| New Reply |
On the nature of the "infinite" fall toward the EH |
Share Thread | Thread Tools |
| Dec25-12, 06:42 AM | #426 |
Mentor
On the nature of the "infinite" fall toward the EHIn general an EH forms whenever there is enough mass inside the Schwarzschild radius. That can happen at any density, so a mechanism which prevents high densities, like degeneracy, simply cannot prevent EH formation in general. |
| Dec25-12, 11:00 AM | #427 |
| Dec25-12, 11:07 AM | #428 |
| Dec25-12, 12:21 PM | #429 |
http://en.wikipedia.org/wiki/Tolman%...3Volkoff_limit Conceptually, both limits work the same, but the details are different because of the different types of fermions involved (neutrons vs. electrons). |
| Dec25-12, 12:24 PM | #430 |
| Dec25-12, 12:26 PM | #431 |
| Dec25-12, 12:28 PM | #432 |
| Dec25-12, 02:06 PM | #433 |
Mentor
| Dec25-12, 02:13 PM | #434 |
| Dec25-12, 02:17 PM | #435 |
Mentor
| Dec25-12, 04:16 PM | #436 |
| Dec27-12, 11:53 PM | #437 |
Quote by Austin0
Well I agree that Zeno did not explicitly define a coordinate frame ibut he did implicitly define Achilles motion in the terms of the ground.I.e. Achilles successively caught up with a previous position of the tortoise which would naturally be a spatial point on the ground. So in this context the ground would be an inertial frame. And Pervects statements could validly be interpreted in this context. In which case it would be Achilles motion which was non-inertial.Such an interpretation would be perfectly consistent with Pervects statements right up to total zeno time being infinite. Yes???. so you are circularly inserting an assumption that Zeno coordinates are non-inertial. Quote by Austin0 WHich is why I said Quote by Austin0 Clearly I did not suggest that my interpretation was the only possible one but only pointed out that it was also not precluded and other interpretations were not exclusive or preferred. Unsupported assertion that my interpretation is wrong and yours is fact. Quote by Austin0 2) Could you explain this metric? It is true it does not look like an inertial metric but it also does not resemble the Sc metric either. If I am understanding it correctly the first term contains both Zeno coordinate time and also Achilles coordinate time yes? How does that work ? it appears a bit circular no?? It also appears that it is based on a constant velocity term in the Zeno frame , how is this possible??? 3) What is your definition of inertial. Lack of accelerometer reading? Disregarding g both Achilles and the Zeno frame are inertial by this standard. Constant motion. As observed from all inertial frames both Achilles and Zeno frames are in uniform coordinate motion yes? So are equivalent. As far as I know inertial frames are simply defined by uniform rectilinear motion without explicit reference to time flow so what is your basis for this strong assertion that the Zeno frame is non-inertial??? your initial premise here [itex]d=100-vt[/itex] means that Achilles catches the tortoise at d=0 or 100-vt=0 so vt=100 and [tex]t = \frac{100}{v}[/tex] SO clearly yiour conclusion [tex]\lim_{n\to \infty } \, t = \frac{100}{v}[/tex] is directly equivalent to your initial premise [tex t = \frac{100}{v}[/tex] without any of your intermediate steps and is classically circular reasoning. A tautology if you like. Also: Given your declaration of Achilles inertial motion, as far as I can see there is no possible state of accelerated motion of the Zeno frame that could effectuate the observations of Achilles motion as defined by Pervect. SO unless you can come up with such a description I propose that Zeno motion is also inertial i.e. constant and the non-uniformity is all temporal. DO you disagree ? If so what possible motion?? In this case then, the temporal non-uniformity could not be actual dilation , meaning change of physical processes etc. as there is no known physics to explain this kind of exponential increase of time rate concurrent with the decrease in coordinate velocity of the inertial Achilles . SO this leaves arbitrary mechanical clock rate as the only possible scenario consistent with your own conditions and assumptions. Just as I suggested early on and you rejected with your tautological definition. Or do you disagree and have an alternative explanation??? so the Zeno clocks speed up exponentially but Zeno observers do not .. But this seems to me to mean that finite proper time on Achilles clock could not possibly mean infinite time on a mechanically calibrated actual physical clock. SO the analogy is completely non-applicable. Or do you still disagree??? |
| Dec28-12, 07:41 AM | #438 |
Mentor
So, yes, it is an assumption that Achilles' motion is an inertial, that assumption is part of the original well-known scenario. Pervect's definition of a coordinate system does not change that assumption since it is invariant, and an "interpretation" of pervect's comments which assumes that specifying coordinates also changes invriants is simply a mistake. EDIT: I later realized that there may be some lingering confusion about the meaning of inertial. When we are talking about a worldline then inertial does mean zero proper acceleration (zero accelerometer reading). When we are talking about a coordinate system then inertial means that the metric is the Minkowski metric in those coordinates. These are both the standard definitions in GR. So Achilles' worldline is inertial under the first definition, and the Zeno coordinates are non-inertial under the second definition. I hadn't originally noticed that you were mixing a worldline and a coordinate system in your question above. |
