Inconsistent forms of the metric in a uniform field
In summary, there are two methods for writing down the metric in a uniform field, and they disagree in their higher-order terms. This discrepancy is due to an implied choice of coordinates that is different in the two cases. It is also possible that there is no single metric that satisfies all the desired properties for a uniform field, such as being flat, producing a relative time dilation independent of height, and being indeterminate for determining height by local measurements.
  • #71
Altabeh said:
This of course does not occur for flat spacetimes for which all Christoffel symbols vanish!
This is incorrect. For example, the Rindler coordinates, with [itex]ds^2=(1+ax)^2dt^2-dx^2[/itex], give [itex]\Gamma\indices{^x_{tt}}=-a(1+ax)[/itex] and [itex]\Gamma\indices{^t_{xt}}=a(1+ax)[/itex], but the spacetime is flat.
  • #72
bcrowell said:
I don't think it totally works as a uniform field, because an observer hovering at a fixed location relative to the lattice you described can release a test particle from rest, and the acceleration of the test particle is [itex]-a(1+ax)[/itex]. This isn't constant, so the field isn't uniform.
Hi Ben. I think the accelerating grid in #68 is uniform from the point of view that you can pick any point on the grid at random at any random time and the local acceleration would be a. Because you can pick any random time this means that simultaneity is less of an issue as you can pick any plane of simultaneity you like and the accelerometers will all be reading the same. On the other hand, any individual observer on the lattice will consider the other observers at rest with the lattice to be accelerating away from them in the x direction so if we have a notion of distance on the lattice that keeps all the observers at rest with some artificial coordinate system then the apparent acceleration of free falling test particles might come out different from the calculation you give.
bcrowell said:
I don't think there is any metric in GR that can be called a uniform field and that satisfies every criterion you could put on a wish list. They all have certain undesirable properties. But anyway this is the undesirable property of this particular metric.
I would agree there is no real gravitational field that is equivalent to the accelerating latice and maybe the reason GR can not produce a metric that can be called a uniform field is that GR concerns itself with real gravitational fields generated by masses. Not sure about that though.
Anyway, do you agree about my conclusions for the accelerated lattice in #68 about the coffee grounds and specifically about who measures what?
kev said:
[tex]d\tau^2 = (1+ax)^2 dt^2 - dx^2 -dy^2 -dz^2 [/tex]
Where x and [itex]d\tau[/itex] are measured in S and dt, dx, dy and dz are measured in the accelerating frame.
Also, I said:
kev said:
while transverse distances (y and z) remain constant according to the accelerating grid observers (ruler or radar) and the y,z measurements are measured to be the same according to both the accelerated and non accelerated observers. (No transverse length contraction).
I think it would be fair to add that the radar transverse distance starts to differ from the transverse ruler distance over larger distances and this disagreement of radar distance from ruler distance appears to be a characteristic of any accelerating field.
bcrowell said:
The whole notion of a gravitational field is frame-dependent. If you're looking for a metric that in some sense embodies a uniform field with a particular value of g, then all you can hope for is a metric that accomplishes that in one particular set of coordinates. Those are the coordinates you use to write down the line element.
I agree that would be ideal, but it would appear the text are using "mixed coordinates". For example the FAQ on the relativistic rocket gives the the time dilation factor as (1+ ad) and makes it clear that a is measured in the accelerating frame (proper acceleration and distance d is measured in the non accelerating frame, so two different frames in one equation. It is also obvious by inspection that dx, dy and dz are not measured in the non accelerating frame because if they were, there would be no acceleration or time dilation when those values are set to zero.
  • #73
I just noticed that earlier in the week someone (who wants to remain anonymous) sent me some very detailed and helpful information on this topic via PM. I thought it might be helpful to pass on some of the general ideas. Any mistakes in summarizing his info is purely my fault, not his.
