Why can't a closed conductor have excess charge inside?
In a closed conductor, excess charge cannot exist inside in a static situation; any charge present resides on the surface. The absence of an electric field within the conductor prevents net current and charge redistribution. Gauss's law indicates that the integral of the electric field over any closed surface inside the conductor is zero, implying no net charge is enclosed. Consequently, the charge density must be zero throughout the interior of the conductor. This behavior is consistent across various conductor shapes, including hollow and solid forms.
tecnics
the interior of a closed conductor can have no excess charges in the static situation ...and even if they have excess charge ...then these charge resides on the surface of the conductor...not inside it...
can anyone explain to me...y a closed conductor behaves so?
wht connection does it have with gauss law for electrostatics?
the conductor can be either..a hollow or solid cylinder or ...even a solid wire..
If there was an electric field inside the conductor, then there would be a net current and hence redistribution of charge. This tells us that there can be no electric field inside the conductor in the static situation. Gauss law relates the integral of the field over a surface to the charge enclosed by the surface. If we pick any surface within the conductor, the integral is going to be zero since the field is. Thus, there can be no net charge enclosed by the surface. Since this is true for any closed surface in the conductor, the charge density must be zero everywhere.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
