Using MgSO4 for Producing H2SO4?
  • Thread starter Thread starter JeffEvarts
The discussion centers on the chemical reactions involving phosphorus and copper sulfate, specifically the formation of copper phosphide and sulfuric acid. The initial inquiry explores whether magnesium or calcium sulfates could replace copper sulfate in a similar reaction, but responses indicate that this is unlikely due to the stability of copper phosphide, which does not react with water. The conversation also addresses the potential for mixing oxalic acid and magnesium sulfate to produce sulfuric acid and magnesium oxalate. It is noted that while a weaker acid typically cannot produce a stronger one, metathesis could allow for this if the weaker acid's anion is precipitated out, although concentrated solutions of the stronger acid may not be achievable. The discussion highlights the importance of understanding chemical stability and the nuances of acid-base reactions.
JeffEvarts
Background: Phosphorus + Copper Sulfate:
I know that the following (unbalanced) reaction proceeds from left to right from this reference, possibly with the formation of elemental copper as well.
P4 + CuSO4 + H2O -> Cu3P + H3PO4 + H2SO4.​
This reference (which gets the stochiometry and formula slightly different) agrees.
The net-net is that Phosphorus, Water, and M1SO4 produce (very dilute) H2SO4.
Question One: Would this work with an alkali such as Magnesium or Calcium Sulfates in place of the copper sulfate?
P4 + MgSO4 + H2O -> Mg3P2 + H3PO4 + H2SO4?​
Question Two: It seems unlikely that a weaker acid could make a stronger one, but metathesis is a powerful ally. Can you really mix oxalic acid and magnesium sulfate to produce sulfuric acid and magnesium oxalate? Anyone tried it IRL?
Thanks for your thoughts,
-Jeff
Chemistry news on Phys.org
Mg and Ca are not alkali metals. You are one column in teh periodic table over from the alkali metals (Li, Na, K, etc.)
Highly unlikely. Copper phosphide is very stable and doesn't react with water, which can't be said about other phosphides.
If you can remove weaker acid anion by precipitating it out of the solution, you can be left with a stronger acid, precipitation being the driving force of the process. It won't let you make concentrated solutions of the stronger acid, but is definitely possible.
And yet
In response to my statement:
Steamking responded:
That is true, but I just referred to them as alkalis. I believe the column group containing Ca, Mg, etc. is called the alkaline Earth metals. Or maybe that's not what they're called anymore. It has been a long time since I was in class studying.
-Jeff
Q1: That's a shame
Q2: That's actually pretty cool.
Again I find myself thanking you, Borek.
-Jeff
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
