Body moving with constant accelration over two equal segmants given time find accerla
In summary, the body travels over two equal 10m segments of its path at a constant acceleration of -9.8m/s2.
teddyayalew
36
" A body moving with constant acceleration travels consecutively over two equal 10m segments of its path S. Find the acceleration "a" of the body and its speed v(not) at the start of the first segment, if the first segment is traversed in t(1) = 1.06 seconds and the second in t(2) = 2.2 seconds "
equations I have defined :
http://i41.tinypic.com/o5zwwn.jpg
I also know the acceleration is going to be negative since it takes longer for the body to cross the second segment of equal distance. The body is slowing down
http://i40.tinypic.com/wmmdyx.jpg
I am having trouble eliminating the v(0).
Given the approach you've started with, I think the simplest thing to do would be to use your first equation (the one for S1) and use it to solve for v0 in terms of known quantities:[tex]v_0 = \frac{S_1}{t_1} - \frac{at_1}{2}[/tex]If you take this expression for v0 and plug it into the second equation for S2, then you'll have an equation that contains only a, and other known quantities. You can then solve for a.
Thank you cepheid I was able to solve the problem.
1. What is constant acceleration?
Constant acceleration is when an object's velocity changes by the same amount over equal time intervals.
2. How is acceleration calculated?
Acceleration can be calculated by dividing the change in velocity by the time interval over which the change occurs. The units for acceleration are meters per second squared (m/s^2).
3. What is the equation for calculating acceleration?
The equation for calculating acceleration is a = (vf - vi) / t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time.
4. How does constant acceleration affect an object's motion?
Constant acceleration causes an object to change its velocity at a constant rate, meaning its speed and direction of motion are changing at a constant rate.
5. How can acceleration be graphically represented?
Acceleration can be represented on a graph as the slope of the velocity-time graph. The steeper the slope, the greater the acceleration.
