Optimal Methods for Factoring Equations
  • Thread starter Thread starter uperkurk
Factoring equations can yield multiple valid forms, but the preferred method often emphasizes simplicity and clarity, similar to reducing fractions. The example provided, 3a + 6a^2 + 15a^3 = 3a(1 + 2a + 5a^2), is correct, yet Wolfram Alpha may present alternative factorizations, such as 3a(5a^2 + 2a + 1), which can be more concise. Users are encouraged to consider the layout and format of their input when using computational tools, as this can affect the output. While there may not be a single "best" way to factor, clarity and adherence to mathematical conventions are generally favored. Ultimately, understanding the underlying principles of factoring is essential for effective problem-solving.
uperkurk
I'm factoring some equations and the way I do it seems correct and Wolfram often lists my way of factoring it but it's like the 5th or 6th one down.
Just wondering if it's like fractions where the best answer is the lowest the fraction can be reduced to.
For example I say that:
3a+6a^2+15a^3 = 3a(1+2a+5a^2)
Wolfram doesn't list my way of factoring it when I input the equation to be factored, but I know it's correct because when I input my factored form instead of the original problem, it lists the original problem as a solution.
Any particular way to be factoring these? Like highest exponenets first, not using 1 ect?
Mathematics news on Phys.org
That is simply the "distributive law": a(b+ c)= ab+ ac.
I am puzzled by your saying this. When I put "3a+ 6a^3+ 15a^3" into Wolfram alpha, it gives me quite a lot of information- such as the real root, 0, and two complex roots, and one thing it tells me is that it can also be written as "3a(5a^2+ 2a+ 1)".
Mathematica 8 gives your answer with either of the following inputs: Factor[3 x + 6 x^2 + 15 x^3] or Factor[3x + 6x^2 + 15x^3]. What version or format are you using? Note "Factor" must begin with a capital F and the expression must be put within square brackets, etc.
What I mean is which is prefered?
http://www4c.wolframalpha.com/Calculate/MSP/MSP28661e08b41157f5gd7f000040c225hah823i3e2?MSPStoreType=image/gif&s=44&w=117.&h=18.
http://www4c.wolframalpha.com/Calculate/MSP/MSP6901egf7iaae09973c30000473gfi1489a2g5df?MSPStoreType=image/gif&s=62&w=120.&h=18.
http://www4c.wolframalpha.com/Calculate/MSP/MSP37931i702gba3e39i9350000348g19dci0927517?MSPStoreType=image/gif&s=16&w=116.&h=22.
Are these all completely 100% equivalent or would an examiner prefer to see a certain layout?
I don't know what an examiner would prefer, but the layout you used in the original post is both my preferred way and what Mathematical used. I don't see a bunch of choices like you suggested. Mathematica 8 only gave me 3 a ( 1 + 2 a + 5 a^2)!
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
