MaTHFRo
- 7
I'm developing a game for the iPhone, and I have a situation where I have a graphic that the user can drag around the screen and there are some buttons the user can push to both rotate it and enlarge it. The graphic is located within a UIView, which is just a rectangular shape that fits tightly around it.
The thing I'm having trouble with is rotating the graphic, and then translating it so it fits within the UIView correctly. When the user pushes the button to rotate, the first thing I'm doing is calculating the correct size the UIView frame needs to be to fit the rotated object. Then I do the following:
It makes sense to me that in order to translate the object back to the upper left corner (0,0), i have to subtract the new size of the frame width and height value, minus the non rotated images width and height, and that should give me the translation I need. Yet it's not working, do I have the correct order of operations?
Any help would be appreciated.
Code:
- (CGAffineTransform) transform
CGAffineTransform transform = CGAffineTransformIdentity;
transform = CGAffineTransformRotate(transform, (M_PI * self.graphicRotationAngle) / 180);
transform = CGAffineTransformScale(transform, self.graphicSize.width / self.graphic.size.width, self.graphicSize.height / self.graphic.size.height);
transform = CGAffineTransformTranslate(transform, self.graphicSize.width - self.frame.size.width, self.graphicSize.height - self.frame.size.height);
return transform;
