| New Reply |
Forces on ropes connected to a slanted ceiling |
Share Thread |
| Dec30-12, 07:05 AM | #1 |
Hey forum.
So I was posed the question whether the forces on two ropes will vary or not depending on if the ceiling from which they are hanging is slanted or not. Here's a picture depicting the scenario: ![]() I claim they'll equal 150 N respectively, independent of the ceiling slanting or not. But I am not sure how to motivate this (mathematically and/or conceptually). Do you guys have any idea? Picture-source: https://www.youtube.com/watch?v=hSQM0hoS6VE |
| Dec30-12, 07:18 AM | #2 |
Mentor
Pretend the top of the picture was covered up so you had no idea about what the ropes attached to. Would it change your solution?
Do you know how to solve this problem in the first place? Assume a horizontal ceiling, if it helps. (Consider torques acting on the rod the girl hangs from.) |
| Dec30-12, 08:14 AM | #3 |
| Dec30-12, 08:17 AM | #4 |
Mentor
| Dec30-12, 08:52 AM | #5 |
But, if do have to consider torque, I am not really sure how the calculation really goes; care to show? |
| Dec30-12, 01:27 PM | #6 |
SweatingBear
Is it the slant of the ceiling or the differing lengths of the two ropes that has you wondering? How does force transmit itself from one location on the rope to the next? Does the tension in a rope vary along its length? If the roof was so high that you could not tell whether the roof was slanted or not by just looking at it straight up to determine an incline, could you detemine the force at each end on the bar? |
| Dec30-12, 02:15 PM | #7 |
Cut the girl vertically in half and attach each half to each end of each rope and remove the horizontal rod that she hangs from. The tension in each rope is the same regardless of the slope of the roof assuming equal halves.
Does this help? Sorry for the gruesome picture above. |
| Dec30-12, 02:30 PM | #8 |
)Great explanation - works for me. |
| Dec30-12, 03:24 PM | #9 |
Concluding remark: Regardless of if the ceiling is slanted or not, the force on each rope is half of the persons weight i.e. 150 N (respectively). |
| Dec30-12, 03:41 PM | #10 |
Mentor
| Dec30-12, 11:34 PM | #11 |
| New Reply |
Similar discussions for: Forces on ropes connected to a slanted ceiling
| Thread | Forum | Replies | ||
| Tension problem dealing with 4 ropes and 2 weights (ropes oriented at different angle | Introductory Physics Homework | 10 | ||
| frictional forces between ropes | Introductory Physics Homework | 1 | ||
| Forces on ropes | Introductory Physics Homework | 13 | ||
| Cars, Ropes, Forces and Bisecting Angles... | Introductory Physics Homework | 2 | ||
| 3 objects connected by ropes (tension) | Introductory Physics Homework | 15 | ||
