Question about wavefunctions and their Hilbert space
In summary, the conversation is about the relationship between the wave function and Hilbert space in quantum mechanics. The wave function is the position representation of the state vector and it realizes the Hilbert space of states as the space of square-integrable functions. The measurement operator and energy operator are both examples of complete sets of commuting observables that can be used to expand the wave function. There are also subtleties involved in understanding the concept of an eigenfunction in a Hilbert space setting. The dimension of the space can vary depending on the context, and in some cases, an infinite dimensional space is required. The conversation also touches on the Rigged Hilbert Space formalism as a solution to certain issues in the usual Hilbert space formulation
Tosh5457
134
28
Maybe someone here can explain me something I never understood in QM: The wave function lives in the Hilbert space spanned by the measurement operator. Is there any mathematical relation of those spaces with each other?
I don't know what a measurement operator might be.
The wave function of a single particle in non-relativistic QT is the position representation of the state vector, i.e., it realizes the Hilbert space of states as the space of square-integrable functions, [itex]\mathrm{L}^2[\mathbb{R}^3].[/itex]
Since all separable Hilbert spaces are equivalent this is just a special realization of the abstract Hilbert space as known from the representation free Dirac formulation of quantum theory.
For example the energy operator
They are the same space, but different basis result from different complete sets of commuting observables.
Often, but not always, the energy operator by itself forms a complete commuting set of observables eg the hydrogen atom.
Regardless you can expand them in other observables like momentum or position if you like. By definition a wavefunction is a state expanded in terms position eigenvectors.
There are all sorts of subtleties associated with the above such as exactly what an eigenfunction of position is in a Hilbert space setting, you really need to go to a Rigged Hilbert space. But that is is basically it.
Thanks
Bill
Thanks
Bill
If they're the same space then it's only a dimension 2 space? How can that be, that a finite dimension space have an infinite number of elements that are orthogonal to each other?
Exactly in what context do you think the space has dimension 2?
Usually the eigenvectors of the energy operator is countably infinite.
Thanks
Bill
Thanks
Bill
I mean the space generated by the eigenvectors of the spin operator (up or down).
Sure - but at the same time such objects have position so an infinite dimensional Hilbert space is required for that. You consider it described by the superposition two wave-functions each residing in an infinite dimensional space one for up and one for down. The space of the linear combination of two such functions is itself infinite dimensional. Its just in some experimental set-ups the position is irrelevant so you only need a two dimensional space to analyse it.
Just as an aside the usual Hilbert space formulation has issues with things like Dirac delta functions and waves of infinite extent. One way out of the difficulty is the Rigged Hilbert Space formalism and in that view you consider the fundamental states for be finite dimensional but of unknowen dimension. However that is a whole new discussion. Start a new thread about it if you are interested.
Thanks
Bill
Likes 1 person
Thanks
Bill
Ok thanks for the explanation :smile:
1. What is a wavefunction?
A wavefunction is a mathematical description of the quantum state of a particle or system. It describes the probability amplitude of finding the particle in a certain state or location.
2. What is the Hilbert space associated with a wavefunction?
The Hilbert space is a mathematical concept that represents the set of all possible states that a system can be in. In quantum mechanics, the Hilbert space associated with a wavefunction is the space in which the wavefunction exists and evolves.
3. How are wavefunctions and Hilbert space related?
Wavefunctions are elements of the Hilbert space, meaning they are vectors in the space that represent the possible states of a system. The Hilbert space provides a mathematical framework for understanding the behavior and evolution of wavefunctions.
4. What is the significance of the square of the wavefunction?
The square of the wavefunction represents the probability density of finding a particle in a particular state. This means that the higher the value of the square of the wavefunction, the higher the probability of finding the particle in that state.
5. How does measurement affect the wavefunction and its Hilbert space?
Measurement causes the wavefunction to collapse into a specific state, changing its value and affecting the Hilbert space. This is known as the collapse of the wavefunction and is a fundamental concept in quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
