Double Urination: Causes and Effects
  • Thread starter Thread starter Dadface
The discussion centers around the phenomenon of needing to urinate shortly after an initial voiding, often referred to as "mini wee." Participants speculate on the causes, with one suggesting that it may be due to urine stored in the ureters dripping into the bladder as it empties. Others note that post-void urine retention is generally normal, with less than 50 ml considered acceptable. Concerns about abnormal retention volumes are mentioned, indicating potential underlying issues unrelated to kidney function. Some participants share personal experiences, attributing the sensation to bladder elasticity and muscle contraction after emptying. There are also mentions of potential age-related bladder issues that may require medical attention in the future. Overall, while the phenomenon is common and often benign, there is an acknowledgment that persistent or excessive symptoms should be discussed with a healthcare professional.
Dadface
Does anyone else experience the following:
You are busting for a wee and eventually you get to the toilet and away you go.Heaven. A short time later,sometimes just seconds,you need another mini wee.
I think its due to the bladder getting completely filled and being emptied on the first wee. The mini wee is due to urine being stored in the ureters and dripping into the bladder as it empties. Is there anything to my idea?
Thanks
Biology news on Phys.org
Yes, annoying isn't it? I always wondered if the kidneys were storing urine when back pressure from the bladder increases.
Thanks
Post-void urine retention, to some degree, is normal- AFAIK, less than 50 ml is considered 'normal'. Abnormal retention volumes can be due to a variety of problems (unrelated to kidney function). If you are concerned, you should see a doctor.
No concerns at all. Have been experiencing this for as long as I can remember. I just wondered about the cause.
@dadface. My personal perception is a function of bladder elasticity. In other words, when it is really full, upon emptying, it is slack for a few moments. In a matter of seconds, as the muscle contracts, it then finds it has fluid to void. Filling the ureter would have minimal, to drops of fluid. Backing into the kidneys would cause renal failure, or malfunction. My opinion is bladder wall malfunction,which will grow more serious with age needing a cath to get the rest.
I've been reading a bunch of articles in this month's Scientific American on Alzheimer's and ran across this article in a web feed that I subscribe to. The SA articles that I've read so far have touched on issues with the blood-brain barrier but this appears to be a novel approach to the problem - fix the exit ramp and the brain clears out the plaques. https://www.sciencealert.com/new-alzheimers-treatment-clears-plaques-from-brains-of-mice-within-hours The original paper: Rapid amyloid-β...
