Why Does Cold Water Increase Survival Rates in Drowning Incidents?
  • Thread starter Thread starter K.E
    Reactions
Submersion in cold water can lead to survival in drowning cases due to several physiological factors. Cold temperatures slow down metabolic processes, reducing the body's oxygen demand and allowing for a longer survival time without oxygen. In contrast, warmer water increases metabolic rates, leading to quicker depletion of oxygen in the body. Additionally, oxygen solubility is higher in cold water, but the key factor is the body's response to temperature. In warmer conditions, the rapid movement of water molecules can cause oxygen to escape more easily, further diminishing the oxygen available for survival. Overall, the combination of slowed metabolism and oxygen conservation in cold water contributes to the potential for revival after drowning.
K.E
People who have been submerged in very cold water, and presumed drowned, have sometimes been revived. By contrast, people who have been submerged for a similar period of time in warmer water have not survived. Suggest reasons for this difference.
I know this has to do with the fact that higher temperatures increase the rates of reaction because more particles collide with enough energy to react. But I am not sure of how to relate that to this question.
Thanks!
Chemistry news on Phys.org
Think how fast oxygen is used by the tissues.
Is it because oxygen dissolves more easily in cold water than in warm water? Also because when the water is warmer, its molecules move and vibrate faster, making it easier for oxygen molecules to escape from solutions?
No, it is not about amount of oxygen dissolved in water. It is about oxygen in the body.
Effect on Metabolism by temperature?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
