Calculating the magnetic field in solenoid
When calculating the magnetic field in a solenoid, the formula B = μnI applies, where n is the turn density defined as N/L. The discussion centers on whether L should be the length of the solenoid or the mean length of the core when using a steel core with a small wrapped coil. It is clarified that L should refer to the length of the core surrounded by the coil, as the magnetic flux through the core is not affected by the turn density. This distinction is crucial for accurate calculations of the magnetic field. The consensus is that using the length of the core is the correct approach.
rp8308
Just need a question cleared up.
If I had a coil wrapped around a core, and I was calculating the magnetic field of the solenoid using
B = μnI
where n = N/L, I is current and μ is the permeability of my material
N being the number of turns in the coil, and L being the length of the solenoid if there was an air core. Now if I had a steel core, for example, and the core was a large circular shape such that the coil itself only wrapped around a small amount of the core. Would the length L be the length of the solenoid still? (because its defined as turn density) or would it be the length that the magnetic flux takes through the whole core and therefore be the mean length of the core? (much larger than the length of the solenoid).
Cheers
ok I am pretty sure its the length of core because flux through the core won't change with the density of turns, but could do with someone just confirming this... I hate when i confuse myself
If you meant to say L is the length of the coil, then yes I agree.
Edit: By 'length of the coil' I mean the length of the core which is surrounded by coil. (Not the actual length of the coil which is wrapping around it).
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
