| New Reply |
Different Clock Rates Throughout Accelerating Spaceship |
Share Thread | Thread Tools |
| Feb6-13, 09:46 AM | #69 |
Different Clock Rates Throughout Accelerating Spaceship1) for uniform linear motion, gamma is purely "subjective" - nobody's clock is moving slower than anyone else's in a meaningful way. it is all wrapped up with planes of simultaneity. 2) for uniform circular motion, gamma gains a clear "objective" meaning - RF can use it to describe *all* of AO's time dilation, and AO can use the inverse to describe *average* time anti-dilation of RF. It is similar to the gravity situation where there are agreed differences in time dilations. 3) The next part is harder for me to work out - the linearly accelerating observer - how RF and AO can measure their relative clock speeds. I gather than RF can calculate AO's relative time dilation by simply integrating ever changing gamma with ever changing velocity? But to ask how AO determines RF's clock speed, this situation is neither the simple 'subjective' or 'objective' case above. |
| Feb6-13, 10:22 AM | #70 |
For AO, this simple example raises one of the SR concepts difficult to grasp on first encounter. This is the so called Rindler horizon. If you try to ask about how AO would model RF clocks by factoring out light delay using some simultaneity convention, you face the following observation: RF clocks that AO is accelerating away from appear to red shift until they disappear, at a fixed distance behind the AO. Any RF clock further away cannot be seen or communicate in any way with the AO, so mutual clock comparison is impossible. Note that there is a one way aspect to this (as for all horizons): any RF clock can eventually receive a signal from any point in AO's history; however, there is a last time, for every clock in RF, after which it cannot send any signals to AO. Visually, you can certainly say the case is more like your (1): any clock at rest in RF and AO's clock each eventually see the other clock freezing and red shifting to infinity. |
| Feb6-13, 10:37 AM | #71 |
For normal SR we can use gamma for both observers to determine that they see each other's clocks as ticking slower by gamma. This works for clocks they are passing or any other clocks in either frame.
I understand that it becomes more complex doing this between RF and AO for remote clocks, so I would just wish to focus on RF clocks being passed by the AO observer, all of which are deemed simultaneous and synchronized by RF. RF uses integrating gamma to watch AO's single clock continually slow down relative to the RF network of clocks as v and gamma increase. What does AO decide passing these RF clocks. How fast does this network of RF clocks tick? The same method? |
| Feb6-13, 11:12 AM | #72 |
To try to create an symmetric situation for AO, we need a configuration of co-accelerating clocks, with one RF clock going past them. For this, we have to decide the acceleration profile of each clock, and also how to synchronize them. For the latter, unfortunately, there is no preferred approach (what is special about inertially comoving clocks is that any reasonable synchronization procedure produces the same result; this is not true for a family of accelerating clocks. In particular, Einstein clock synch using light signals, and Born rigidity based simultaneity, disagree.) I urge you to focus on questions about what AO observes, and stop trying to treat AO as defining a frame of reference. |
| Feb6-13, 11:41 AM | #73 |
But now I realize I need to look back at the SR issue you brought up. However since I also determine at any moment using my network that gamma-adjusted clocks placed further back on along the moving frame are set later than clocks forward along the frame, that is a different effect. Do they cancel each other out? As a moving frame passes me, and I watch the counts of these different clocks in the frame, passing me, a different clock each time, do I see this time change at my own rate? |
| Feb6-13, 12:21 PM | #74 |
| Feb6-13, 01:31 PM | #75 |
| Feb6-13, 01:58 PM | #76 |
| Feb7-13, 05:30 PM | #77 |
More to the point, the OP asked about direct observations, not interpretations. If front and back experience same g force, then string between front and back will break. This is a fact. Similarly, if they compare clock rates by exchanging signals, the front clocks will be observed to be going faster, by both front and back rocket passengers. Again a simple fact. That is all that was asked - direct observations. |
| Feb7-13, 09:28 PM | #78 |