| Dec28-12, 08:06 AM | #439 |
Actually, there is a difference having to do with causality, but it doesn't come into play in anything you've said so far: For the Schwarzschild case, events after the traveler crosses the event horizon are inaccessible to the distant observer, while in the Zeno cases, there are events after Achilles crosses the finish line that are accessible to the distant observer (although they can't be given a time coordinate in the coordinate system of the distant observer). -- Daryl McCullough Ithaca, NY |
| Dec28-12, 08:07 AM | #440 |
Mentor
[tex]\frac{dn}{dt}=\frac{v}{(100-vt) ln(2)} [/tex] and [tex]t=\frac{100}{v}(1-2^{-n})[/tex] Substituting the second equation in on the rhs of the first equation and simplifying we get [tex]\frac{dn}{dt}=\frac{2^n v}{100 ln(2)}[/tex] So the metric in post 414 should be: [tex]ds^2=-c^2 \left( \frac{100 ln(2)}{2^n v} \right)^2 dn^2 + dx^2 + dy^2 + dz^2[/tex] Which again is clearly not the Minkowski metric of an inertial frame, thereby demonstrating that the Zeno coordinates are non-inertial. |
| Jan1-13, 10:51 PM | #441 |
Quote by Austin0
Pervect has here given a series of events. Or at least relationships as there seems to be no determinable velocities or explicit spatial coordinates to be derived from this information. You have asserted that the Zeno frame is non-inertial so the question is what possible state of motion of that frame could make possible those observed distances between two bodies in uniform motion. Maybe an example would help you visualize: If the observations in the Zeno frame supported a picture of linear decrease in distance between Achilles and the tortoise this would indicate a constant motion of the Zeno frame also , agreed??? If the observed decrease in distance, itself increased in rate , this would support a conclusion of positive parallel acceleration of the Zeno frame.I.e. Zeno frame increasing it's velocity relative to A and the tortoise. But according to Pervect the decrease in relative distance between Achilles and the tortoise is decreasing over time non-linearly. SO what possible motion (acceleration) of the Zeno frame could make this possible???? My conclusion is that there is no possible acceleration that could do this alone and therefore the observations in the Zeno frame could only be possible if the Zeno time rate was increasing at a rate not possible through the effects of motion ( Lorentz effects..) Quote by Austin0 Achilles is passing a stream of Zeno clocks and observers. Do you think Achilles sees everything in the Zeno frame speed up exponentially or only the clocks??? If you think everything speeds up (actual dilation) then what is your explanation of the physics behind this??? This would be to a certain extent possible if Achilles and the tortoise were racing at relativistic speeds in a circle in a stationary Zeno frame but I doubt the exponential increase would be possible even with accelerating racers. If you think it is only the clocks, an arbitrary coordinate choice, then you are talking about a mechanism to accomplish this radical increase in rate in actual physical clocks correct? Quote by Austin0 |
| Jan1-13, 11:01 PM | #442 |
The only definition of v actually expressed is in the Achilles frame so that does not seem like it could be that ,right? So how do you define v in the Zeno frame and what does it apply too??? ******************************_____ You have stated that although Achilles and the tortoise are inertial, the Zeno frame is not, so how do you arrive at your identity here to justify your substitution and simplification. The d here in Achilles frame; [itex]d=100-vt[/itex] is not equivalent to the d' here in Zeno's frame; [itex]d'=100/2^n[/itex]. is it??? Having invoked relativistic principles in this classic scenario how can you now directly equate a distance in one frame with that in another which is not only moving at a relative velocity but which is in non-uniform motion??? What about simultaneity??? So how can the rest of your derivation from that point be valid if this initial step is not on ?? |
| New Reply |
| Thread Tools | |
Similar Threads for: On the nature of the "infinite" fall toward the EH
| Thread | Forum | Replies | ||
| In binary can we have a value with "deci" "centi" "mili" or more lower valued prefix? | Computers | 14 | ||
| 1-D Kinematics Problem/Free Fall. "A helicopter carrying Dr. Evil..." | Introductory Physics Homework | 1 | ||
| Nature of "Real" Applications Quantum Mechanics | Quantum Physics | 2 | ||
| Finding "a" and "b" in an infinite series limit comparison test | Calculus & Beyond Homework | 10 | ||
| The distance-dependent nature behind lorentz "time-transformation"... | Special & General Relativity | 5 | ||
