Optics Question - How is light divided into a 2d image?
In summary: The light that is hitting the CCD will be represented on the CCD as a series of black and white pixels. Now imagine turning the CCD camera so that the light is hitting the lens in the same place as it is hitting the CCD. You will see a perfect copy of what is on the wall in front of the CCD camera. The lens in your eye is also a CCD, and when you look through the lens you see the inverted image of what is on the outside of your eye. The image that you see in your eye is not inverted, it is inverted because the lens in your eye is not pointing directly at the sun. The image that you see in your eye is inverted because
phys_person
The theory seems simple. Light strikes the film in a camera, or a CCD and the different regions of intensity are recorded. But what I can't get my head over, is how a different portion of the film strip or CCD *knows* which part of the image it is supposed to be representing.
For example, if I was to make a series of pinholes in a sheet of paper, I could view out of each one of them a complete image that is nearly identical to the the image from the hole beside it. If I was to try and record some details about the image, such as light intensity, general colour, it would have identical results as the hole beside it. How can a series of readings from a film or CCD be constructed to make a complete image? How can one small piece say it's looking at blue, and another small piece say it's looking at red? I just don't get how the image is divided up like that. When the total light information striking a small point on a 2d plane, should be almost completely identical to another small point beside it.
Science news on Phys.org
I think you are confused here, in fact I'm not following your point, but light doesn't just strike film or a CCD in a camera, if that's all that happened then every pixel would show the same brightness and color. The light goes through a lens that forms an image on the surface of the film or CCD, and that image shows different levels of brightness depending on where each pixel is located with respect to the image. It also shows different colors depending on where the pixel is located, if the object that is being imaged by the lens emits or reflects different colors by different amounts. The key here is the lens, without that you don't have a camera.
Echoing Jeff, I think you (the OP) is neglecting the function your eye in your thought experiment.
It seems as though you are saying the lens breaks up an image into different portions of light across a 2d plane. If so, how can I see pretty much see the same total image out of different portions of the lens in someone's eye glasses? What about light passing through a window? What about a window with a slight bend that is not even noticeable to the eye? Just what kind of changes does the light have to undergo to become a 2d map of an image?
As opposed to just "regular" light that would seem the same from different spots.
Thank you
phys_person: The best way to understand what is happening is to do a VERY simple experiment. Do you have a magnifying glass? You can buy a cheap one one (about $1) at your local drug store since the elderly use them for reading. Stand opposite a window in your house, during the daytime so you have plenty of light, and place the magnifying glass a few inches from the wall. You will see an inverted image on your wall of what you see outside. Now imagine a CCD camera placed at the location of the wall.
1. What is the process of creating a 2d image from light?
The process of creating a 2d image from light is known as imaging. It involves the use of lenses, mirrors, and other optical elements to manipulate and focus light onto a sensor or film to create a visual representation of the scene being captured.
2. How does light get divided into a 2d image?
Light is divided into a 2d image through the use of an optical system, such as a camera or microscope. The system focuses and directs light rays onto a sensor or film, which then records the light intensity and color information to create the final image.
3. What role do lenses play in dividing light into a 2d image?
Lenses are a crucial component in dividing light into a 2d image. They are responsible for bending and focusing the incoming light rays onto a sensor or film, which determines the sharpness and clarity of the final image. Different types of lenses, such as convex and concave, are used to manipulate the light in various ways to create the desired image.
4. How does the quality of lenses affect the final 2d image?
The quality of lenses can greatly impact the final 2d image. A high-quality lens, with minimal aberrations and distortions, will result in a sharper and more accurate image. On the other hand, a lower quality lens may produce a more blurry or distorted image.
5. Are there other factors besides lenses that influence the creation of a 2d image from light?
Yes, there are other factors that can influence the creation of a 2d image from light, such as the light source, the sensor or film used, and the environment in which the imaging takes place. Each of these elements plays a crucial role in determining the quality and accuracy of the final image.
