Why is silver acetate sort of insoluble?
  • Thread starter Thread starter McSpongy
    Silver Sort
The discussion centers on the unique behavior of the acetate ion in forming water-soluble salts with various cations, highlighting the exception of silver(I) ion, which leads to less soluble silver acetate. The conversation explores why silver is an outlier in this context and questions whether similar behavior occurs with other anions like methanoate or propanoate. Additionally, there is a consideration of whether a solution of silver acetate could produce silver hydroxide due to the acetate ion's basic properties. It is noted that the reaction between silver acetate and water does not occur spontaneously, as the acetate ion is a weaker base compared to hydroxide ions, leading to the conclusion that acetic acid may form instead. The discussion hints at the potential for a color change in the solution due to the interactions between silver ions and hydroxide ions.
McSpongy
One of my first solubility lessons regarded the great ability of the acetate ion to form a water-soluble salt with any other cation.
One of my most recent lessons regarded the great ability of the silver(I) ion to override the previous rule.
Why is silver the only ion that makes a not-as-soluble acetate? Would it happen also with methanoate or propanoate? I searched for those two and couldn't find them.
Furthermore, would a solution of silver acetate eventually form silver hydroxide because of the basic properties of the acetate ion?
Chemistry news on Phys.org
I can't answer the question about why silver makes so many insoluble ionic compounds.
But I do know that the reaction AgOAc + H2O → AgOH + HOAc will not occur spontaneously. OH- is a stronger base than OAc- and HOAc is a stronger acid than H2O, so the preferred reaction is very much in the opposite direction.
I supposed the acetate would partially form acetic acid, as the weak base it is, and some of the generated hydroxide ions would find their way into a happy ionic marriage with some of the aqueous silver, and the solution would have a growing brown color.
It happened in my head.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
