop this state from occurring. He provided no basis for this something. You may say he simply believed something must stop this from happening. Krauss et.al. effectively provide a basis for this.
But there are no contridictions between maps. Classically, you just have different coverage by different maps.
No, it is not like your case. It is like a map that covers the whole sphere versus a map that is missing a disk.
This is where you are misunderstanding things. The correct analogy here is that this map does not include a little disk around the north pole. It agrees with complete maps on the distance to this disk boundary (finite proper time for infallers, computed same for SC coordinates as all others). However, the disk is simply not covered by this map. This map assigns an infinite value of some coordinate to lines approaching the disk; however, computing distance along these lines (proper time for infallers), it agrees with any other map that the distance to the disk boundary is finite.
This is because one map has a hole that the other one fills.
All the maps agrees on every computation of an observable, for the events they have in common. One map is incomplete. Others are complete (include more of space time - world lines don't end for no reason, on a topological hole).
The unique contribution of Krauss et.al. is to provide a proposed physical reason to prefer the incomplete map: that the incomplete map already 'covers' too much. The real world, with quantum effects, diverges from classical near the edges of the incomplete map, so that even the very edge of the incomplete map becomes irrelevant. (Of course this is conditional on their debated quantum analysis).
I believe I have covered this above. Kruskal, GP, Lemaitre, etc. are simply maps that cover more events. Every computed measurement in them agrees with SC for the events included in both. SC assigns infinite coordinate values at a boundary of its coverage, the others do not, but all measurements right up to this edge agree in all coordinates (that infaller's clocks pass finite time reaching the edge; that distant observers never see/detect anything reaching the edge = EH).
I cannot respond to what you call Einstein's GR versus other GR. Only you know what you mean by this. There is one GR. Over the course of his life, Einstein changed his mind several times over which predictions of it are physically plausible, but this isn't different theories but beliefs about applicability of predictions to the real world. For example, the theory has a cosmological constant that may or may not be zero. First Einstein thought a value of zero was implausible; then he decided it was physically preferred; now it appears small positive value is most plausible. Einstein first accepted, then rejected, then accepted the prediction of gravitational waves by GR. Einstein's position on black holes amounted to the belief that they weren't physically plausible. However, classically, there is no way to remove them as predictions without something as artificial as: events not seen by a chosen class of observer do not exist.
Almost nobody believes the classical description of BH appllies to our universe. There is much disagreement about what occurs instead.
There are a wide range of GR predictions that people differ on the likelihood of their corresponding to our universe: white holes, closed time like curves, naked singularities, alcubierre drive, etc. There are varying strong reasons for doubting them.
  • #40
I'm not sure this is the only physically reasonable conclusion. The BH in question would have to exist for an eternity from the distant observer's perspective before the objects would cross the EH, yet current theory suggests that BHs would evaporate in finite time from that same distant observer's perspective. (Without examining how that EH came to exist in the first place!) this would suggest to me that infalling objects are destroyed and emitted as Hawking Radiation before they cross the EH.
  • #41
The "time" you refer to is time according to a distant observer, i.e., an observer who is spatially separated from the infalling matter. Did you also calculate the proper time experienced by an observer who is *not* spatially separated from the infalling matter? That is, an observer who is falling in along with it? O-S show that that proper time is finite. Have you really stopped to think about what that means?
No, he is just recognizing that the proper time for an infalling observer to reach the horizon is finite, and realizing what that means. All the proofs you refer to, which say that "it is impossible for a singularity to form in a finite time", are proofs that a singularity cannot form *in the region of spacetime where the distant observer's time coordinate is finite*. They are *not* proofs that that region of spacetime is the only region of spacetime that exists. In fact, it is easy to show that there *must* be another region of spacetime, below the horizon, that is not covered by the distant observer's time coordinate. That must be true *because* the proper time for an infalling observer to reach the horizon is finite. Have you considered this at all?
Have you not been reading all the posts I and others have made explaining "how other people interpret this"? Please, before you keep bringing this up, take some time to seriously consider what I said above, and what I'm going to say below.
This is actually a good analogy, but not for quite the reason you think. (I'll give my version of the analogy below.) A Mercator projection doesn't actually include the North Pole; it maps the finite distance from the equator to the North Pole, on the actual globe, to an *infinite* vertical distance on the flat map. Actual maps using the Mercator projection, on finite-sized sheets of paper, don't reach all the way to the North Pole; they are cut off at some latitude short of 90 degrees North. So in your analogy, CalCross's map does *not* show that you can walk North of the North Pole; instead, it shows (or appears to show) that it would take an infinite time to reach the North Pole, because the distance to it looks infinite.
