New Reply
Relativistic RMS Speed
Share Thread Thread Tools
Jan3-13, 03:05 PM   #1
How can we restrict the RMS speed of molecules to comply with relativity?
They obviously can't go at or faster than the speed of light.
If you are dealing with particles inside of very hot stars for example you may get very high erroneous speeds.
[itex]v = \sqrt{\frac{3KT}{m}}[/itex]
How could we manipulate this equation?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Jan3-13, 03:12 PM   #2
Recognitions:
I am not familiar with the equation you gave. However, increasing energy (heating particles up) close to relativistic speeds leads to increase in m rather than v.
Jan3-13, 03:23 PM   #3
Yes that may have been a more appropriate question for me to ask in hopes of connecting relativity and kinetic gas theory
Jan3-13, 03:29 PM   #4
Mentor
Quote by Vodkacannon View Post
We don't.
Instead, we start from scratch and re-derive the Maxwell speed distribution using relativistic kinetic energy instead of non-relativistic kinetic energy. This appears to have what you are looking for:
The Maxwell Speed Distribution for Relativistic Speeds (PDF)
See equation 21 on page 4.
Jan3-13, 03:41 PM   #5
Quote by jtbell View Post
We don't.
Interesting. thanks. I had known about Maxwells Distribution laws before as it's in my AP textbook. I can see how the formula sort of resembles the plain old relativistic equations.
Jan3-13, 03:48 PM   #6
Recognitions:
Gold Membership Gold Member
We don't.
It's interesting that this makes no mention of the Maxwell-Juttner distribution, which should be the applicable distribution. Do you know if this analysis is consistent with that? At a glance, it doesn't look like it would be.
Jan3-13, 03:53 PM   #7
Astro/Cosmo 2012
Recognitions:
Retired Staff Staff Emeritus
Quote by mathman View Post
This is the relativistic mass convention, which is very old-fashioned. Physicists today use the convention that mass is invariant, so, e.g., rather that writing p=mv with an m that is a function of v, they write [itex]p=m\gamma v[/itex], where m is a constant.
Jan3-13, 04:58 PM   #8
Recognitions:
I could be wrong, but I think the formula given in this paper is incorrect. Basically he's taking the density of states to be uniform in velocity space with a sharp cutoff imposed at v=c.
The correct approach is to use a uniform density in momentum space. For nonrelativity it doesn't matter since p = mv is linear, but it does matter in our case. In momentum space there is no cutoff, one integrates over all p out to infinity.
Jan4-13, 04:00 PM   #9
Recognitions:
Quote by bcrowell View Post
Nitpicker - what would you call [itex]m\gamma [/itex]?
Jan4-13, 04:10 PM   #10
Recognitions:
m[itex]\gamma[/itex]
The reason I discourage calling it a mass is the temptation for those learning SR to substitute it into Newtonian formulas. There is only one common formula (momentum) for which this works.
F = m[itex]\gamma[/itex]a anyone?
KE = (1/2)m[itex]\gamma[/itex]v^2 anyone?
Another observation is that [itex]\gamma[/itex] is really part of the normalization of 4-velocity to be a unit 4-vector. The correct 4-force equation for constant mass particle is simply m * 4-acceleration.
Jan5-13, 02:20 PM   #11
Recognitions:
Quote by PAllen View Post
It may be old fashioned, but my understanding was that the total energy is mc2, which can be expanded as a series in v to get m0c2 +m0v2/2 + ... = rest mass energy + kinetic energy.
Jan5-13, 03:09 PM   #12
Recognitions:
But KE, exactly, = mc^2(γ-1) [m being rest mass] which is completely different from substituting mγ into the Newtonian formula, getting (1/2)mγv^2. The point is that there is only one relativistic analog of Newtonian kinematic formulas for which you can pretend mγ plays the role of mass. So thinking there is a general concept of relativistic mass which is analogous to the m in Newtonian formulas leads only to a large number of common errors
[edit: Thinking more, I see the main reason for the shift is the wide adoption of 4-vectors for SR. In this scheme you have mU. for 4-momentum; m is rest mass, U is 4 velocity. No mγ in sight (it is internal to the 4-velocity). Then, 4-force is naturally mA, using 4-acceleration; no nonsensical transverse and longitudinal relativistic mass as seen in some ancient relativity books.]
Jan7-13, 04:08 PM   #13
Recognitions:
The main point of the formulation I gave is that it is easy to see where the Newtonian KE comes from, since the correction term is ~ (v/c)2.
Jan9-13, 04:36 AM   #14
The reason I discourage calling it a mass is the temptation for those learning SR to substitute it into Newtonian formulas. There is only one common formula (momentum) for which this works.[..]
See http://math.ucr.edu/home/baez/physic...y/SR/mass.html for a balanced discussion but note one glitch: the FAQ ignores that the second law of Newton is in fact F~dp/dt. It works fine like that.
[..] [edit: Thinking more, I see the main reason for the shift is the wide adoption of 4-vectors for SR. [..]
Right. Notice that invariant mass and relativistic mass are alternative solutions to avoid the introduction of "longitudinal" and "transverse" mass concepts.
New Reply
Thread Tools
Similar Threads for: Relativistic RMS Speed
Thread Forum Replies
Speed of a Relativistic Particle? Introductory Physics Homework 1
Ender's Relativistic Speed Special & General Relativity 11
Speed of Pi Meson - Relativistic question Introductory Physics Homework 5
What happens after you travel at a relativistic speed Special & General Relativity 15
relativistic speed Advanced Physics Homework 4
