Effects of Pressure on Water: Explained
  • Thread starter Thread starter dhulke
    Pressure Water
Increasing pressure on water raises its boiling point and temperature, as boiling occurs when vapor pressure equals ambient pressure. At sea level, water boils at 100°C, but at higher altitudes with lower pressure, the boiling point decreases. This principle is fundamental to air conditioning, where gas is compressed, heating it, then cooled before expansion, which lowers its temperature. Regarding the confusion about deodorant bottles, while compression can heat the contents, the effect is temporary and does not mean the bottle remains hot. Additionally, applying pressure to water does not easily turn it into ice due to the unique crystal structure of ice, which makes it less dense than liquid water, complicating the phase transition.
dhulke
Hi!
So I'm pretty confused about the effects that pressure has on water. If I increase pressure, I increase the boiling point. Likewise, if I increase pressure I increase temperature. How's that?
That's the way air-conditioning works, by increasing pressure on one side and decreasing pressure on the other this way one side gets hotter and the other gets colder. But if by increasing pressure, temperature increases, shouldn't my deodorant bottle be hot?
And if I have water and I apply pressure, shouldn't it turn to ice at some point? I'm so confused... Can anybody help me?
Chemistry news on Phys.org
You are confused about how air conditioning works. See this article (vapor compression cycle):
http://en.wikipedia.org/wiki/Refrigeration#Vapor-compression_cycle
A liquid boils when its vapor pressure equals or exceeds the ambient pressure acting on the free surface. Water boils at 100 C at sea level when the atmospheric pressure is 1 atmosphere. If you go to the top of a tall mountain, where the atmospheric pressure is less than 1 atmosphere, the boiling point of water is reduced below 100 C.
Welcome to PF!
Anything that is hot can be made cold again: the effect isn't permanent. If it was, air conditioning wouldn't work. So with air conditioning, it goes like this:
1. The gas is compressed and gets hot.
2. The gas is run through a heat exchanger to cool it (and some liquefies).
3. The gas is allowed to expand, cooling it.
You'd expect that, yes, but ice has a crystal structure that makes it less dense than water. So it isn't that easy.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
