Calculating Torque of sphere resting on an inclined plane
In summary, if you have a sphere with mass m and radius r, resting on an inclined plane with angle \theta. What is the torque on the sphere due to gravity pull?If you draw a neatly labeled freebody diagram, you will see that the force component of weight along the incline (downhill) is mg\sin\theta. Now, this force acts through the mass center so it has a zero torque contribution about the CM. On the other hand (assuming of course that the incline doesn't translate) the friction force equal to f does not act through the mass center so it has a torque about the mass center which tends to increase the rotational velocity of the body (draw arrows to
candyshot
If I have a sphere with mass m and radius r, resting on an inclined plane with angle [tex]\theta[/tex]. What is the torque on the sphere due to gravity pull?
I know that the force that pulls the sphere down the plane is [tex]mg *\sin \theta[/tex] and the (static) frictional force is [tex]-\mu_s * mg \cos \theta[/tex].
If we can assume the sphere does not slip, how does one calculate the torque that the frictional force exerts on the sphere?
Im also interested in how to calculcate the total acceleration of the sphere.
/CandyShot
If you draw a neatly labeled freebody diagram, you will see that the force component of weight along the incline (downhill) is [itex]mg\sin\theta[/itex]. Now, this force acts through the mass center so it has a zero torque contribution about the CM. On the other hand (assuming of course that the incline doesn't translate) the friction force equal to f does not act through the mass center so it has a torque about the mass center which tends to increase the rotational velocity of the body (draw arrows to convince yourself that this is true).
For a formal solution, consider [itex](i',j',k')[/itex] unit vectors along the incline, perpendicular to it ([itex]k' = i' X j'[/itex]). Resolve the forces and the vector [itex]\vec{r}[/itex] from the CM to the point of application of friction force and compute the torque due to this force by using [itex]\tau = \vec{r}X\vec{F}[/itex].
For the total acceleration you need to write 2 dynamic equations: one for translation of the center of mass (as you would write for a block sliding down an incline) and one for rotation.
Now it is important to make a distinction between rolling and slipping. The formula for friction force you have used can be applied only when slipping is given to occur. If rolling without slipping occurs then the the velocity of the point of contact of the body is zero. In this case you cannot use [itex]f = \mu mg\cos\theta[/itex] and must not substitute any value of f. f will enter the dynamic equation for rotation and also the translational equation. Eliminate f to get the relationship between the mass, theta and acceleration.
Okey, thanks for that.
/Candyshot
/Candyshot
I discovered a major mistake in my post and have edited it. Please read the post all over again. Sorry for the inconvenience.
1. What is torque and how is it calculated?
Torque is a measure of the force that causes an object to rotate. It is calculated by multiplying the force applied to an object by the distance from the pivot point to the point where the force is applied.
2. How do you calculate the torque of a sphere resting on an inclined plane?
To calculate the torque of a sphere resting on an inclined plane, you will need to know the weight of the sphere and the angle of the incline. The torque can be calculated by multiplying the weight of the sphere by the length of the lever arm, which is the distance from the center of the sphere to the point where the weight is acting.
3. What is the relationship between torque and the angle of the inclined plane?
The torque of a sphere resting on an inclined plane increases as the angle of the incline increases. This is because the lever arm, or the distance from the center of the sphere to the point where the weight is acting, becomes longer as the angle increases. This results in a greater torque being applied to the sphere.
4. Can the torque of a sphere on an inclined plane be negative?
Yes, the torque of a sphere on an inclined plane can be negative. This occurs when the force applied to the sphere is acting in the opposite direction of the motion of the sphere. In this case, the torque is calculated as a negative value.
5. How does the mass of the sphere affect the torque on an inclined plane?
The mass of the sphere does not directly affect the torque on an inclined plane. The torque is primarily determined by the weight of the sphere and the angle of the incline. However, a heavier sphere may require a larger force to move it, resulting in a larger torque being applied.