There is a family of metrics called the Weyl vacuums, which are of the form
[tex]ds^2 = -\exp(2u) \; dt^2 + \exp(2\,(v-u)) \; (dz^2+r^2) + \exp(-2u) \; r^2 \; d\phi^2 \qquad .[/tex]
According to him, the metrics most commonly referred to as candidates for the GR version of a uniform field are: two special cases of the Weyl vacuum; the Rindler coordinates, which can be expressed as a special case of the Weyl vacuum; and the Petrov metric. The Weyl vacua, unlike the Petrov metric, are static. Although the Einstein field equations are nonlinear, there is a certain way of superimposing Weyl vacua in a nonlinear way that provides new solutions. In some cases you get strange artifacts called "struts," which are things that act like rigid rods but that don't have any gravitational mass. Although some of the Weyl vacua can be described in simple geometric terms, e.g., as the field of a line of mass, that is actually kind of misleading, because the interpretation of the spatial coordinates isn't what you'd think based on the description.
Re atyy's #2, he says that the Weyl vacuum for u=az is a vacuum solution, but it's not the same vacuum solution as the one atyy proposed.
  • #74
1- What can be inferred about this: "This of course does not occur for flat spacetimes for which all Christoffel symbols vanish!"?
I said that if all Christoffel symbols vanish, then for that spacetime all particles accelerate simultaneously from every observer's point of view without knowing where they are at when observing particles! This sentence doesn't imply that, for example, for other four dimensional flat spacetimes whose Christoffel symbols do not vanish, there is no such thing as simultaneity of accelerations!
2- That spacetime you are in love with, :tongue2:, of course cannot have simultaneity for all particles, except for those that are instantaneously at rest according to an observer being at rest or a co-moving one!
3- I think you didn't read my post at all! Only skimmed some parts of it! But I enjoy reading all posts first then if there was something that can hit the spot I'd be glad to share it with you!
AB
  • #75
Oh God! This time bcrowell and I are on the same page!
I guess you don't mean that line element is coordinate-dependent, do you?
That doesn't mean that there are no frame-independent properties that you should hope for. In particular, I think it's desirable for the scalar curvature to be constant, and for the metric to be vacuum solution. Both the Rindler coordinates and the Petrov spacetime satisfy these criteria.
As far as I can tell, every vacuum solution of Einstein field equations is a Ricci-flat spacetime! So every vacuum solution implies the vanishing of curvature scalar!
AB
  • #76
I'm sorry, but Ben is right! At different points of your grid, the position is a matter of importance to any kind of observer except for the instantaneous co-moving ones whose observations don't affect the spacetime to admit a uniform gravitational field! Nevertheless, the uniform gravitational field does only locally exist and GR has no such thing to stand for as a general solution or something!
True.
It unfortunately is not correct! If it is, it will destroy your last conclusion concerning the non-existence of uniform gravitational fields globally!
So do I!
AB
  • #77
Ah, thanks for the correction. It would be more interesting to talk about having other curvature invariants that were constant, e.g., the Kretschmann scalar. I played around with a few of these in Maxima, and found that the Kretschmann scalar does vanish identically for the Petrov metric. That implies that the scalar invariant [itex]C^{abcd}C_{abcd}[/itex] constructed from the Weyl tensor also vanishes identically.
  • #78
Hi
For a conformally flat spacetime, if the Ricci tensor vanishes, then the spacetime is flat. So the KS is also zero iff the Ricci tensor vanishes for conformally flat spacetimes! But, in general, the Ricci-flatness does not imply KS is zero!
Could you provide me with some available links that I can understand what exactly this Petrov metric is?
AB
  • #79
I played around a little with the geodesic equations in the Petrov metric. Suppose you restrict yourself to a fixed z, and for convenience take an observer at an r such that [itex]\cos\sqrt{3}r=1[/itex], which means that the timelike coordinate is t. For a particle released at rest, the geodesic equations become
[tex]
\ddot{t}=0
[/tex]
[tex]
\ddot{\phi}=0
[/tex]
[tex]
\ddot{r}=-\frac{1}{2}e^r \dot{t}^2
[/tex]
where dots mean differentiation with respect to the affine parameter. If you take the affine parameter to be the particle's proper time, then [itex]\dot{t}=e^{-r/2}[/itex] initially, and the particle accelerates toward lower values of r with a proper acceleration that is independent of r. If you go to a place where [itex]\cos\sqrt{3}r=-1[/itex], the timelike coordinate is again t, but I think the direction of time is reversed here as compared with at the place where [itex]\cos\sqrt{3}r=+1[/itex]. Here the particle accelerates toward higher values of r. This seems to match up with what the Gibbons and Gielen paper describes about the geodesics: they oscillate back and forth in r.
