Endothermic Reactions: Activation Energy & Heat Transfer
Every chemical reaction requires sufficient activation energy for reactants to initiate the process, often supplied by heat from the surroundings. In endothermic reactions, reactants absorb heat to break existing bonds, resulting in a temperature drop. The energy released during the formation of new bonds is less than the heat absorbed, leading to a net decrease in temperature. The activation energy comes from both the ambient temperature and any additional heat source. The discussion raises questions about the experimental setup and the clarity of the heat source's role, indicating a need for further detail to fully understand the process. Overall, the theory presented appears sound, with minor suggestions for clarity and precision.
Celluhh
every reaction requires its reactants to have enough actvation energy in order to start the chemical reaction.sometimes, extra energy is provided in the form of heat. so the reactants take in heat from the surroundings and have enough energy to break old bonds and form new bonds. when they break old bonds they take in the heat energy provided right? then when they form new bonds they let out energy that is less than the heat energy provided hence some of the heat energy is actually taken in by the reactants right?that causes the temp drop as shown in the endothermic temp graph.
just to clarify if my line of thought is correct, in this case the activation energy that the reactants possesses come from the heat energy at room temperature as well as the heat energy from the heat source right? and that the amount of heat energy that reactants let out is much lesser than this energy combined, hence causing temp to drop to a minimum, am i right?
the purpose of typing out this paragraph is to check if my theory has anything wrong in it, so please feel free to correct me if i am wrong!Thank You!
Chemistry news on Phys.org
I don't see anything obviously wrong in what you wrote (apart from the fact phrases should start with a capital letter), but:
1. I don't see the plot you refer to, I am only guessing its content.
2. Seems to me like you first refer to the system without heating and then miraculously there is a heat from a heat source. That makes me wonder what is the experimental setup you are talking about.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
