Time slowing down for someone traveling just under the speed of light
The discussion revolves around the concept of time dilation as experienced by two spaceships traveling at relativistic speeds, particularly just under the speed of light. Participants explore the implications of relative motion on aging and time perception, addressing scenarios where one ship accelerates and the effects of their respective frames of reference.
  • Some participants assert that time dilation is mutual; each ship perceives the other's clock as ticking more slowly due to their relative velocities.
  • Others question the relevance of which ship fired its engines, suggesting that the act of acceleration is crucial in determining the effects of time dilation.
  • A participant proposes a scenario where both ships fire their engines, leading to confusion about which ship ages more slowly.
  • One participant emphasizes that if a spaceship travels in a circle and returns to Earth, the situation is not symmetric, leading to differential aging rather than simple time dilation.
  • Another participant introduces the twin paradox, distinguishing between two scenarios: one where two observers are in relative motion and another where they reunite after traveling, which involves acceleration.
  • Some participants express difficulty in visualizing the concepts, suggesting resources like the Usenet Physics FAQ to aid understanding.
Participants generally agree that time dilation is relative and that both ships perceive time differently. However, there is no consensus on the implications of acceleration and the conditions under which differential aging occurs, leading to multiple competing views.
The discussion highlights the complexity of relativistic effects, particularly regarding the definitions of simultaneity and the impact of acceleration on aging. The nuances of the twin paradox and the conditions under which time dilation is observed remain unresolved.
This discussion may be of interest to individuals exploring concepts in special relativity, particularly those curious about the implications of time dilation and the twin paradox in relativistic physics.
mycotheology
Lets say ship 1 is traveling just under the speed of light so time slows down for the crew and the age less quickly than the stationary crew in ship 2. Relative to the crew in ship 1, the crew of ship 2 are traveling at just under the speed of light, so time moves slower for them and they should be the ones aging more slowly. Which is it?
mycotheology said:
Which is it?
It's both. Time and time dilation are relative, not absolute.
mycotheology said:
Which is it?
The one that fired its engines, which you didn't specify.
What if they both fired their engines. Anyway, it doesn't matter unless they get back together. There is no sense in which you can pick which one is 'really' slower if they just travel away from each other, possibly exchanging signals.
Time dilation between inertial frames is mutual - according to each reference system it is the clock at rest in the other system that is ticking more slowly. This disagreement is due to disagreement about who is "in rest" and related things such as distant simultaneity.
See for example the elaborations here: http://en.wikipedia.org/wiki/Time_d...relative_velocity_symmetric_between_observers
Agreed.
I read that if a spaceship is traveling at a really high speed, let's say just under lightspeed, that the crew will age more slowly than us earthlings because time slows down when they are traveling at such a high speed. What doesn't make sense to me is that relative to the spaceships crew, its the Earth that is traveling at an extremely high speed so its the earthlings clocks that slow down. Let's say the spaceship travels around in a circle and returns to Earth 15 years later. Will the earthlings have aged more than the crew of the spaceship? From the spaceships perspective, it should be the earthlings that aged slower.
Isn't it irrelevant who fired the engine? I meant to imply that spaceship 1 fired the engine and took off at just under light speed relative to spaceship 2. The crew of spaceship 2 will observe that spaceship 1s clocks have slowed and the length of the spaceship has contracted. Whats confusing me is that relative to the ship 1 (the fast moving ship), ship 2 is the one that's traveling at just under lightspeed. So does time dilation occur for both ship 1 and ship 2? I'm a full on visual thinker so this is a real mind boggler for me. Trying to come up with a way to visualise this concept.
No, if the spaceship travels in a circle the situation is not symmetric. This becomes a case of differential aging (not symmetric) rather than time dilation. The spaceship traveling in a circle is not inertial, and cannot pretend they are at rest in an inertial frame and use the normal SR formulas. The spaceship traveling in a circle will age less.
You might try the Usenet Physics FAQ entry on the twin paradox:
http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_paradox.html
In particular, the Doppler Shift Analysis and the Spacetime Diagram Analysis.
The Doppler Shift Analysis focuses on what each twin actually sees, in the sense of the actual light signals each twin receives from the other; this might help in visualizing since it removes all the abstractions about "time dilation" and just focuses on the actual observations.
The Spacetime Diagram Analysis gives a sort of "God's eye view" of what is happening and how it all fits together globally.
That would mean that nothing happened to the rocket that fired its engine, but the other rocket that did nothing accelerated.
Ah, so its called the twin paradox. Thanks a lot. Hopefully those FAQs will resolve it for me. The wiki page looks good too.
Be careful. There are two deceptively similar but interestingly different paradoxes.
1) The one your raised in your first post: When they're moving relative to one another, which one is "really" slow? The answer is "neither - they both see time passing more slowly for the other and there is no contradiction because of relativity of simultaneity".
2) The twin paradox: If they start out in the same place at the same time with the same age, travel for a while, then rejoin at a later time (which means that one of them has necessarily accelerated or free-fallen through a fairly exciting gravitational field) so that they can directly compare their age, which one is younger? The answer here is that one of them will be unambiguously younger.
By whose clock(s)? Theirs, Earth's, or yours?
See Misner, Charles W.; Thorne, Kip S.; Wheeler, John Archibald (1973), Gravitation, San Francisco: W. H. Freeman, ISBN 978-0-7167-0344-0.
  • · Replies 18 ·
  • · Replies 23 ·
  • · Replies 25 ·
  • · Replies 36 ·
11K
  • · Replies 93 ·
