What Provides the Centripetal Force for Circular Motion?
In summary, according to the author, the only force acting on a rotating body is gravity. The moment of net force is zero, but how? and what do you think?
dreamz25
If a body is rotating in a circular orbit then what is the moment of net force acting on it about the axis of rotation?
What do you think?
0 but how?
dreamz25 said:
0 but how?
Which way does the net force act? What's the definition of torque?
in gravitation i have read that...
the force on a planet towards radius is given by
GMm/r^2
and the force which acts radially outwards is
Mv^2/r
so don't know where the net force acts... !:{
and torque = F X R
if the direction of net force is towards center then it makes and angle of
180 degrees which gives ex. torque = 0 as sin 180 = 0 ...
but just tell me about the direction of net external force...! (Thanks in advance)
GMm/r^2
OK.
Mv^2/r
There is no outward force.
The only force acting is gravity.
and torque = F X R
Good.
How then do we derive the velocity of a plannet in circular orbit?
when we equate both of them...
v = root[GM/R]...!
By applying Newton's 2nd law. The only force is gravity. Set that equal to mass X the centripetal acceleration.
No need for any mysterious outward force.
ok.. so u mean both of them acts towards the centre... Right?
since the force on the particle by the center equals GMm/R^2
and also by Newton's second law of motion, F = ma so, F = m x centripetal acceleration (which is towards the center) = m x v^2/r
and thus we get, v = root[GM/r] ...?
Your math is right, I think you just have a conceptual problem. When you say "both of them acts towards the centre", my question to you is, both of what?
We're not talking about two distinct forces here. Gravity IS the centripetal force in this situation. Centripetal force is always just a requirement for circular motion. It has to be provided by something real, like gravity, or tension in a string. Without something like this to provide (or act as) a centripetal force, there simply won't be any circular motion.
got ur point... but i too meant the same...
i m nt differentiating the two force i just meant the different expressions for a single force..
the force between them is GMm/r^2 which also equals mv^2/r (the centripetal force which acts towards the center to keep the body rotating in a circular path) and thus gets the formula derived...
wonderful lines... thanks..!
FAQ: What Provides the Centripetal Force for Circular Motion?
1. What is torque?
Torque is a measure of the rotational force applied to an object. It is commonly measured in units of newton-meters (N·m) or pound-feet (lb-ft).
2. How is torque calculated?
Torque is calculated by multiplying the force applied to an object by the distance from the pivot point to the point where the force is applied. The formula for torque is T = F * d, where T is torque, F is the force, and d is the distance.
3. How is torque different from force?
Force is a vector quantity that measures the push or pull on an object, while torque is a vector quantity that measures the rotational force applied to an object. In simpler terms, torque is a type of force that causes an object to rotate.
4. What are some real-life examples of torque?
Examples of torque in everyday life include opening a door, turning a steering wheel, or using a wrench to tighten a bolt. In sports, throwing a ball or swinging a golf club also involve the use of torque.
5. How does torque relate to the concept of work?
Work is defined as the force applied to an object multiplied by the distance the object moves in the direction of the force. Torque is a type of force, so it is directly related to the concept of work. The more torque that is applied to an object, the more work is done to move or rotate that object.
