| New Reply |
Connected set |
Share Thread | Thread Tools |
| Feb22-13, 01:07 AM | #1 |
Connected set
Is a singleton a connected set.
I am thinking it is because it is not in the intersection of two disjoint sets. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Feb22-13, 01:14 AM | #2 |
Yes. An equivalent condition is that a set is disconnected if there exists a non - empty proper clopen subset contained in that set. The only clopen subsets of a singleton are the singleton and the empty set.
| Feb22-13, 12:20 PM | #3 |
| Feb22-13, 12:36 PM | #4 |
Connected set |
| Feb22-13, 12:44 PM | #5 |
If you finished that one, maybe you can try to find some variations yourself such as connected and path connected, but not locally connected. |
| Feb22-13, 01:00 PM | #6 |
| Feb22-13, 10:57 PM | #7 |
Thanks |
| Feb22-13, 10:59 PM | #8 |
| Feb22-13, 11:04 PM | #9 |
BTW what is the difference between a Topological Space and a Metric Space?
| Feb22-13, 11:09 PM | #10 |
| Feb22-13, 11:18 PM | #11 |
| Feb22-13, 11:27 PM | #12 |
Please check my attachment. Notice that ##E = E_1 \bigcup E_2## but neither proper subset is clopen. Further even if we consider ##E_1## by itself which is connected, it is not open. |
| Feb22-13, 11:33 PM | #13 |
In the diagram, you state that both [itex]E_{1},E_{2}[/itex] are closed. Do you know the definition of a closed subset? We define [itex]A\subseteq X[/itex] to be closed if [itex]X\setminus A[/itex] is open in [itex]X[/itex]. Therefore if [itex]E = E_{1}\cup E_{2}[/itex], [itex]E_{1},E_{2}[/itex] are closed, and [itex]E_{1}\cap E_{2} = \varnothing [/itex] we can easily conclude that [itex]E \setminus E_{1} = E_{2}[/itex] is open and [itex]E \setminus E_{2} = E_{1}[/itex] is also open so they are both clopen. Keep in mind that your sets [itex]E, E_{1}, E_{2}[/itex] are proper subsets of [itex]\mathbb{R}^{2}[/itex] therefore when detecting whether [itex]E[/itex] is connected or not using open sets you must do so with respect to the subspace topology on [itex]E[/itex]. This answers your last point as well: every set is open in itself by definition of a topology.
| Feb22-13, 11:41 PM | #14 |
Now, whether [itex]E_1[/itex] is closed in the subspace [itex]X[/itex] depends entirely how we define the topology on [itex]X[/itex]. Since you're comfortable with metrics, we can just restrict the metric from [itex]\mathbb{R}^2[/itex] to [itex]X[/itex]. So for [itex]x,y\in X[/itex], we set [itex]d_X(x,y)=d_{\mathbb{R}^2}(x,y)[/itex]. Now [itex]X[/itex] forms a metric space. Can you see that [itex]E_1[/itex] is open in [itex]X[/itex]?? Try the sequential definition of open maybe: can you see that if a sequence converges to a point in [itex]E_1[/itex], then the sequence has to be in [itex]E_1[/itex] eventually? The trick is that the sequence is not a sequence in [itex]\mathbb{R}^2[/itex], but in [itex]X[/itex]. So the elements of the sequence are either in [itex]E_1[/itex] or [itex]E_2[/itex]. |
| Feb22-13, 11:44 PM | #15 |
| Feb22-13, 11:51 PM | #16 |
| Feb25-13, 12:36 PM | #17 |
Recognitions:
oddly enough, the somewhat unintuitive definition which follows is easily shown equivalent to other definitions, but much easier to use in proofs.
A space X is connected if and only if every continuous map f:X-->{0,1} is constant. Hence X is disconnected iff there is a continuous surjection X-->{0,1}. Equivalently (exercise), a set X is disconnected iff X is the union of two non empty disjoint open sets. Certainly every map on a one point set is constant. For the topologists sine curve it is easy to show a continuous map f is constant on the curvy part (if you know that (0,1) is connected), and then f also has the same value on the point (0,0), since that is in the closure of the curvy part. I invite you to try this version on any connectedness proof you like, such as the continuous image of a connected set is connected, or the closure of a connected set is connected, or path connected implies connected.... Also a union of connected sets with non empty intersection is connected. Also a finite union of connected sets A1,...An such that each of A1,...,An-1 meets the next one is connected. These take a little effort by the open set definition (even Dieudonne' spends half a page on these last two in Foundations of Modern Analysis), but are all trivial by the constant function definition. |
| New Reply |
| Thread Tools | |
Similar Threads for: Connected set
| Thread | Forum | Replies | ||
| Is a convex subset of a connected space connected? | Topology and Analysis | 2 | ||
| Connected vs. Path Connected Sets | Differential Geometry | 6 | ||
| Capacitors Connected, Disconnected, and Connected Again | Introductory Physics Homework | 1 | ||
| An open connected set is path(polygon) connected | Calculus | 1 | ||
| Is every subspace of a connected space connected? | General Math | 12 | ||
