kartikwat
- 49
What is voltage and how to look at it intellectually?
kartikwat said:What is voltage and how to look at it intellectually?
kartikwat said:See,when battery is connected in circuits,based on my reading battery creates potential difference which start the charge to move. when the charge reaches capacitor in series what happens after that is creating a trouble
Drakkith said:I believe it is the buildup of the electric field in the capacitor. When you first connect the battery the capacitor is uncharged and acts like a short. Therefore it has very little voltage drop across it. As the plates charge the electric field builds up, requiring more work to move each charge and increasing the voltage drop across the capacitor. Someone correct me if I'm wrong.
kartikwat said:Yes you are saying right and what causes potential drop when charge passes through capacitor
Drakkith said:What's mica?
kartikwat said:@drakkith what happens if we introduce mica between the plates of capacitor (1)when the voltage supply remain connected(2)after the supply was disconnected
CWatters said:Individual charges do not pass through a capacitor. Charge arrives on one plate and repels like charges from the other plate. You end up with a different charge on each plate. It's this that causes a voltage to appear between the plates.
UltrafastPED said:Then I recommend a text like Purcell:
https://www.amazon.com/dp/0070049084/?tag=pfamazon01-20
When taught, it is a full semester course. Of course there are other texts, but this one is well suited to self-study, and is widely available. Requires a working knowledge of calculus.
DiracPool said:Are you just recommending Volume 2? What about Volume 1? Is this it?
https://www.amazon.com/dp/1107014026/?tag=pfamazon01-20
jtbell said:Let's make an analogy, by first talking about gravity instead of electricity.
Suppose we have a 1 kg object resting on the ground. We lift it to a height of h = 2 m and hold it stationary there. We have to do work against the gravitational force: W = Fh = mgh = (1 kg)(9.8 m/s2)(2 m) = 19.6 J. We say the object now has 19.6 J of gravitational potential energy with respect to the ground. (I hope you've already studied potential energy in mechanics so this is just a review for you!)
An object with a mass of 2 kg at that height would have twice as much potential energy, 39.2 J. The potential energy of an object at a given height depends on its mass. However, we can say that any object at a height of 2 m has 19.6 J of potential energy per kg of mass. We can say that a location 2 m above the ground has a gravitational potential (note I didn't say "energy") of 19.6 J/kg. If we wanted to give the unit "J/kg" a name, we might call it a "gravolt." Any object placed at that height has gravitational potential energy equal to its mass times the gravitational potential ("gravoltage") at that location.
Now imagine that instead of a gravitational field, we have an electric field E in the downwards direction with a magnitude of 9.8 N/coulomb; and an object with +1 coulomb of charge. To lift the object to a certain height, we have to do work against the electrical force: W = Fh = qEh. The rest of the discussion is the same as above, except that we rename:
mass --> charge (and kg --> coulomb)
gravitational potential energy --> electric potential energy
gravitational potential --> electric potential
"gravoltage" --> voltage (J/kg --> J/coulomb = volt)
Drakkith said:That's a complicated issue that's probably best left until you know more about electronics.
kartikwat said:But in this case where is electrical potential energy 0
1. Introduction
The electrostatic potential between the Moon surface and space is a key parameter that is fundamental for lunar science and human exploration on the Moon.
Many investigations of electric potential and associated electric fields have been conducted theoretically and experimentally from the surface and orbits using solar wind plasma since the Apollo era...
In summary,
high energy electron flux results in -400 V potential in the nightside of the Moon.
In the dayside, due to the photoelectron emission the surface tend to charge positively with +5–+20 V, while near the magnetic anomaly, potential more than +100 V is expected.
Voltage is the measure of electric potential energy per unit charge. It is the force that drives electric current through a circuit.
Voltage is measured in units of volts (V) using a voltmeter. It can also be calculated by dividing the electric potential energy by the amount of charge.
Voltage and current are directly proportional. This means that as voltage increases, so does current, and vice versa.
There are two main types of voltage: direct current (DC) and alternating current (AC). DC voltage remains constant over time, while AC voltage changes direction periodically.
Looking at voltage intellectually involves understanding the underlying principles and concepts behind it, such as electric potential energy, charge, and resistance. It also involves being able to apply mathematical formulas and laws, such as Ohm's Law, to analyze and solve problems related to voltage.