So let's try a different version of the analogy. Schwartz and CalCross both live on the equator right where it crosses the prime meridian. CalCross makes a map, using the Mercator projection, and claims, based on that map, that the distance to the North Pole is infinite, so nobody can ever reach the North Pole; it would take an infinite amount of time. Therefore, CalCross claims, there is nothing beyond the North Pole, since any such place would have to be "further away than infinity".
Schwartz, however, has a mathematical model based on the Earth being a sphere (he can't draw his model undistorted on a flat map, but he can work with it mathematically), which says that the distance to the North Pole is finite, and that if you walk there and then continue walking, the Earth's surface continues on just fine. Explorers are sent north along the prime meridian; which of the two (CalCross and Schwartz) will be proved right, and which will be proved wrong?
Obviously this case is not exactly like the case of Schwarzschild spacetime, because the North Pole is not a "horizon"; the explorers can turn around and come back, bringing their data with them. But CalCross's coordinates, in which the distance to the North Pole looks infinite, even though it really isn't, are very much like Schwarzschild coordinates, in which the "distance" (which in this case is time, since we are looking in a timelike direction) to the horizon looks infinite, even though it really isn't.
Yes, they did. Their model is valid in the same way that CalCross's map of the Earth is valid; you can use CalCross's map to calculate the length of any curve on the Earth's surface you like, as long as the curve doesn't include one of the poles. Similarly, you can use the standard SC exterior coordinates to calculate the length (proper time) of any worldline in Schwarzschild spacetime you like, as long as the worldline doesn't cross the horizon. Both maps are correct within their limited scope, but they are limited in scope.
The Kruskal diagram is probably not the best place to begin if you are trying to understand how GR models a black hole spacetime. I would start with either ingoing Painleve coordinates or ingoing Eddington-Finkelstein coordinates instead. That said, I'll make some comments about the Kruskal diagram below.
What do you mean by "reference system"? It is true that there is no observer whose worldline is the "time" axis (i.e., vertical axis) of the Kruskal diagram; but there's no requirement in GR that that be true for a valid coordinate chart. (Strictly speaking, it's not a requirement even in SR; you can describe flat spacetime in some wacky coordinate chart whose "time axis" isn't the worldline of any observer.) The Kruskal chart is a coordinate chart; it's a mapping of points (events) in spacetime to 4-tuples of real numbers [itex]( V, U, \theta, \phi )[/itex], such that the metric on the spacetime can be written in this form:
[tex]ds^2 = \frac{32 M^2}{r} e^{-r / 2M} \left( - dV^2 + dU^2 \right) + r^2 \left( d \theta^2 + sin^2 \theta d \phi^2 \right)[/tex]
Here V is the "time" coordinate (vertical axis) and U is the "radial" coordinate (horizontal axis) in the Kruskal diagram. (Note that I've used units in which G = c = 1.) The "r" that appears in this line element is not a separate coordinate in this chart; it is a function of U and V, which is used for convenience to make the line element look simpler and to make clear the correspondence with the Schwarzschild chart. An example of the diagram is here:
http://en.wikipedia.org/wiki/Kruskal–Szekeres_coordinates
Note that this diagram is for the "maximally extended" Schwarzschild spacetime, which is not physically realistic. If we drew a similar diagram of the spacetime of the O-S model (the modern version which completes the O-S analysis by carrying it beyond the point where the horizon forms), it would include a portion of regions I and II in the diagram on the Wikipedia page, plus a non-vacuum region containing the collapsing matter. DrGreg posted such a diagram in the thread on the O-S model here:
https://www.physicsforums.com/showpost.php?p=4164435&postcount=64
(I know you've already seen this, but I want to be clear about exactly which diagrams I'm referring to.)
A key fact about the Kruskal diagram that makes it so useful is that the worldlines of radial light rays are 45 degree lines, just as they are in a standard Minkowski diagram in flat spacetime. (You should be able to see this from looking at the line element above; if you can't, please ask. Being able to "read off" such things from a line element is a very useful skill.) That makes it easy to look at the Kruskal diagram and see the causal structure of the spacetime--which events can send light signals to which other events.
