What does speed motor spec mean?
  • Thread starter Thread starter doubled
    Mean Motor Speed
The speed specification of 0.18 sec/60 means that the motor takes 0.18 seconds to rotate 60 degrees. This indicates the motor's responsiveness at a voltage of 4.8V. It is not a measure of degrees per second, which would be a different calculation. Understanding this distinction is crucial for evaluating motor performance. The specification reflects the maximum speed achievable at the specified voltage.
doubled
The link to the motor is here: http://www.savoxusa.com/Savox_SC1256TG_Digital_Servo_p/savsc1256tg.htm
In the description tab, it lists all the specs. My question is in regards to the speed specs.
e.g., "Speed(@4.8V sec/60): .18"
I don't understand what that is saying. 0.18 what?
0.18 sec per 60 degrees? i.e., 0.18 deg per 1 second?
I'm assuming that's the max @ that voltage or the average?
Thanks in advance for any help.
0.18 seconds per 60 degrees of rotation. By the way, it's a good idea always to try to imagine these rates. Try to imagine 0.18 degrees per second and you'll find it's not too likely, and not at all equivalent to 0.18 seconds per 60 degrees!
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