So in this sense the Petrov metric seems to be a better realization of the uniform gravitational field than the Rindler coordinates, because the proper acceleration has the same magnitude everywhere. On the other hand, it does have strange properties like CTCs, and that's undesirable.
[EDIT] I think the constancy of the proper acceleration follows from the fact that in addition to the three obvious Killing fields, there is a fourth one involving r. If I've got that right, then the restriction of my calculation above to certain values of r can be relaxed, and the result still holds.
  • #80
I explicitly calculated the Kretschmann scalar and found that it was zero. For the assertion that this implies that [itex]C^{abcd}C_{abcd}[/itex] vanishes, see http://en.wikipedia.org/wiki/Kretschmann_scalar . I didn't say that [itex]C^{abcd}[/itex] vanished, just that that particular scalar constructed from it vanished.
[EDIT] In any case, I think it's more conclusive to look at the Killing vectors than to go through a list of curvature scalars and try to show that they're all constant.
See #4.
  • #81
kev said:
The situation is essentially the Rindler metric with a = constant, substituted for the usual a = 1/x.
Altabeh said:
I don't see this. Please explain it a little bit!
I am saying if you take the the equations for the relativistic rocket with constant proper acceleration and make the acceleration equal to 1/r where r is the displacement along the x-axis from the origin of the initial inertial refenence frame at t=0 then you have the Rindler metric, which has the desirable property that the accelerating observers consider their mutual spatial separation to be constant. If you make the proper acceleration a constant (independent of location) for a series of rockets then you get the get the accelerating grid with a form of uniform acceleration that I described earlier, but you lose the property of constant spatial separation of the observers.
It seems you and Ben have a wish list for a uniform gravitational field that is too long and impossible to meet in any realistic situation and I think my accelerating grid is as close as you are going to get. It might be helpful to define that wish list :wink:
I am not sure that the equation I gave:
precisely describes the accelerating grid.
I think we have yet to pin down why the other metric:
[tex]ds^2=e^{2gy}dt^2-dy^2 [/tex]
differs from the first.
I have also found other metrics that claim to describe the Rindler metric such as:
[tex]ds^2 = (1+2ax)dt^2 - \frac{dx^2}{(1+2ax)} - dy^2 - dz^2[/tex]
from http://nedwww.ipac.caltech.edu/level5/Sept02/Padmanabhan/Pad10_1.html which seems to agree with this paper http://arxiv.org/PS_cache/physics/pdf/0601/0601179v1.pdf that derives an equation for a uniform field by taking a first order approximation of the Schwarzcshild metric in the weak limit and locally.
Wikipedia http://en.wikipedia.org/wiki/Rindler_coordinates gives the Rindler metric as:
[tex] ds^2 = -x^2 dt^2 + dx^2 + dy^2 + dz^2 [/tex]
which describes the Minkowski line element converted to the Rindler chart. I think this particular metric describes a free falling particle from the point of view of the accelerating Rindler observers and that is why there is no acceleration term in that metric.
Anyway, I think we should try and clear up the differences by determining exactly who measures what and if the various authors have different physical models in mind, or if it is just due to different points of view from observers in different states of motion?
  • #82
How about
http://arxiv.org/abs/0904.4877
Lorentzian spacetimes with constant curvature invariants in four dimensions
Alan Coley, Sigbjorn Hervik, Nicos Pelavas
  • #83
This metric:
[tex]d\tau^2 = (1+ax)^2 dt^2 - dx^2 - dy^2 -dz^2 [/tex]
has been bothering me for while so I decided to have closer look at it.
From the equations for the relativistic rocket, it easy to work out the instantaneous velocity of rocket with constant proper acceleration (a) that has traveled a time [itex]\Delta t[/itex] measured in the initial inertial reference frame (iirf) that the rocket was originally at rest in, from:
[tex] v= \frac{a\Delta t}{\sqrt{1+(a\Delta t/c)^2}} [/tex]
From this we can work out the instantaneous time dilation factor from:
[tex] \gamma = \frac{dt}{d\tau} = \frac{1}{\sqrt{1-v^2/c^2}} = \sqrt{1+(a\Delta t/c)^2} [/tex]
Note that we do not need [itex]\Delta (x,y,z)[/itex] because this is already implicit in a*t. In other words if we know the acceleration and the time it has been accelerating for, then all the information to calculate how far the rocket has traveled is already there.