The other useful thing about the Kruskal diagram is that it let's you see how standard SC coordinates are distorted. Look at the dotted lines through the origin of the diagram, fanning out into region I; these are lines of constant Schwarzschild time t. See how they all intersect at the origin? That's why SC coordinates become singular at the horizon, which on this diagram is represented by the 45 degree line U = V (i.e., the one going up and to the right), and which therefore includes the origin. What look to the distant observer like "parallel" lines of constant time are actually *converging* lines. And what looks to the distant observer like an infinite "length" (i.e., time) to the horizon is actually a finite length (this can be easily calculated in the Kruskal chart, just take any timelike curve that intersects the horizon and integrate the above line element--the easiest curve is one with U = constant, so the only nonzero differential is dV).
As far as whether the Kruskal chart is "valid", of course it is. You can find a correspondence between it and the SC chart (or any other chart) in the same way you can find a correspondence between the standard latitude/longitude "chart" on the Earth's surface and a Mercator chart. But if one chart only represents a portion of the spacetime (as the SC exterior chart does), then there will only be a correspondence with other charts on that portion of the spacetime.
But how do we know that the other portions of spacetime shown on the Kruskal chart "really exist"? Because the Einstein Field Equation says so. When you solve the EFE for the case of a spherically symmetric vacuum, and make sure your solution is complete, what you get is the spacetime shown in the Kruskal chart. When you solve the EFE for the case of a spherically symmetric vacuum surrounding collapsing matter, what you get is a portion of regions I and II of the Kruskal chart, as shown in DrGreg's diagram. There is no way to solve the EFE and only get region I; such a solution is incomplete, just as the original O-S solution was incomplete.
I'm not sure what you think the difference is between all these things. See my comments above; perhaps they will help to either clear up your confusion or at least clarify your questions.
  • #42
This is a quantum argument, not a classical one. It is basically the same one Krauss et. al. make. A problem is that there is no consensus on this. Both before, and after in specific answer to it, other researchers find that quantum corrections and evaporation to not prevent the event horizon from forming in finite time for observers falling with the collapse. The two school's of thought, then, differ on how quantum mechanics solve the 'information problem' for black holes:
1) There is no problem. Evaporation saves the day in time. You don't even need to worry about a quantum treatment of a horizon that doesn't exist.
2) Evaporation doesn't save the day. There is problem. You do need to worry about a quantum treatment of a horizon. The solution is some type (many proposals) of a quantum black hole analog - that shares many predictions to a classical BH, but differs in various details, and has no singularity. This object also eventually evaporates.
  • #43
That's interesting, thank-you. In my limited experience, discussions on Black Holes seem to presume their existence before examining their properties. Let's not discuss if and when objects can cross the EH for a moment; rather, let's discuss "when" an existing BH formed in the past from the distant observer's perspective. Classically, it's eternity! Infinite time in the future to grow and infinite time in the past to be created. And what to do with the singularity?
From a layman's perspective it seems that BH's introduce more problems than they solve, particularly when we have a theory for resolving the issue (i.e. Hawking Radiation)
  • #44
The only objective statement, classically, that can be made about the distant observer is that they never see a BH finish forming (for a collapse, they see a dark ball just bigger than where EH would be calculated to be; the matter inside the collapsing body has apparently vanished).
When you try to go from here to 'when' a BH formed, (classically or otherwise) you have a problem. This gets right back to special relativity as Pervect has reminded several times. There is no objective meaning to now at a distance. Depending on what simultaneity convention you use, you can say, for a distant observer, the BH never forms; or that it formed 3PM yesterday. Neither statement has any physical content. So, "a BH never forms for distant observer" is a statement with no meaning in classical GR. The very similar statement "a BH is never seen to finish forming by distant observer" is a physical and indisputable statement.
The issue is that a successful theory predicts they readily form (in sense above) from reasonable initial conditions. Observationally, the evidence piles up that things exist which have all the properties of GR black holes that can be verified from a distance. So the problem must be dealt with. What, exactly, is really there remains in dispute and will for some time (more observational evidence is coming all the time; quantum gravity theory will eventually progress).
  • #45
Their existence is not "presumed"; it is shown by solving the Einstein Field Equation for a spherically symmetric vacuum spacetime. The solution makes it clear that there *is* and event horizon and a black hole region inside it, and that objects *can* cross the EH in a finite proper time (i.e., a finite time according to a clock that is falling in with the object). Of course this is a classical solution and doesn't take quantum effects into account; we can't fully take quantum effects into account because we don't have a theory of quantum gravity yet. See my comments at the end of this post.
