Is CH3OH a better notation for methanol than CH4O?
  • Thread starter Thread starter soothsayer
    Reaction
The discussion revolves around the feasibility of the chemical reaction NaOCH3 + CO2 + H2O → NaHCO3 + CH4O. While the equation is balanced, the actual reaction may not proceed as written due to the instability of CH4O (methanol) and the potential for alternative products like C2H4. The reaction's success depends on various factors, including energetics and kinetics, with methanol being more stable than initially perceived. The presence of water and the pH of the solution play crucial roles in determining the reaction's pathway and products. Overall, while the reaction could theoretically occur, practical yields of CH4O would likely be minimal, with more stable products favored.
soothsayer
The equation is balanced, but would it actually work?
Or would the reaction simply ignore the water in the left hand side and go,
2NaOCH3 + CO2 → Na2CO3 + H2O + C2H4
Or perhaps a little of both? I'm just starting to teach myself Chemistry, so any insight would be great!
Chemistry news on Phys.org
You'd have to do the energetics - but at room temp, reactions are often done in solution ... i.e. the water does not take part.
In general - not every balanced chemical equation will actually happen.
Well, at least a little bit of both, in the sense that every correctly balanced chemical reaction has to go to equilibrium, but if one of your products is really energetically unstable, you could have an incredibly low equilibrium constant for that reaction, in which case you may want to treat that reaction as negligible - you would certainly not be able to say it is the "main reaction". The other issue is kinetics - if one of the products is really kinetically unstable, the production of that product will be really slow and the consumption of any of that product which is produced would be really fast.
CH4O looks to me like it would probably be both very energetically unstable and very kinetically unstable. So, you might get some of it - but that amount would be ridiculously small (I would think) and take a really long time to form. I don't know if C2H4 is that likely to come out of this either but it is probably more likely - so you would get more of it, but still very little, and it would still take a while to form though it would be far faster than the formation of CH4O.
AFAIK in chemistry we do not hear of C making more than 4 bonds and H rarely makes more than 1 - but without doing one of these we cannot have CH4O.
Does CH3OH look better?
What you have written out here is an overall reaction which requires several steps and equilibria. Ignoring the carbon dioxide and just looking at the sodium methoxide and protons, you are describing the protonation of sodium methoxide which is very favorable. The pKa of methanol (a very weak acid) is about 16, so any kind of acid in solution (even the water) will lead to an appreciable amount of methanol.
For example, NaOCH3 + H+ → Na+ + CH3OH
would be favorable in most circumstances unless the pH of the solution is extremely high. Consider that if the pH is ~16 (the pKa of methanol) you will have a 1:1 ratio of methoxide:methanol.
The reaction you have written above is slightly more complicated because the acid would be carbonic acid (and even the bicarbonate because methoxide is such a strong base) which depends on the equilibrium between carbon dioxide in the gas phase, carbon dioxide dissolved in the solution, carbonic acid, bicarbonate and, finally, carbonate. This all really depends on the conditions but in theory (and the short answer) is, yes, it should happen.
This reaction is more complicated because you are essentially dimerizing (kind of, I don't really know the technical name for such a reaction) methanol/methoxide. My organic chemistry is rusty (and my text is at my folks' place because I don't have room in the tiny hovel that is my apartment) so I don't want to comment too much about this process but my gut tells me that this would not be the main product(s) of the system.
CH4O is methanol, a pretty stable molecule. We keep it in large jugs in the flammables closet without having to worry too much about it disappearing. The notation (CH4O) can be confusing if you don't have a good "chemistry vocabulary" which is why I prefer to write it as CH3OH. The latter helps people "see" the connectivity a little bit better.
... that was dumb.
Yup, sorry. For some reason I visualized the C atom having more than 4 bonds, even though I've seen CH4O used for methanol various times.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