So
[tex] d\tau = \frac {dt}{\sqrt{(1+(a\Delta t/c)^2)}} [/tex]
Now the relativistic rocket equations give the relationship of distance traveled [itex]\Delta x[/itex] and elapsed time [itex]\Delta t[/itex] as:
[tex] \Delta t = \sqrt{( (\Delta x/c)^2 + 2\Delta x /a)} [/tex]
and substituting this value into the equation above it gives:
[tex] d\tau = \frac {dt}{\sqrt{(1+(a\Delta x/c^2)^2 + 2 a \Delta x / c^2)}} = \frac{dt}{(1 + a\Delta x/c^2)} [/tex]
This differs the normal presentation in a number of ways. The time dilation factor is inverted and it should be clear that this is correct because the proper time of the accelerating rocket is always less than the time of the inertial clock. Secondly there is no separate dx factor because this is already present in the [itex]\Delta x[/itex] term. Up to now I have been assuming (and I think others have too) that the x in (1+ax) term of the usual metric is a location, rather than a distance traveled and the inclusion of [itex]\Delta x[/itex] rather than just x makes it clear that the metric is independent of location.
This new metric can be expanded to 4 dimensions as:
[tex] d\tau = \frac{dt}{(1 + a\sqrt{(\Delta x+\Delta y + \Delta z)}/c^2)} [/tex]
This last equation treats the proper acceleration as a scalar and does not really care which direction it is directed in. (The [itex](\Delta x+\Delta y + \Delta z)[/itex] term takes care of the direction.)
I hope I got that all right. Maybe someone can check it.
[EDIT] Just noticed that the above equations aare only valid when the intervals [itex]\Delta x[/itex] or [itex]\Delta t[/itex] are taken from t=0 in the iirf. It will need a bit more work to genralise the equations to any t.
  • #84
The equations
[tex]\begin{array}{rclc}
d\tau^2 & = & (1+ax)^2 dt^2 - dx^2 -dy^2 -dz^2 & (1)\\
ds^2 & = & a^2x^2 dt^2 - dx^2 -dy^2 -dz^2 & (2)\\
ds^2 & = & -x^2 dt^2 + dx^2 + dy^2 + dz^2 & (3)
\end{array}
[/tex]​
are all variations on what is usually described as the "Rindler metric" (or, to be pedantic, should really be the "Minkowski metric expressed in Rindler coordinates").
They describe lattice points undergoing Born-rigid acceleration -- every pair of lattice points is a constant distance apart as measured by a comoving inertial observers at either point, and two events have the same t coordinate if they are simultaneous according to comoving inertial observers at either lattice point.
In (1), the nominal observer is at x=0 undergoing proper acceleration a.
In (2), the nominal observer is at x=1/a undergoing proper acceleration a.
In (3), the nominal observer is at x=1 undergoing proper acceleration 1.
(In all three cases, c=1, of course.) x is distance measured by comoving inertial observers, and t coincides with the proper time of the nominal observer.
The equation
[tex]
[/tex]​
is not usually described as "Rindler coordinates" (in my limited experience), but also satisfies all the conditions above except that x no longer measures proper distance, but is a distorted distance. This particular metric resembles the Schwarzschild metric in many ways, and is an appropriate one to study if you are are applying the equivalence principle to Schwarzschild coordinates.
None of the above describe a "Bell's spaceship" lattice. In such a lattice, the lattice points are moving apart ("the string breaks"), so you would expect the coefficient of dx2 to be time-dependent. I did spend half an hour with the back of an envelope trying to think what the metric would look like, but I gave up. Part of the problem is that there's no obvious definition of coordinate-simultaneity in this case. As two lattice point observers are moving apart, their comoving inertial observers disagree with each other over what is Einstein-simultaneous.
  • #85
atyy said:
How about
That's very helpful -- thanks, atyy!