Infinite *coordinate* time according to Schwarzschild coordinates. But, as I've explained in previous posts in this thread, Schwarzschild coordinates become "infinitely distorted" at the horizon; they make finite lengths, like the finite length of an infalling worldline that crosses the horizon, look like infinite lengths.
AFAIK nobody claims that the full, maximally extended solution, which includes a white hole that is "infinitely far in the past" according to Schwarzschild coordinate time (which has the same limitations here as it does in the future direction, see above), is physically reasonable. The physically reasonable solution includes a collapsing object (such as a star) in the past, not a white hole. That object collapsed at a finite time in the past, even according to Schwarzschild coordinate time.
Do you mean the actual, physical singularity at r = 0? Or do you mean the coordinate "singularity" at the horizon"? The latter is not a "real" singularity; it's an artifact of the infinite distortion of Schwarzschild coordinates at the horizon. The former *is* a real singularity, and does show a limitation of classical GR. See below.
Actually, we don't have a full theory that resolves the issue. "The issue" is really three issues; following on from what PAllen said, they are:
(1) When we take quantum effects into account, do they prevent a horizon from forming at all? In other words, does some quantum process cause any collapsing object that is predicted by classical GR to form a horizon and a black hole, such as a sufficiently massive star, to instead get turned completely into outgoing radiation *before* the horizon forms?
(2) If the answer to #1 is "no", do quantum effects at least prevent a singularity of infinite spacetime curvature from forming at r = 0 when the outer surface of the collapsing object reaches that point?
(3) If the answer to #1 is "no", regardless of what the answer to #2 is, can we at least be sure that quantum effects, such as Hawking radiation, prevent any information from being lost behind the horizon? In other words, even if objects do fall into the black hole and get destroyed in the singularity at r = 0, is their information still converted into Hawking radiation so it gets preserved?
We don't know the correct answer to any of these questions at this point. My understanding of our current "best guess" is that the answer to #1 is "no", and the answers to #2 and #3 are "yes". But we don't know for sure.
  • #46
With respect, when I'm philosophically discussing the existence of black holes I'm speaking about the realm of reality, not mathematical models. You said that the "only physically reasonable conclusion" was that they existed, while PAllen pointed out that the true answer is ambiguous at best. My personal opinion is that they do not exist in reality and current theory (as I understand it) cannot objectively conclude otherwise.
  • #47
In reality we are not allowed the luxury of an infinite past. If a calculation shows that the EH must have formed prior to the Big Bang, I find this problematic.
  • #48
Just to clarify: I said that's true according to classical theory. But we know classical theory has limitations.
Because we don't know what the effect of quantum corrections to the classical theory is. They may prevent the horizon from forming, or they may not, as I said.
Yes, there are plenty of people who have that opinion. My personal opinion is basically the same as what I said the current "best guess" is: horizons do form, but they eventually evaporate away. But nobody knows for sure.
  • #49
No calculation shows that; even the classical calculations, that show an EH forming, don't show it forming prior to the Big Bang.
  • #50
PAllen said:
B) Consider an observer that is distant and hovering into eternal past, but at some moment free falls into the BH (late enough so they hit the singularity). For this observer, both past-only and future-only conventions include both interior and exterior events. However, past only covers only a portion of spacetime - ending with the past of the termination of free fall world line on the singularity. A future only simultaneity covers all of space time, and is thus also a causal inclusive simultaneity.
In my opinion, it seems clearly desirable to favor causal inclusive simultaneity; and thus it is unfortunate that so much attention is paid to SC time slice simultaneity, which is exclusively a past-only simultaneity.
Going back to your OP, wouldn't the analysis of a white hole lead to the opposite conclusion?
  • #51
Did you read a few sentences earlier:
"Now consider these for the Oppenheimer-Snyder spacetime (asymptotically flat; collapsing space time region; interior and exterior SC regions eventually). I choose this for qualitative plausibility and to avoid the white hole region (the notions certainly apply to full SC geometry)."
There is no white hole in this scenario. As noted, I could apply the definitions to a WH case, but then the results would be different. I wasn't interested in doing so, because I don't consider a WH plausible. GR itself requires white holes originate in the past without cause; while black holes are predicted (classically) to form from plausible starting conditions.
In case you were asking me to apply the concepts to the white hole case, I am not interested. There is more than enough confusion about collapse to BH; I don't want distraction from the white hole case.
