How Does Placement of Lead Affect the Buoyancy of a Wood Block?
In summary: This means that the buoyant force (Fb) is less and the equation will be satisfied at a lower mass of lead.
tigers4
24
A block of wood has a mass of 3.84 kg and a density of 598 kg/m3. It is to be loaded with lead so that it will float in water with 0.89 of its volume immersed. The density of lead is 1.13 104 kg/m3.
a)What mass of lead is needed if the lead is on top of the wood?
b)What mass of lead is needed if the lead is attached below the wood?
Fb=MG
mg=.89Fb
I don't really know where to begin, .89Fb=mg. but I am confused on how to use density of the wood or the lead to help solve the equation? Any ideas on how to start off the problem?
You know that the goal is to have 0.89 of the volume of wood underwater. Why not start by figuring out what the weight of the block of wood is, its volume, and how much of that volume will be below water. From there you should be able to tell what the buoyant force is (due to displaced water). Compare with the weight of the block.
d=m/v, so v=m/d.
3.84kg/598kg/m^3=.00642m^3=Vwood
.89v is under water, so the volume of displaced water=.89Vwood.
(density of displaced fluid)(V of displaced fluid)g=buoyancy force
.89*buoyancy force=(Mwood+Mlead)g?
tigers4 said:
d=m/v, so v=m/d.
...and you were doing so well...
In your final line, why are you multiplying the buoyancy force by 0.89? You've already calculated the buoyancy given that 0.89 of the wood's volume is submersed.
Time to put some numbers to the calculations.
What is the weight of the block (Newtons)?
What is the force due to buoyancy (Newtons)?
Is there a difference? If so, what is it and what's to be done about it?
(.89*.00642m^3)*(1000kg/m^3)=(3.84+m)
m=1.874kg
Why would it be different if the lead was on the bottom of the wood?
m=1.874kg
Because when it's below the wood the lead will also displace some water -- essentially it weighs less underwater.
Related to How Does Placement of Lead Affect the Buoyancy of a Wood Block?
1. What is buoyancy?
Buoyancy is the upward force exerted on an object by a fluid (such as water) that opposes the weight of the object. It is the principle that allows objects to float in water.
2. How is buoyancy calculated?
Buoyancy is calculated using Archimedes' principle, which states that the buoyant force on an object is equal to the weight of the fluid that the object displaces. This can be calculated by finding the weight of the fluid displaced by the object and multiplying it by the acceleration due to gravity.
3. What factors affect buoyancy?
The factors that affect buoyancy include the weight and density of the object, the density of the fluid, and the volume of the object that is submerged in the fluid. Objects with a lower density than the fluid will float, while objects with a higher density will sink.
4. How does the shape of an object affect its buoyancy?
The shape of an object affects its buoyancy because it determines the amount of fluid that the object displaces. Objects with a larger volume and a lower density will have more buoyant force and will float more easily than objects with a smaller volume and a higher density.
5. Can objects float in any fluid?
Objects can float in any fluid as long as the fluid's density is greater than the object's density. For example, objects will float in water because water has a density of 1 g/cm³, while objects will sink in oil because oil has a lower density of 0.92 g/cm³.
