Electric Field inside the spherical shell
The electric field inside a hollow spherical shell with charge is zero, regardless of whether there is charge inside the shell. If the shell is charged and there is also charge inside, the electric field outside the shell can be determined by the total charge present. Gauss' law indicates that the electric flux through a Gaussian surface relates to the net enclosed charge, confirming that the field inside remains zero. The discussion emphasizes the importance of understanding charge distribution and the implications of Gauss' law in electrostatics.
Hardik Batra
As we know there are charge on spherical shell then electrical field inside the shell will be zero.
1) If there is no charge on the spherical shell, but has charge inside the shell then what is the electric field inside and outside the shell?
2) If there is charge on the spherical shell and also have charge inside the shell then what is the electric field inside and outside the shell?
Is this spherical shell a conductor and is it hollow or solid?
Do you have a textbook that covers Gauss' law?
It's conductor and it is hollow.
What can you say about the distribution of the charge?
Gauss' law states that the flux through a gaussian surface is the net charge enclosed, over the permittivity of free space, what does that tell you about the field inside the sphere?
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