  • #52
If an EH is shown to form at all it would be shown to occur after the BB by definition. I'm talking about starting with a black hole of mass M+A, where A is the mass of an object which has fallen past the EH, and calculating "when" from the distant observer's perspective that object crossed the EH. If the object takes a local eternity to cross the EH falling in then it takes a local eternity to cross the EH coming out.
  • #53
I understand what you are asking except the part about coming out. Nothing comes out unless you are talking about quantum evaporation.
As for the rest:
- Classically, an infalling body merges with the pre-existing BH and expands its actual event horizon in finite (short) time locally for the infalling body; and reaches the singularity of the pre-existing BH in finite local time. The infaller does have an objective basis to correlate local and distant events, because they can keep receiving signals from outside until the moment they reach the singularity. They can see a specific distant clock time (in theory) as of the moment they reach the singularity.
- From a distant observers point of view, I keep repeating the question cannot be answered as worded; even similar questions in SR cannot be answered. You can answer when will a distant observe see the above happening? Then there is an answer: never. Because this physical answer is never, it follows that there is no objective answer to when A crossed the horizon for the distant observer. They can make an infinite number equally defensible answers, one of which is never.
  • #54
Logic shows this is a contradiction. Take the BH mentioned above of mass M+A, where A is the mass of an object *having already passed* the EH from a distant observer's perspective. Note the time = [tex]T_0[/tex]Now turn the clock back [tex]T_{-1}, T_{-2}, T_{-3}[/tex]...until the object of mass A is no longer beyond the EH at [tex]T_{-x}[/tex] (and I don't care if we're using Schwarzschild metric for the observer's calculations, for example, or we simply move backwards in time until he *sees* the object, as you said)
What are we left with? At [tex]T_{-x}[/tex] we have an object outside of the BH, and at [tex]T_0[/tex] that object has crossed over the EH in finite time according to the distant observer. The conclusion is that observing the object crossing back out of the BH as we turn the clock backwards will never happen from the distant observer's perspective, certainly not within the finite age of the Universe.
  • #55
This is already a statement whose meaning is rejected by relativity. All else is irrelevant. Because the distant observer can never see it happening, they can never say the know it happened. Maybe it did, maybe it didn't.
Maybe I misunderstand your intent. It is absolutely possible for a distant observer to assign remote times in a consistent way such that they consider the object to have crossed the horizon in finite time. They can also consistently assign remote times so that never happens. It will never be possible to verify one assignment over another precisely because event horizon crossing will never be seen.
  • #56
Exactly. This is equivalent to saying "maybe the black hole exists, maybe it does not." Point being black holes do not even necessarily exist in Relativity. I'd be curious to see a time-reversed Kruskal analysis of objects crossing (back out of) the EH.
  • #57
Yes, you can say a distant observer can never know an actual BH (rather than an 'almost BH') has formed. They can only compute that if GR is true, then for the matter at the 'almost BH' they do see, there is no alternative to a BH forming, in finite time for that matter. If GR is false in the near BH domain (as is likely to some degree), then there are alternatives.
However, because GR is unambiguous that a BH forms in finite time for the infalling matter, and new matter falls in in finite time for the infalling matter, it must be said that GR predicts black holes. That this prediction is not verifiable from the outside, doesn't make it not a prediction of GR. For example, QCD says quarks will never be detected in isolation. They are still a prediction of QCD.
The real 'way out' is that quantum gravity changes the classical GR predictions.
  • #58
If you are referring to a white hole, it's already present in the Kruskal diagram. The white hole is region IV on the Kruskal chart, as shown for example on the Wikipedia page:
If you consider a timelike free-fall trajectory that starts at the past singularity (the hyperbola at the bottom of region IV), emerges from the white hole (i.e., crosses from region IV into region I), rises to some finite radius r at Kruskal time V = 0, then falls back into the black hole (crosses from region I into region II), and finally ends up at the future singularity (the hyperbola at the top of region II): such an object's trajectory is time-symmetric; the part before V = 0 is the exact time reverse of the part after V = 0.
If, however, you are referring to a spacetime where a BH forms from the collapse of a massive object, then evaporates away, I haven't seen a Kruskal-type diagram of that case, but I have seen Penrose diagrams of the most obvious way to model it (which not everyone agrees is the correct model, but it's a good starting point for discussion). See, for example, the diagram here:
http://en.wikipedia.org/wiki/Black_hole_information_paradox
Compare with the Penrose diagrams on this page:
http://www.pitt.edu/~jdnorton/teaching/HPS_041/chapters/black_holes_picture/index.html
The Penrose diagram corresponding to the Kruskal diagram I linked to above is in the section "Conformal Diagram of a Fully Extended, Schwarzschild Black Hole". The Penrose diagram corresponding to the classical GR model of a collapsing massive object (like a star) is in the section "A Conformal Diagram of a Black Hole formed from Collapsing Matter".
