New Reply
Elastic collisions
Share Thread Thread Tools
Dec17-12, 12:19 PM   #1
Elastic collisions
1. The problem statement, all variables and given/known data
A 2.0 kg ball moving with a speed of 3.0 m/s hits, elastically, an identical stationary ball. If the first ball moves away with an angle 30 degrees to the original path, determine the speed of the first ball after the collision, and the speed and direction of the second ball after the collision.
2. Relevant equations
v_1 = V_1cos30 + v_2cos(theta) for the movement in the "x" direction
and
0 = v_1cos30 + v_2cos(theta) for movement in the "y" directions
3. The attempt at a solution
Played with this for hours but to me it does not seem like there is enough information. I feel like I am missing at velocity for after the collision.
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Dec17-12, 12:25 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi doub! welcome to pf!
Quote by doub View Post
A 2.0 kg ball moving with a speed of 3.0 m/s hits, elastically …
an elastic collision is defined as one in which energy is conserved (as well as momentum, which is always conserved in collisions)
Dec17-12, 12:46 PM   #3
Right,
this is the best answer I got however I do not feel anywhere near confident.
3.0 m/s = v_1'cos30 + v_2'cos(theta) = 2.598 m/s + v_2'cos(theta) = 3.0 m/s - 2.598 m/s
so v_2'cos(theta) = 0.402 m/s in the "x" direction
0 = v_1'sin30 + v_2'sin(theta) = 1.299 m/s + v_2'sin(theta). so v_2'sin(theta) = -1.299 m/s
tan^-1 = v_2'cos(theta)/v_2'sin(theta) = -1.299/0402 = -72 degrees
and using sqrt(v_2'sin(theta)^2 + v_2'cos(theta)^2 = 1.36 m/s
am I anywhere in the ballpark at least?
Dec17-12, 01:24 PM   #4
Recognitions:
Elastic collisions
hi doub!
(try using the X2 button just above the Reply box )
no, v1' isn't 3.0, it's unknown!
try the momentum equations again (and you'll need an energy equation also)
Dec17-12, 01:38 PM   #5
yeah I'm totally lost now
Dec17-12, 01:57 PM   #6
Recognitions:
start again, with v1' v2' and θ as your three variables
(you have three equations: x, y, and energy, so that should be solvable )
show us what you get
Dec17-12, 02:02 PM   #7
Ok,
The equations I have gotten are
x --> v_1 = v_1'cos30 + v_2'cos(theta)
y --> 0 = v_1'sin30 + v_2'sin(theta)
Energy --> v_1^2 = v_1'^2 + v_2'^2
Dec17-12, 02:11 PM   #8
Recognitions:
fine so far
now fiddle about with the first two equations so that cosθ and sinθ are on their own, then use cos2θ + sin2θ = 1 to eliminate θ
Dec17-12, 02:25 PM   #9
So,
cos(theta) = v1 - (v1'cos30)/v2'
and
sin(theta) = (-va'sin30)/v2'
where do the sin2theta come from?
Dec17-12, 02:33 PM   #10
Recognitions:
uhh?
square both equations!
Dec17-12, 02:45 PM   #11
I am just not seeing this...
cos2(θ) = (v12 -v12'cos302)/v2'2
sin2(θ) = (-v12'sin302)/v2'2
thanks very much for helping btw
Dec17-12, 02:53 PM   #12
Recognitions:
ok, now add
θ will miraculously disappear!
pzzaaam!
Dec17-12, 03:11 PM   #13
so if we add are we left with;
(v12 -v12'cos302) + (-v12'sin302) / 2v2'2
Dec17-12, 04:05 PM   #14
Recognitions:
actually, the RHS of that first equation should be (v1 -v1'cos30)2/v2'2
how did you get that?
where has the = sign gone?
New Reply
Thread Tools
Similar Threads for: Elastic collisions
Thread Forum Replies
elastic collisions Introductory Physics Homework 1
The elastic collisions of gas Classical Physics 1
Elastic Collisions Introductory Physics Homework 12
