Experiment with grounding and EMFs
The discussion revolves around conducting an experiment to assess how grounding affects electromagnetic fields (EMFs) generated by appliances. The experiment involves modifying a power cord by disconnecting the hot wire while ensuring safety precautions are followed. Participants emphasize the importance of verifying home wiring to prevent hazards, as incorrect wiring could lead to dangerous situations. Measuring EMFs with a meter while using a battery-powered device is suggested, although the practical significance of the experiment is questioned. Overall, consulting a qualified electrician and adhering to safety protocols is strongly advised before proceeding with any modifications.
ZeroGzex
Hi,
I'd like to do a simple experiment to see how grounding influences the EMF generated by an appliance. I'm a novice at these sorts of things though, and I want to be sure that there aren't any safety concerns which I'm not aware of. In order to do my experiment, I would modify a 3 pronged power cord by bending aside the hot plug and taping it completely over with electrical tape, so that only the neutral and ground plugs connect. I would then plug an appliance into a standard house outlet with this cord and measure how its magnetic field differs from when it is plugged in normally. Would there be any potentially serious hazards in doing this? Also, would it ever be possible for electrical current to travel up through the neutral and/or ground slots of the outlet and into the appliance rather than flowing only in the other direction? Would uncommon events like a power surge or lightning strike have any effect?
Thanks for your replies,
Zex
Welcome to the PF.
As long as your home is wired to code (I'm assuming you are in the US), there should not be any safety issues with disconnecting the Hot lead. Just be sure to disconnect the Hot lead and not the Neutral...!
The results will show that there is no electrification of the appliance if Hot is disconnected. How are you planning on measuring any magnetic fields? What is your overall goal in doing this?
I am not an electrician, this is my understanding:
If your house electricity is wired correctly, there should be no current in and out of the appliance if you disconnect the hot wire. The ground is usually a long rod pounded into the ground soil as ground safety. The neutral is the return wire of a 3 phase hot wire. It is supposed to be grounded to Earth like the ground wire in the power station. Only two hot wire is connected into the house...say call them red and black wire. Each is 110V reference to the neutral wire. But it is 220V across the red and black wire. So in your house, the 220V plug is just the red and black wire, your 110V is either red with neutral ( white) or black with neutral.
So if you cut the hot wire, you have no power...theoretically! BUT, BUT, I have seen houses with wrong wiring, they can accidentally switch the neutral and hot wire around and if you just cut the wire you "think" is the hot wire, you still have the power connected and that is deadly dangerous.
So you need to be careful, use a safety check plug ( one that has LED or lights that show what is safe and what's not) to test the plug before you do this. But I still don't see the point of you doing this as there is no power if everything is correct.
Great. Thanks for the info guys. I'll be measuring the EMF with a meter, and I forgot to mention that I'm planning to do this with a laptop running on battery power. It would indeed be pointless to try it with something that has no battery, though admittedly my knowledge of physics isn't thorough enough to know if there is a point even with a device running on battery power. My rational is simply curiosity. Gaining an understanding of the physical world and all that.
Hello Zex,
Thank you for your interest in experimenting with grounding and EMFs. It is always important to take safety precautions when conducting any type of experiment, especially when dealing with electricity.
Firstly, I would recommend consulting with a qualified electrician before modifying any power cords. They will be able to advise you on the best way to safely modify the cord without causing any potential hazards.
Additionally, I would suggest using proper equipment and following safety protocols when measuring EMFs. This may include using a calibrated EMF meter and wearing appropriate protective gear.
As for the possibility of electrical current traveling up through the neutral and/or ground slots, it is unlikely but not impossible. This is why it is important to consult with a qualified electrician and follow safety protocols.
Uncommon events such as power surges or lightning strikes may have an effect on the experiment, but again, it is important to take safety precautions and consult with a professional before conducting the experiment.
Overall, I would recommend taking proper safety measures and consulting with a qualified electrician before conducting any experiments involving electricity and EMFs.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
