How much lava is there in earth?
  • Thread starter DrDu
  • Tags
    Earth
In summary, according to this source, the percentage of Earth's crust that is made up of hardened lava is over 66%.
DrDu
974
I was reading about the Earth's structure and learned that the mantle is solid, although it can deform plastically. In fact this follows from possibility of transversal seismic waves to propagate.
This leaves me with the question where the magma that we observe in volcanos is formed and how much there is present at the crust-mantle boundary.
I'm sure you've checked out wiki?
http://en.wikipedia.org/wiki/Magma
Here are two loosely related but interesting articles
THE DEEPEST HOLE
http://www.damninteresting.com/the-deepest-hole/
Drillers Accidentally Create First Live Magma Observatory
http://www.wired.com/wiredscience/2008/12/magmaobservator/
Thank you Greg!
This only leaves open my question on the quantity of magma present at the crust-mantle boundary.
That's not lava but magma. I'm not aware of trustworthy estimates about total quatities. There are numbers mentioned here but not tied a reference.
Yes, you are right, I should have written magma in the tiltle, not lava.
I have been reading the "subduction" article before but found it quite dubious, e.g.
"The supercritical water, which is hot and more buoyant than the surrounding rock, rises into the overlying mantle where it lowers the pressure in (and thus the melting temperature of) the mantle rock to the point of actual melting, generating magma."
I can't see how rising water can lower the pressure.
The water pushes the grains in the rock apart, counter to the loading stress due to the overburden. The net is a drop in the effective stress.
c.f http://en.wikipedia.org/wiki/Effective_stress
I did some reading. Apparently water reduces the melting temperatures by depolymerizing silicates in the melt thereby increasing the entropy of the melt:
www.people.fas.harvard.edu/~langmuir/Papers/Katz G3 03.pdf
Makes much more sense.
I found some numbers on how much magma is generated by locations (subduction zones, hot spots etc)
in H Bahlburg, C Breitkreuz, Grundlagen der Geologie, Spektrum Verlag, 2012.
. The sum is of the order of 1 km^3 per year. I don't have the precise numbers at hand right now.
That sounds small to me. It appears you are missing mid ocean ridges, which add about 20 km^3 per year.
You are right. The numbers from the book are
location intrusive extrusive
subduction zone 8 0.8
mid oceanic ridges 18 3
intra plate volcanoes
oceanic 2 0.4
continental 1.5 0.1
Lava being the unsolidified molten rock material deposited on the surface of Earth? A fraction of a fraction of a fraction of a percent. As defined as a solidified rock, the percentage of Earth's crust is over 66% hardened lava, in the form of basalt.
You seem to have taken the view that the oceans are absalt, the continents (granite) are not, and so the ratio is as you have defined it. However you have failed to take into account the much greater thickness of the continental crust.
Please link to the source so we can verify, thank you.
Also, this is a reminder to everyone posting "facts", you need to post a link to your source when you post facts about something that is not general knowledge, it's the only way we can determine which information is most accurate.
Related to How much lava is there in earth?
1. How much lava is currently on the surface of Earth?
It is estimated that there are about 100,000 km3 of lava currently on the surface of Earth. This includes lava flows on land and in the ocean.
2. How much lava is beneath the Earth's surface?
It is difficult to estimate the exact amount of lava beneath Earth's surface, but it is believed to be significantly more than what is on the surface. This includes lava in magma chambers, lava tubes, and other underground structures.
3. How much lava has erupted throughout Earth's history?
It is estimated that over 5 million km3 of lava has been erupted throughout Earth's history. This includes both on land and underwater eruptions.
4. Where is the most lava located on Earth?
The majority of Earth's lava is located in the Pacific Ring of Fire, which includes areas such as Hawaii, Iceland, and Japan. This is due to the presence of numerous active volcanoes in this region.
5. How does the amount of lava on Earth compare to other planets?
Earth has a relatively small amount of lava compared to other planets and celestial bodies. For example, Jupiter's moon, Io, has over 100 times more lava than Earth. This is due to its active volcanism caused by gravitational forces from Jupiter.
  • Earth Sciences
  • Earth Sciences
9K
17K
9K
