What are some nonreactive electrolyte solutions?
  • Thread starter Thread starter Xtensity
The discussion centers on the need for an appropriate electrolyte for the electrochemical reduction of an alcohol without causing adverse reactions. The user typically employs basic sulfuric acid but recognizes its incompatibility with the alcohol due to potential violent reactions. The goal is to find a suitable electrolyte that is either soluble in alcohol or water, acts as a conductor, and remains inert during the reduction process. Suggestions include using sodium sulfate or other inert salts that are stable and do not undergo oxidation or reduction in the electrochemical cell. The user is focused on maintaining a clean process, as they plan to perform an acid-base extraction afterward to remove the electrolyte.
Xtensity
I have an alcohol that I need to hydrogenate/reduce and I would like to do it electrochemically. The catholyte solutions I am used to using are basic sulfuric acid, but that would not work in this case as it would cause a violent reaction with the alcohol. The alcohol could be reduced with an acid but I would prefer to do it electrochemically as it is much cleaner. I need some sort of electrolyte, either soluble in alcohol or water, that can act as a conductor in this cell, but not react with the alcohol that I am reducing. Following the reduction is the usual workout with an acid-base extraction so there's no worry about difficulty in removing the elctrolyte.
Any ideas?
Chemistry news on Phys.org
Sodium sulfate? Basically any inert salt that won't easily get oxidized nor reduced.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
