Tungsten Wire Resistance Test | 12Vdc | Fluke Clamp Meter
The discussion revolves around measuring the resistance of tungsten wire when heated with a 12V DC supply. Despite expectations that resistance would increase with temperature, the measurements show no change in resistance between the cool and glowing hot states. Participants suggest potential issues with measurement techniques, particularly the accuracy of current readings using a clamp meter and the impact of contact resistance at connections. It is noted that Ohm's Law is not applicable in this scenario due to varying temperatures affecting resistance. Proper measurement practices, such as avoiding contact resistance and ensuring simultaneous voltage and current readings, are emphasized for accurate results.
magmash
Hi guys
I have been playing around with a piece of tungsten wire by supplying it with 12Vdc and measuring the current draw to see how much the resistance changes when the wire is glowing hot. while doing this i am not getting any change in the resistance, the wire has the same resistance when its cool (no power supplied), and when its Glowing hot (supplied with power), shouldn't the resistance change when the temperature rise in the wire ? .
I am using Ohms law to calculate the resistance while the tungsten wire is being supplied with power
R=V/I, i am measuring the voltage with a Multimeter and the current with a Clamp meter (Fluke).
M Quack said:
Yes, the resistance should increase. Maybe the current reading is off? DC currents are difficult to measure with a current clamp.
http://hypertextbook.com/facts/2004/DeannaStewart.shtml
http://en.wikipedia.org/wiki/Current_clamp
I have had no problem with measuring DC currents, did the same experiment with a light bulb and got what i expected, higher resistance.
Does the resistance get higher with the temperature on every conductor Copper, Aluminum, ect ?
magmash said:
Hi guys
To be more accurate, you can't be "Using Ohm's Law" in fact, because Ohm's Law requires the temperature to be constant. What you are doing is to use the Formula R = V/I, which is the definition of the Resistance. In this case, you will be measuring different values of resistance as the temperature varies so Ohm's Law is not part of what you are doing. Diodes and other devices are definitely not 'Ohmic resistances' yet you can still measure V/I and get a value for a resistance.
This is not 'the Maths Police' talking. I am just pointing our that confusion can arrive when a term like Ohm's Law is used in the wrong context. People can make assumptions and fall down a hole.
magmash said:
Hi guys
What are you supplying power with? A battery or a 12v power supply?
http://personal.tcu.edu/zerda/manual/lab22.htm has a graph of the variation of resistivity of tungsten with temperature. It covers a temperature range that you won't achieve but you can see the variation between room temperature (300K) and dull red heat (1000K). That's something you should easily achieve.
There may be something 'not optimal' (i.e. wrong) with your measuring arrangement. You need to be careful about where you measure the PD across the wire. For instance, do not include the connections to the power supply as there may be contact resistance where the current comes on and off the wire. Measure PD between two points near each end of the wire and also measure the current and volts simultaneously. If you are using the same multimeter for each measurement, the resistance of the meter and connections can be affecting the current and this can affect the voltage, with and without the meter.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