One nice thing about this paper is that it clearly characterizes the idea about curvature invariants that I was bumbling around trying to characterize earlier. They define a spacetime as CSI (constant scalar invariant?) if everything you can compute from the Riemann tensor by contraction and covariant differentiation is constant.
There is also a notion called "locally homogeneous," which they never seem to define explicitly. It is closely related to being CSI, but is not equivalent in all cases.
They prove that if a 3+1 spacetime is CSI, then it's either locally homogeneous or a certain type of Kundt spacetime.
They also define VSI, which means CSI with all the scalar invariants equaling zero. I don't know if the Petrov spacetime is VSI. It does have a vanishing Ricci scalar (because it's a vacuum solution) and a vanishing Kretschmann invariant.
They define a metric as I-degenerate if there are smooth transformations of the metric that leave the CIs the same while changing the spacetime intrinsically. If the Petrov metric is VSI, then maybe it's I-degenerate, because the strength of the gravitational field is a tunable parameter. (But I don't know if changing g actually makes the new spacetime inequivalent to the old one under a diffeomorphism, so maybe this isn't the case.)
This paper http://arxiv.org/abs/0901.0791 by the same authors has a flow-chart for determining I-degeneracy from curvature invariants (p. 20). On p. 27 they discuss Petrov type I (which is the type of the Petrov metric); they make some general statements, but say that there are exceptions for symmetric spacetimes, and these exceptions would presumably apply to the highly symmetric Petrov metric.
IMO there should be two main criteria:
(1) It should admit a set of global coordinates such that particles released anywhere with a coordinate velocity of zero have an initial coordinate acceleration that's equal in magnitude to some constant.
(2) In addition, it should satisfy some frame-independent criterion, like being CSI, having four simply transitive killing vectors, or being "locally homogeneous," whatever that means.
The Petrov metric satisfies 1, and satisfies 2 in the sense of Killing vectors, but has strange properties like CTCs. The Rindler coordinates don't satisfy 1.
At this point, I would be interested in figuring out whether the Petrov metric is VSI, and whether it's I-degenerate.
  • #86
This is in your wish list, because we can't make such a desire happen to exist in Rindler or Semay metric. Putting [tex]a=1/r[/tex] makes the acceleration position-dependent and the worst thing is that looking at the geodesic equations that describe the motion of lattice points along geodesics shows us that with your assumtion proper acceleration is still position-dependent unless we take [tex]r=x-x_0=x[/tex] to be a constant (or consider DrGreg's representation of how the proper acceleration undergoes a constant proper acceleration a by putting x=0), which means the points on your lattice does remain motionless in the direction of x-axis while the acceleration is itself supposed to be along x-axis.
How can one make the proper acceleration a constant without assuming again no motion in the direction of x-axis? If you could have a position-independent proper acceleration, I would welcome the idea of "uniform acceleration" in your lattice-based version of the aforementioned metrics.
I myself only think of a uniform gravitational field in any spacetime locally! The reason is that until the proper acceleration depends on the position (or time), I can't agree to having a uniform gravitational field in a flat spacetime. (I think no such thing as gravity exist in a flat spacetime, either!) If we take the spacetime to be Minkowski, then all proper accelerations (in the direction of spatial coordinates) are equally zero; so we can say the gravitational field in this metric is uniform. But where is the gravity in such strictly flat spacetime!? The moral that I sign my wish list with it is: Equivalent principle leads to having a weakened form of a uniform field and vice versa.
Your lattice in my eyes seems to be working well locally as the above says. Though I think when it comes to local discussion of the whole stuff, your lattice gets as less valuable than all efforts done to this date in this zone as it can!
The two have a big difference: One is flat the other isn't!
AB
  • #87
Altabeh said:
This is in your wish list, because we can't make such a desire happen to exist in Rindler or Semay metric. Putting [tex]a=1/r[/tex] makes the acceleration position-dependent and the worst thing is that looking at the geodesic equations that describe the motion of lattice points along geodesics shows us that with your assumption proper acceleration is still position-dependent
Indeed. I never claimed otherwise. The classic Rindler metric (with Born rigid acceleration) does not have uniform proper acceleration (as measured by local accelerometers on the rockets). That is why the classic Rindler metric has to be modified somehow to achieve a form of uniform acceleration.
