How do the moon's & earth's orbital planes intersect?
In summary, the Earth's orbit around the sun is in a plane A and the moon's orbit around the Earth is in a plane B. These planes intersect at an angle of roughly 5 degrees, with the Moon's orbit inclined to the ecliptic, which is defined as the plane of the Earth's orbit. The orientation of this intersection rotates one complete revolution every 18+ years, while the argument of perigee rotates one complete revolution every ~9 years. This can be viewed from the ecliptic, with the Earth's orbital plane appearing as a horizontal line through the center of the Earth.
-Job-
Consider the Earth's orbit around the sun to be in a plane A and the moon's orbit around the Earth to be in a plane B. How do these planes intersect? Are they parallel or perpendicular? At what angle do they intersect themselves? Does the angle stay the same, or does it vary.
Astronomy news on Phys.org
The Moon's orbit is inclined roughly 5 degrees to the ecliptic. The ecliptic is defined to be the plane of the Earth's orbit. The orientation rotates one complete revolution every 18+ years. The argument of perigee rotates one complete revolution every ~9 years. Click the link for an animation. This is viewed from the ecliptic, so if it were shown, the Earth's orbital plane would be a horizontal line through the center of the Earth.
http://www.orbitsimulator.com/gravity/saros.GIF
1. How do the moon's and earth's orbital planes intersect?
The moon's orbital plane is tilted at an angle of about 5 degrees compared to the earth's orbital plane. This means that the moon's orbit around the earth is not directly aligned with the earth's orbit around the sun. However, the two planes do intersect at two points called the "nodes".
2. What causes the moon's and earth's orbital planes to intersect?
The moon's orbital plane is tilted due to gravitational interactions with other celestial bodies during its formation. This tilt is maintained due to the moon's relatively small mass compared to the earth's, which prevents it from being pulled into alignment with the earth's orbital plane.
3. How often do the moon's and earth's orbital planes intersect?
The moon's and earth's orbital planes intersect twice per orbit, once when the moon is moving from the southern to the northern hemisphere and again when it is moving from the northern to the southern hemisphere. This occurs approximately every 29.5 days, which is the length of the lunar month.
4. What happens at the nodes where the moon's and earth's orbital planes intersect?
At the nodes, the moon's orbital plane crosses the earth's orbital plane, allowing for a solar or lunar eclipse to occur. A solar eclipse occurs when the moon passes between the sun and the earth, blocking the sun's light from reaching the earth. A lunar eclipse occurs when the earth passes between the sun and the moon, casting a shadow on the moon.
5. Is there any significance to the intersection of the moon's and earth's orbital planes?
Yes, the intersection of the two orbital planes plays a crucial role in the occurrence of eclipses. It also affects the moon's position in the sky, as it can appear higher or lower depending on its location in relation to the nodes. Additionally, the tilt of the moon's orbital plane is thought to have played a role in shaping the moon's surface and its geological history.
  • Astronomy and Astrophysics
