| New Reply |
Is g affected by other sources of gravity? |
Share Thread | Thread Tools |
| Nov24-12, 03:53 PM | #1 |
Earth shouldn't alone make the value of g=9.81m/sec^2. There is the moon, all the planets and our sun (ignoring the outstanding multitude of outer space for my simplicity) and all of these bodies must have some influence on everything that's on Earth. So if we want to find the real acceleration due to gravity on Earth, wouldn't we have to find the net acceleration after taking into account all these sources of gravity that are trying to pull me toward their respective selves?
| Nov24-12, 04:00 PM | #2 |
It's a similar question to the one : Would you include the change in g if you were to calculate the height at which you'd throw a ball?
| Nov24-12, 04:20 PM | #3 |
Mentor
| Nov24-12, 04:28 PM | #4 |
Mentor
To add some numbers:
Earth: ~9.81 m/s^2 Sun (average): 0.0059 m/s^2 Moon (average): 0.000033 m/s^2 Jupiter at closest approach: 3.7*10-7 m/s^2 = 0.00000037m/s^2 Venus at closest approach: 2.3*10-7 m/s^2 But: Those forces are very uniform throughout earth. You cannot measure an absolute acceleration - only a difference between two points (here: earth and you). This changes numbers a lot: Earth: ~9.81 m/s^2 Moon (average): 6*10-7 m/s^2 Sun (average): 3*10-7 m/s^2 Venus at closest approach: 4*10-11 m/s^2 Jupiter at closest approach: 4*10-12 m/s^2 And just for fun: Proxima Centauri (closest star): ~10-23 m/s^2 1000 kg in a distance of 2m: ~2*10-8 m/s^2 Best relative gravimeters according to Wikipedia article: ~10-11 m/s^2 (at least within some hours of measurement: source, pdf) |
| Nov24-12, 05:50 PM | #5 |
Not that I'm suggesting a midwife could be 1000kg!! |
| Nov24-12, 06:58 PM | #6 |
Recognitions:
There is a standard value for g by definition, 9.80665 m / s^2 or 32.1740 ft / s^2. Wiki article:
http://en.wikipedia.org/wiki/Standard_gravity |
| Nov25-12, 07:25 AM | #7 |
| Nov25-12, 07:33 AM | #8 |
| Nov25-12, 07:34 AM | #9 |
Of course. And it is measurably affected by the Moon and Sun - hence the tides.
| Nov25-12, 11:31 AM | #10 |
Recognitions:
| Nov28-12, 11:59 AM | #11 |
1) Using Newton's law of gravity and his 2nd law of motion. (I think, g calculated using this approach would be the value that it only Earth alone is responsible for producing). 2) Using a pendulum whose time period is known. (This one should automatically take into account all the other forces present ) I did perform those experiments in school, but I wasn't enough interested back then to check how well the two techniques agree with each other. Thanks for your answers everyone! You guys are awesome! (and that was a very informative post mfb. Thanks!) |
| Nov28-12, 12:39 PM | #12 |
Mentor
| Nov28-12, 12:57 PM | #13 |
So the experiment is to drop a lead weight and see how long it takes to fall a measured distance? Or to see how fast it is falling after a measured time? No, such a measurement is not dependent entirely on the gravity from the mass of the Earth. It would also depend on the motion of the Earth and on the gravity from the Sun, Moon and planets. The contribution from the rotation of the Earth is typically far more significant than the contribution from the tidal force of the Moon. |
| Nov30-12, 02:00 AM | #14 |
Tidal forces wouldn't affect a point particle, it's the differential force across the earth that causes tides. Otherwise the sun would be our tidal driver.
| Nov30-12, 04:28 AM | #15 |
| Nov30-12, 04:33 AM | #16 |
The planets would have very little effect, but the Sun and Moon do, hence tides and King tides To the original question, the experiment would have been done countless times over years so you would assume that the value would be an average. To calculate the real force, you can mathematically factor in all the planets to give you a true value for that present moment. |
| Nov30-12, 04:59 AM | #17 |
Mentor
This isn't the right metric, however. The tidal force caused by some body is the difference between the gravitational accelerations toward that body at the surface and center of the Earth. This makes the contributions from the Sun a bit less than half of those from the Moon. |
| New Reply |
| Thread Tools | |
Similar Threads for: Is g affected by other sources of gravity?
| Thread | Forum | Replies | ||
| Why is light affected by gravity? | General Physics | 16 | ||
| Is EVERYTHING affected by gravity? | Special & General Relativity | 2 | ||
| Is sound affected by gravity? | General Physics | 5 | ||
| Why are Photons affected by gravity? | General Physics | 5 | ||
