Geometry Question About A Sphere
  • Thread starter Thread starter bodykey
    Geometry Sphere
To determine the number of dots within a sphere with a radius of 100 meters, one must consider the spacing of the dots at 50 meters apart. The volume of the sphere is 4,188,790.20 cubic meters, and to find the number of dots, the volume should be divided by the volume of a smaller sphere with a radius of 25 meters, calculated using the formula (4/3)π(25)^3. This approach accounts for the spatial arrangement of the dots, as the initial method of dividing by 50 was incorrect due to confusion between cubic and square meters. The discussion highlights the complexities of sphere packing, relevant in various mathematical and practical applications.
bodykey
If I had a sphere with a radius of 100 meters, a diameter of 200 meters, a volume of 4,188,790.20 square meters, and I wanted to place within this sphere a single dot (one dimensional so it doesn't take up any extra space and there is no displacement --if you're thinking in terms of water--), and I need to have one dot every 50 meters, what is the formula I would use to determine that?
I thought it was just divide the volume by the number 50, but that comes out with a large number like 83,775.80, which seems insanely huge for something with just a diameter of 100 meters. What am I doing wrong here?
This isn't a homework question, just something I'm trying to throw together for an experiment I'm doing in my personal time.
Mathematics news on Phys.org
I presume you are trying to fill the volume of the sphere. You need to divide by 125000 (503) not 50. I got 33.
Note volume is cubic meters, not square meters.
Likes 1 person
Ah ok...that makes SO much more sense! lol
Since the "dots" are to be 50 m. apart, each dot could be thought of as the center of a sphere 25 m. in radius, so you need to divide the volume of the large sphere by (4/3)##\pi (25)^3##.
This wouldn't give you the exact number of points inside the sphere, as it doesn't take into account how the small spheres are arranged inside the larger one. One of the areas of mathematics deals with sphere packing inside of geometric objects. Mathematicians who work in this area consider such simple examples as how oranges are stacked in a pyramidal pile on up to how spheres can be packed in much higher dimensions, which has application in the area of digital communications.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
