| New Reply |
Is the asymmetry mentioned in 1905 SR paper fully removed? |
Share Thread |
| Jan25-13, 03:15 AM | #35 |
Is the asymmetry mentioned in 1905 SR paper fully removed?Sugdub: "… in the "kinematics" part of his 1905 SR paper Einstein clearly referred to a change of directly observable physical quantities, namely space and time quantities." Einstein's SR paper: I-Kinematical part; §1 Definition of simultaneity.... "If at the point A of space there is a clock, an observer at A can determine the time values of events in the immediate proximity of A by finding the positions of the hands which are simultaneous with these events. If there is at the point B of space another clock in all respects resembling the one at A, it is possible for an observer at B to determine the time values of events in the immediate neighbourhood of B." I-Kinematical part; §2 On the relativity of times and Lengths … "By means of stationary clocks set up in the stationary system and synchronizing in accordance with §1 the observer ascertains at what points of the stationary system the two ends of the rod to be measured are located at a definite time. The distance between these two points, measured by the measuring-rod already employed, which in this case is at rest, is also a length which may be designated “the length of the rod." … "We imagine further that with each clock there is a moving observer, and that these observers apply to both clocks the criterion established in § 1 for the synchronization of two clocks." I-Kinematical part; §3 Theory of Transformation of Co-ordinates …. "We now imagine space to be measured from the stationary system K by means of the stationary measuring-rod, and also from the moving system k by means of the measuring-rod moving with it; ... Further, let the time t of the stationary system be determined for all points thereof at which there are clocks by means of light signals in the manner indicated in §1 …." Obviously Einstein refers to "observers" and measuring devices ("rods" and "clocks") in the Kinematical part of his paper and he compares two different experimental scenarios leading to different values of observable quantities. The root cause of this argument is that you were so far unable to read / admit that the "Kinematical" part refers to observable quantities whereas the "Electrodynamical" part exclusively refers to non-observable quantities. The same transformation cannot fit to both paradigms since Electrodynamics must deal with a change of reference frame whereas Kinematics cannot do so. Hence my question: what is the rationale for invoking SR and its Lorentz transformation for resolving the EM problem at stake? II-Electrodynamical part; §6 Transformation of the Maxwell-Hertz Equations for Empty Space...."If we apply to these equations the transformation developed in §3, by referring the electromagnetic processes to the system of co-ordinates there introduced, moving with the velocity v, we obtain the equations..." Capito? |
| Jan25-13, 07:47 AM | #36 |
Mentor
The two cases of that first paragraph's example are related by a boost. The Lorentz transform is a boost. Therefore it is reasonable to use the Lorentz transform to remove the asymmetry discussed there. If you want to discuss other scenarios that you believe are NOT related by a boost then I am glad to do so, but it is clear that the scenario in the first paragraph is a boost. Do you disagree about that specifically? |
| Jan28-13, 08:52 AM | #37 |
Whether Einstein actually succeeds is however disputable. Let's come back to the nature of the "asymmetry": the explanation given for the observed current appears to be non-symmetrical (an electric force on the one hand, an electromotive force on the other hand), whereas the problem to be resolved is defined in a fully symmetrical way (two symmetrical descriptions of the relative motion between the magnet and the conductor). So the "asymmetry" referred to by Einstein points to a logical anomaly, insofar a non-symmetrical conclusion (different causes for the current) cannot be inferred from fully symmetrical hypotheses. There are two ways to resolve this anomaly: either re-formulate the conclusion so that it becomes symmetrical, or re-formulate the hypotheses so that they contain an asymmetry which triggers the asymmetry in the conclusion. I can't see that any of these alternatives has been met. |
| Jan28-13, 04:29 PM | #38 |
| Jan28-13, 05:01 PM | #39 |
Mentor
Mathematical fact 1: Maxwell's equations are not invariant under Galilean transforms. This is an asymmetry. Mathematical fact 2: Maxwell's equations are invariant under the Lorentz transform. The asymmetry is resolved. |
| Jan28-13, 06:02 PM | #40 |
If the mathematical asymmetry were eliminated by making Maxwell's equations invariant under the Lorentz transform, there would be no point in Einstein instructing us to transform the field to the rest frame of the charge to determine the force on the charge, nor would there be any reason to assert that the electromagnetic force in other frames is an "auxiliary concept", rather than an asymmetry. |
| Jan29-13, 06:33 AM | #41 |
Mentor
| Jan29-13, 08:46 AM | #42 |
I'm actually reading through this at the moment, so I'll throw my hat in here for a second. Here's the summary of the paper's position after the derivation of the transformation rule between EM fields in the stationary and moving reference frames
After this the paper adds Einstein later states that "... [the] electric and magnetic forces do not exist independently of the state of motion of the system of co-ordinates." So you can't talk about the force on charge (in your frame) as being composed of bits of this or that. You must transform into the frame of the charge and measure fields and forces there(then presumably transform the force/acceleration back to your frame). He also says that this resolves the paradoxes/problems with Homopolar/Faraday generators. It's a very great pity that he didn't spell this out explicitly though. |
| Jan29-13, 09:15 AM | #43 |
Mentor
| Jan29-13, 03:05 PM | #44 |
Let's come back to the issue at stake. The electric theory assumes that the conductor is in absolute rest and its "v" parameter stands for the absolute velocity of the magnet. Conversely, the magnetic theory assumes that the magnet is in absolute rest and its "v" parameter stands for the absolute velocity of the charges alongside the x axis. Both expressions of the force cannot be physically reconciled by connecting their mathematical expression through a Lorentz transformation which assumes that neither the conductor nor the magnet is in absolute rest and that "v" stands for their relative velocity. The assignment of different "names" to the different definitions for the "v" parameter would make it obvious. Here we are dealing with different physical definitions for "v" which cannot be all valid at the same time. |
| Jan29-13, 03:18 PM | #45 |
Mentor
Honestly, I don't know where you are getting this garbage, but it does make some of your other statements make more sense. Garbage in, garbage out. |
| Jan29-13, 04:47 PM | #46 |
I'll sign out here. I did learn something, so I thank all who participated.
| Jan31-13, 03:26 AM | #47 |
The same for me. We had enough signs of misbehaviour under stress.
| Jan31-13, 06:43 AM | #48 |
Mentor
Anyway, if you ever wish to continue the conversation you are certainly welcome back. But I will continue to point out where your arguments fail. |
| New Reply |
Similar discussions for: Is the asymmetry mentioned in 1905 SR paper fully removed?
| Thread | Forum | Replies | ||
| Why does Einstein's 1905 SR paper contain Zero citations? | Special & General Relativity | 10 | ||
| Einstein's June 30 1905 paper - help please with the maths | Special & General Relativity | 23 | ||
| 1905 paper "Does the Inertia of a Body Depend Upon its Energy-Content? | Special & General Relativity | 6 | ||
| A New Translation & Reformatting of the 1905 SR Paper | General Physics | 2 | ||
