Register to reply
I am starting to doubt Ohm's law. I would like someone to point out why I am wrong.
by anj16
Tags: ohm's law
Share this thread:
anj16
#1
Dec11-12, 09:00 PM
P: 38
As the title states I am really doubting Ohm's law. This is why: On a breadboard I placed a white LED and a 220Ω resistor with the 9v battery all in series. The total current flowing through the circuit shouldn't be more than 41mA by V=IR, but my multimeter points between the range of 150-120(Edit: mA). Can someone tell me why???
Thank you.
Phys.Org News Partner Physics news on Phys.org
A new, tunable device for spintronics
Watching the structure of glass under pressure
New imaging technique shows how cocaine shuts down blood flow in mouse brains
Integral
#2
Dec11-12, 09:07 PM
Mentor
Integral's Avatar
P: 7,318
We can't help without knowing what you are doing. A circiut diagram including how the meter is connected would help. Try to diagram what you have on the breadboard.
120-150 whats? What kind of meter are you using?
davenn
#3
Dec11-12, 09:14 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,640
what sort of white LED is it give us a part number ?
it may be one that draws more current
Hint.... If you ever want to doubt a known physical law, assume it's something you are doing wrong, not the law ;)
Dave
anj16
#4
Dec11-12, 09:16 PM
P: 38
Quote Quote by Integral View Post
Sorry about that I have edited it in the original post.
Just so you know the correct way of connecting a meter in a circuit to measure the current is to connect it in series. which I did.
anj16
#5
Dec11-12, 09:18 PM
P: 38
Quote Quote by davenn View Post
Dave
I agree with you which is why I thought someone could point out where I am wrong. And about drawing more current wouldn't the current be restricted by the resistor?
BackEMF
#6
Dec11-12, 09:19 PM
P: 53
Quote Quote by anj16 View Post
Thank you.
1) Measure the actual resistance of the "220 ohm" resistor.
2) Check the accuracy of the meter (use another meter - digital might be better as it would probably change the circuit less than and analgoue one)
anj16
#7
Dec11-12, 09:21 PM
P: 38
The resistance of the 220 ohm resistor comes to about 218 ohm.
BackEMF
#8
Dec11-12, 09:28 PM
P: 53
Can we verify the battery's voltage?
davenn
#9
Dec11-12, 09:31 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,640
yes, but the calculated total current through the circuit is a combination of the total resistance of the resistor and of the forward resistance of the LED
you still didnt tell us what sort of LED ??
Dave
K^2
#10
Dec11-12, 09:39 PM
Sci Advisor
P: 2,470
Unless LED develops a negative voltage drop, that seems kind of irrelevant, no? 9V / 220 Ohm = 41mA.
Any LED will actually reduce voltage by about 1 - 2 volts. So the current with an LED should be even less than 41mA. 150+ mA cannot be explained by any kind of LED.
anj16, can you take a picture of your setup?
anj16
#11
Dec11-12, 09:50 PM
P: 38
@Dave about the part# for the LED, I have no clue. I bought in bulk off Ebay.
I have attached a picture of the setup
anj16
#12
Dec11-12, 09:52 PM
P: 38
Quote Quote by BackEMF View Post
The voltage of the battery is 9v
K^2
#13
Dec11-12, 09:56 PM
Sci Advisor
P: 2,470
Isn't the entire + line connected on the breadboard? If so, your resistor is shorted out. Try checking resistance while it is in the breadboard.
anj16
#14
Dec11-12, 10:02 PM
P: 38
Quote Quote by K^2 View Post
Thank you so much!! I never thought about that. I think I need a break from this ;)
EDIT: Also the doubt I had is gone because I re-measured the current and it comes to about 41 mA.
davenn
#15
Dec11-12, 10:37 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,640
prob solved ....
the old saying ... a pic is worth 1000 words ;)
Dave
davenn
#16
Dec11-12, 10:38 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,640
yup fair comment :)
D
Register to reply
Related Discussions
Probability doubt - where am i wrong? Set Theory, Logic, Probability, Statistics 2
Starting point of measurement Astronomy & Astrophysics 1
Starting point Academic Guidance 7
Starting point Academic Guidance 5