| Feb8-13, 07:30 AM | #79 |
It really is the case that aboard an accelerating rocket, things don't seem much different from a rocket hovering over the Earth, except that the variation of "gravity" with height is different in the two cases (although you have to have a really huge rocket to notice the difference in either case). |
| Feb10-13, 08:51 AM | #80 |
ok so the problem of AO's "frame"... RF can easily decide there is a grid of evenly-spaced meters and synchronized clocks using exchanges of light pulses. we can say that RF has no trouble assigning AO an x coordinate and measuring his even acceleration 'a', and clock speed related to AO's current gamma. what happens when AO attempts this... Will AO encounter any ambiguity determining an x coordinate of the RF observer at the origin? If AO can do this, what will he think of RF-origin's clock speed and 'acceleration' with regard to him? |
| Feb10-13, 10:50 AM | #81 |
While AO would have no difficulty making some choices to set up some coordinate system, the ambiguity means you can't give a single preferred answer to RF origin's clock speed - it depends on which choices you make for setting up the coordinate system. Note that any choice made by AO will have a different metric that RF. This means that gamma will not apply (gamma as a time dilation factor is a direct consequence of the inertial metric). Further, the standard SR Doppler formula will not apply. As an interesting aside, a common idealization of the 'rigid framework' coordinates (Fermi-Normal coordinates), and building simultaneity using Einstein's clock synch convention, produce quite different answers for the rate of RF clock (actually, they agree when the RF origin clock is coincident with AO; the further away this clock is, the more they disagree). |
| Feb10-13, 02:32 PM | #82 |
| Feb10-13, 03:02 PM | #83 |
In no way am I saying you can't set up coordinates - just that you can't go from there to talking about 'the' rate of a distant clock 'now' for an accelerated observer. You also can't use inertial frame formulas (like gamma). The approach I think you have in mind leads to AO coordinates with some nice properties for non-inertial motion with rapidly changing accelerations. Using two way light signals you simply define that if event e1 is reached by a signal you sent at t1 on your clock, and you got a return signal at t2, then you define that e1 is simultaneous to (1/2)(t2+t1) on your clock. Then define radial coordinate in polar type coordinates by c(t2-t1). Such coordinates have the following nice properties: - coordinate speed of light is c for radial paths from the origin - these coordinates cover larger regions of spacetime than many other accelerated coordinates - they behave 'smoothly' around sudden changes in acceleration (other common coordinates for accelerated observers do not). However, you also have to accept that coordinate distance fairly quickly diverges from ruler distance (either idealized, or approximate real rulers), where both are possible. For example, as defined above, someone at the bottom of the (accelerating) rocket using the above coordinates would get a slightly different result than using a tape measure along the length of the rocket. [If the rocket was coasting, these would always agree]. |
| Feb11-13, 05:16 PM | #84 |
| Feb11-13, 07:32 PM | #85 |
Back to the usenet rocket example, and related discussions, let's take the two rockets along x which RF finds to be identical in acceleration, velocity, click-rate.
It is said that the tail and head rocket observers can agree that their clocks are moving at different rates. This has some implication of a 'frame' that each has... So, there is some ambiguity regarding 'distance' and 'simultaneity' between them... At the least, each person/clock can see the other as subtending the same or similar visual arc, even if they cannot agree on the distance between them exactly... |
| New Reply |
| Tags |
| acceleration, clocks, relativity, time dilation |
| Thread Tools | |
Similar Threads for: Different Clock Rates Throughout Accelerating Spaceship
| Thread | Forum | Replies | ||
| accelerating spaceship paradox | Special & General Relativity | 3 | ||
| about the accelerating spaceship | Special & General Relativity | 17 | ||
| Co-accelerating spaceships (Bell's Spaceship Paradox), how does this occur in SR? | Special & General Relativity | 44 | ||
| Math of an accelerating spaceship | Special & General Relativity | 7 | ||
| Spaceship accelerating inside a Black Hole | Special & General Relativity | 7 | ||
