What would the products of photolysis degredation of PET plastic be?
  • Thread starter Thread starter lostminty
    pet Plastic
The discussion centers on the issue of taint in plastic drinking bottles caused by UV degradation of PET plastic when exposed to sunlight. Participants express interest in finding a catalyst that could render PET byproducts non-water soluble or enable their evaporation, aiming to mitigate the degradation while ensuring that the plastic does not leach into the contents of the bottles. The challenge lies in balancing the degradation process with the need for a long shelf life and safe consumption. There is a recognition that while the exterior surface of the bottle may be less critical, treating the interior poses significant challenges due to its geometry. Relevant research links on the physico-chemical modifications of PET and UV effects are shared to support the discussion.
lostminty
Interested in this because plastic drinking bottles have a taint to them when left out in the sun. I gather its from UV degredation of the PET plastic.
I'd like to find a catalyst that would allow the PET byproducts to be non water soluble/sequester or even evaporate.
Chemistry news on Phys.org
One has to balance that degradation against the desire for non-leaching of the plastic into the contents and long shelf life.
The exterior surface could be less critical than the interior surface, but it's difficult to treat the interior in a bottle given the geometry.
Here's some research on PET and UV.
Physico-chemical modifications of the DBD and UV irradiation treatments on the PET and PET+TiO2 films
http://134.147.160.41/ispcdocs/ispc16/CostPapers/497.pdf
See also
http://en.wikipedia.org/wiki/Ultraviolet#Degradation_of_polymers.2C_pigments_and_dyes
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