Note that in *none* of the diagrams, other than the Kruskal diagram and the Penrose diagram corresponding to it, does the white hole appear. In the evaporation diagram, Hawking radiation escapes as the hole evaporates, but there is still a black hole interior region and a singularity, and anything that gets inside the horizon is still doomed to be destroyed in the singularity, according to this model. The big open question is, if this model is *not* correct (which most physicists in the field now seem to think it is not, since it leads to the loss of quantum information), what replaces it? There are a lot of suggestions, but no good answer yet.
  • #59
PAllen, I appreciate your maturity in acknowledging other (albeit subjective) points of view. The usual response is an emotional defense of BHs as a matter of fact...
  • #60
This discussion is growing a bit over my head, especially concerning time (my time, not Schwartzschild t, although it's almost the same :-p); I intended to quickly move on from a simple illustration to show that there is an issue, to a concrete physics discussion involving clocks and light rays. However it is interesting for me and perhaps also for invisible onlookers. I'll try to group things piece-wise and only discuss the essentials.
PAllen said:
[..] there are no contridictions between maps. Classically, you just have different coverage by different maps.
Different coverage means to me in the context of relativity, from the same reference system - from the same "perspective". However, what I was referring to was the mapping between different reference systems, of a time τ to a time t>∞, as follows:
harrylin said:
[..] [O-S] talk about t>∞. That doesn't make sense to me, which is what I had in mind with my remark that it looks like they didn't fully think it through. And that's not so strange, as their results were new.
PeterDonis said:
[..] I think [O-S] didn't fully explore the question of what the region of spacetime with "t > infinity" would look like. But just contemplating the existence of such a region is not a contradiction. Check my latest post in the simultaneity thread. [..]
As I clarified earlier, a "region of spacetime" is for me merely a mathematical tool for calculations of, as Einstein put it, "clocks and rods". t>∞ has as physical meaning a possible clock that indicates t>∞. That makes as little sense to me as v>∞.
On this point the discussion dropped outside of the speciality of GR into the realm of general philosophy of physics. Thus you would need to make a strong case with the following if your intention is to convince me (but I hope that that is not what you are trying to do):
"it is impossible for a singularity to form in a finite time", are proofs that a singularity cannot form *in the region of spacetime where the distant observer's time coordinate is finite*. [..] In fact, it is easy to show that there *must* be another region of spacetime, below the horizon, that is not covered by the distant observer's time coordinate. That must be true *because* the proper time for an infalling observer to reach the horizon is finite. Have you considered this at all?
First of all, I can't find anything that explains how you map a time τ to a time t>∞, as O-S suggest, and make physical sense of it. You must have considered this, and you suggested that you did, but I do not see that you clarified that essential point. It is a simultaneity that looks completely impossible to me.
Secondly, of course I considered the fact that O-S map t->∞ to τ->a. I cannot understand how you can think that I didn't reflect on the only part on which everyone agrees. I did not make a plot of it, but I did not see an issue with that. In the O-S model, if a completely formed black hole exists (which, if I correctly read Schwartzschild, he deemed impossible!), an infalling observer will not reach the inside region and as measured in t, his clock time τ will nearly "freeze" to slowly never reach a certain value τ0. As I picture it (for I have not seen a description of it), for the infalling observer the thus predicted effect will be very dramatic, with starlight in front of him reaching nearly infinite intensity as the universe speeds up around him and his observations come to a halt when this universe ends. In fact, it was a discussion based on a blog including that aspect with more than 100 posts that was the first thing that I read about this topic (http://blogs.discovermagazine.com/badastronomy/2007/06/19/news-do-black-holes-really-exist/)
Have you not been reading all the posts I and others have made explaining "how other people interpret this"? [..]
Sorry: I did not see any explanation for the inside region that made any sense to me, or that explains to me how it cannot contradict Schwarzschild's model. Perhaps some others who asked similar questions were convinced, but I did not see that happen (and of course, there is no use to try to convince anyone about which model is "right"; this is just a discussion of models). Perhaps there is another post that I overlooked?
  • · Replies 51 ·
  • · Replies 127 ·
10K
  • · Replies 16 ·
  • · Replies 38 ·