Why do we need to assume no motion along the x axis?
I am not sure what you are getting at here. I am sure we both agree that we can not have a gravitational field in flat spacetime, because any real gravitational field curves spacetime. I am sure you would also agree that we can create a simulation of a gravitational field by having a system of accelerating rockets, such that an observer confined to making local measurements inside a rocket artificially accelerating in flat spacetime would not be able to determine if he was in a gravitational field or not. That is the essence of the EP principle.
This link would agree with you: http://www.dlugosz.com/files/PhysFAQ-edit/Relativity/SR/spaceship_puzzle.html
It illustrates the [itex]d\tau^2 = e^{2z}dt^2 - dx^2 - dy^2 - dz^2
[/itex] metric with this drawing:
and states that this metric represents a "uniform gravitational field" and can not be transformed to flat spacetime by a coordinate transformation. Presumably the diagram is the POV of a free falling observer. I am not sure why the wordlines cross over each other or how this would be consistent with their claim that in this spacetime the accelerating observers measure their mutual spatial separation to be constant. Hmmm.
The accelerating grid I had in mind would have worldlines more like this (parallel hyperbola):
This is the point of view of a free falling observer.
DrGreg said:
The equations
\end{array}
[/tex]​
I did not see what you were getting at when I made this post last night, but I see now that given the special locations of the nominal observers the time dilation ratio dtau/dt does resolve to unity for dx=dy=dz=0 and I have now edited this post. Thanks for taking the time to clarify DrGreg. Cheers.
  • #88
It is because the geodesic equations tell us that the proper acceleration along the x-axis is dependent on the coordinate x, so to assume a uniform acceleration we only have a choice ahead: take [tex]x=x_0[/tex] and consider the motion happens on the planes parallel to yz-plane! One would then be able to dig from this assumption along with the two other geodesic equations that say both proper accelerations along y and z axes are zero, that the proper acceleration is uniform which in turn again resurrects the local discussion!
Exactly! But, as you can see, the trouble is we can very barely find those coordinates that meet the demands mentioned in our wish list.
EP is equivalence principle so no need to be accompanied by a further principle! :biggrin:
I don't think their claim is true unless discussing the whole stuff just locally by having EP hold in a curved spacetime!
AB
  • #89
It occurs to me that we could construct a system of concentric rotating rings, such that each ring has equal centripetal acceleration. This means the angular velocity (or instantaneous tangential velocity) of each ring would be different, with the smaller inner rings rotating with greater angular velocity w=sqrt(g/r) but lesser tangential velocity v=sqrt(gr) with g=constant (assuming the Newtonian relationship for angular acceleration still holds here.. not sure). This would give a form of constant acceleration which would be equal for any given r. Might be interesting to analyse and might be something like the gravitational field of the infinitely long, rotating cylinder of dust that Ben is fond of. :wink:
An interesting property of this structure is that it has constant vertical spatial separtion, even from the point of view of the accelerating observers, but the horizontal distances are a bit messy. Judging by the very complicated metrics for the cylinder of dust, I imagine the mutual horizontal distances are a bit messy there too.
I am coming around to your point of view that it impossible to have a gravitational field that is uniform everywhere and has constant spatial distances from the POV of the accelerated observers, except as a very local aproximation.
I know!.. I know!.. kicks self
  • #90
kev said:
It occurs to me that we could construct a system of concentric rotating rings, such that each ring has equal centripetal acceleration. This means the angular velocity of instantaneous tangential velocity of each ring would be different, with the smaller inner rings rotating faster so v=sqrt(gr) or w=sqrt(g/r) with g=constant (assuming the Newtonian relationship for angular acceleration still holds here.. not sure). This would give a form of constant acceleration which would be equal for any given r. Might be interesting to analyse and might be something like the gravitational field of the infinitely long, rotating cylinder of dust that Ben is fond of. :wink:
This seems to be a good thing and Ben is currently working on it through Petrov metric (I guess)! I'm really busy and can really barely find a little free time to spend on this! But if I could catch the mainstream of the paper given at post #4 regarding the Petrov metric (PM) which is claimed to be the only rotating vacuum solution to Einstein field equations, then I would throw around my own conclusion of the gravitational uniform field and how it can be made globally existent! I would be interested in grappling with the geodesic equations of the PM and checking if they can offer us a coordinates by which the uniform acceleration is guaranteed everywhere! I do not have any hope for this!
