quanticism
- 29
- 3
From qualitative arguments, make a sketch of the form of a typical unbound standing wave eigenfunction for a finite square well potential.
An unbound particle is one which has total energy E greater than the Potential V of the well
Is the amplitude of the oscillation the same in all regions?
Using the Time Independent Schrodinger Equation we see that:
Inside well: Solution is of form [tex]Asin(k_0x)[/tex] where [tex]k_0 = \sqrt{2mE/\hbar^2}[/tex]
Outside well: Solution is of from [tex]Bsin(k_1x + \phi)[/tex] where [tex]k_1 = \sqrt{2m(E-V)/\hbar^2}[/tex] where [tex]\phi[/tex] is the phase shift which can be adjusted to satisfy the boundary conditions.
So inside the well, the wave number of the eigenfunction should be greater than the eigenfunction outside the well. This should mean that the eigenfunction's frequency inside the well is higher.
I've looked around and I found this http://vnatsci.ltu.edu/s_schneider/physlets/main/finite_sqr_well.shtml" . You can look at the unbound states by clicking and dragging your mouse on the black bar on the right with the green lines.
It suggests that the amplitude of the eigenfunction should decrease when inside the quantum well.
I thought the amplitude of the eigenfunction should give you an indication of the probability of finding the particle in that particular region. If so, shouldn't the amplitude be slightly higher inside the well?
