The model of electric flux in solids
The discussion focuses on the behavior of electric flux in a solid metal cylinder under direct current (DC). It clarifies that DC is a constant, non-varying current, which does not exhibit the skin effect, a phenomenon relevant only to alternating current (AC) at high frequencies. In a perfect conductor, there is no electric field inside, as any induced field would cause electrons to move and neutralize it. When considering a real conductor, a very small electric field exists due to resistance, but current density remains uniform across the cylinder's cross-section. Thus, in the case of direct current, conductivity and resistance are consistent throughout the entire cross-section of a homogenous metal.
dkastz
hi there!
I have a bit stupid question:
Imagine a solid metal cylinder. We put a . Explain to me please the exact model of the direct current electric flux of the particles. Is there a "skin effect" when a direct current is in action ?
dkastz said:
hi there!
You did not finish the sentence.
Is Direct Current means constant non varying current? If so, there is no skin effect to talk about, skin effect only happen with varying current and rather high frequency( no as high as people think!).
There is no electric field inside a good conductor like metal if you assume it's a perfect conductor. Any electric field developed inside the metal WILL cause the electrons to move in opposite direction to neutralize the field. That's the reason there is no electric field in a perfect conductor.
In real life, there is a very very ( very!) small electric field if you drive a current through as it's not a perfect conductor, a little voltage developed across the metal due to the resistance.
grr i just saw that i missed the sentence!
Yes. you`re right - Direct Current means constant non varying current. I am wondering what happens inside the cylinder - where do electrons pass - all over the cross section or just at the surface. For the example the two points of current are the centers of the circular faces of the cylinder. What happens if i vary the diameter of the cylinder ?
If it is direct non varying current, the current density in the middle is the same as close to the surface. It is all over the cross section of the cylinder. Skin effect only applies to varying current.
http://en.wikipedia.org/wiki/Skin_effect
deos this mean that in direct, non varying current, the conductivity/resistance is equal on the surface and in any point in the cross section (in case of perfect homogenic metal structure) ?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