Ben is missing now for 1 day and I think he'll have a good "start" with the new idea!
AB
  • #91
The coordinates in which the metric is normally written are coordinates in which the proper acceleration of a particle released at rest is the same everywhere. See #79. Of course if you want that acceleration to *remain* constant forever (i.e., to be constant regardless of the particle's current velocity) then that's impossible.
No, they don't claim that. There are many rotating vacuum solutions to the EFE. What is unique about the Petrov metric is its symmetry. It is "The only vacuum solution of Einstein’s equations admitting a simply-transitive four-dimensional maximal group of motions..."
  • #92
[tex]
\ddot{t}=0
[/tex]
[tex]
\ddot{\phi}=0
[/tex]
[tex]
[/tex]
If your calculations are all correct, then the assumption
[tex]\dot{t}=e^{-r/2}[/tex]
is only in accordance with the first geodesic equation if one of the two conditions below holds:
1) [tex]r[/tex] is taken to be a constant, so the motion is much restricted,
2) the proper velocity of particles along [tex]r[/tex] is zero which is the case when an instantaneous comoving observer measures stuff regarding the motion of particles.
Of course the first condition would not be regarded as a tool of providing a constant proper acceleration globally. So talking about the other condition, and yet highly unphysical one, I don't see any better situation than when we were dealing with the Rindler metric because this is again dependent on position which is cured by setting the initial time of the observer's clock at the beginnig of the motion. And about the motion, there is no such thing along [tex]r[/tex] though for an instantaneously at rest comoving observer along [tex]r[/tex] at a constant [tex]z[/tex] but with a varying [tex]\phi[/tex], one can have the proper acceleration [tex]\ddot{r}[/tex] observed instantaneously and uniformly! But remember that this approach, I think, is so insubstantial in the context of global constancy of proper acceleration: we are actually binding time up into space through [tex]\dot{t}=e^{-r/2}[/tex] in a way to have a uniform acceleration observed by some observer being instantaneously at rest while this is not essentially happening in the spacetime. I mean if you have [tex]z[/tex] also involved as a freely varying coordinate, the situation gets much complicated and requires much more things that we need to mean in essence by 'global discussion' of the whole scenario than now!
Keeping in mind the global discussion, how one would show me all four elements can be adjusted somehow so as to make thee proper acceleration uniform in Petrov metric?
AB
  • #93
As stated explicitly in the text that you quoted, the result only holds for a particle that is instantaneously at rest. Please see my #37, in which I pointed out to you that I had already explicitly stated this twice, in #19 and #26.
No adjustment is necessary. This was the result of the calculation in #79.
Folks, this has been a very enjoyable thread, but I think I'm going to stop following it now. Thanks, everyone, for sharing your valuable and insightful comments!
  • #94
Let me give you a vivid picture of the globally uniform gravitational field and how it can be realized:
1- The metric must be Ricci-flat or a vacuum solution to the Einstein field equations;
2- In Cartesian coordiantes (t,x,y,z), the geodesic equations have the form
[tex]\ddot{t}, \ddot{x}, \ddot{y}[/tex] and [tex] \ddot{z}[/tex] must all be constant.
Or the Christoffel symbols be all constant.
It is not impossible to look for such a metric and I have some plan to do find one! I'll give it a go someday I find a little free time!
AB
  • #95
My bad, I didn't see 'em!
If not take instantaneously at rest as an "adjustment"!
Why? Anyways it's been too enjoyable for me, too and hope you are not leaving us forever!
AB
  • #96
I'm signing off too with thanks to all posters. I have learned some things I should have known. I conjecture that -
1. The Rindler coords have nothing to do with gravity.
2. They are not global but apply locally to an accelerating observer in Minkowski space-time
3. The parameter 'a' is related to the observer's proper acceleration.
4. So far no-one has come up with a uniform gravitational field, either in vacuum or matter.
