Coin toss probability when not 50/50
  • Thread starter Mikes1098
  • Tags
    Probability
In summary, the probability of getting heads or tails in a coin toss is always 0.5, regardless of the past outcomes. However, if you are trying to determine if a coin is fair or not, you can use Bayesian probability to calculate the probability that the coin is fair based on the past outcomes. This probability will change with each new flip, but it does not affect the actual outcome of the next flip.
Mikes1098
I hopefully have a rather simple question... I am looking for the equation to calculate the probability when the total counts of heads and tails get off balance. To further explain, when I flip the coin once there is 50/50 chance getting one or the other... If I flip the coin 10,000 times that probability will get closer and closer to .5. However, on the way to 10,000 flips... Maybe after 100 flips, I might have 30 heads and 70 tails... Therefore my next flip should have have more of a chance of hitting heads (greater than .5 anyway)... How do I calculate that "improved" probability after the measuring x amount of data?
Thanks
If you are making independent tosses of fair coin that is not a correct deduction. There must be hundreds of threads on the forum about the fallacy of thinking this way.
If you are flipping the coin in some way that you can change the probability of getting a head and make it more or less than 0.5 then you could look at how many total heads you have and try to "balance things out" by changing the probability of tossing a head. But if you assume you are always tossing a fair coin then you are tossing a fair coin, regardless of the past history of heads and tails.
No. Coin tosses are independent; previous tosses have effect on future tosses.
As the previous posters have mentioned, if the coin is fair the probability of heads is 0.5 no matter what the previous sequence of heads and tails is.
At the risk of going beyond what you have learned so far, Mikes1098, you could ask a different question that does depend on the past sequence of heads and tails: is this a fair coin or not?
Using the Bayesian view of probability, you could calculate ##P(p_{heads} = 0.5 | A_n)## - the probability that the probability of the coin coming up heads is 0.5, given a that you have observed a sequence, ##A_n##, of n previous coin toss outcomes. This probability will change after each new flip, as each new flip gives you another data point that helps you decide whether or not the coin is fair. You would need some model for how each new data point changes your estimate of ##P(p_{heads} = 0.5 | A_n) \rightarrow P(p_{heads} = 0.5 | A_{n+1})##. However, it is very important to note that this still has no bearing whatsoever on what the outcome of the next coin toss is! It is only an estimate of the probability that the coin is fair! If this estimate is telling you that the probability that ##p_{heads} = 0.5## is small, however, then you may wish to start betting more on tails (however, ##P(p_{heads} = 0.5 | A_n)## doesn't tell you what the actual heads:tails ratio is).
ok, maybe the 100 flip example was a bit exaggerated... assuming it is a fair coin, after 10 flips it would not be shocking not to have perfect 5 heads and 5 tails. Eventually, which ever is behind will catch up after enough flips to equal the predicted .5... therefore doesn't the probability have to favor the one, that by chance, is lower? It seems there should be a way to take measured random data and alter the future probability have the remainder of the set.
Thanks Mute, that was exactly what I was looking for. I guess my definition of "fair coin" might have been off.
Just to be super super clear: the definition of a fair coin is one for which the probability of a "heads" outcome = probability of a "tails" outcome = 0.5 (for heads and tails being the only two outcomes). The situation I am describing is one in which you are observing a sequence of coins flips and trying to determine if you can reject the Null Hypothesis, which in the situation I posed would be "This is a fair coin" or more accurately, something like "This coin is not biased towards heads".
FAQ: Coin toss probability when not 50/50
1. What factors can affect the probability of a coin toss not being 50/50?
There are several factors that can affect the probability of a coin toss being something other than 50/50. These include the weight distribution of the coin, the initial force used to flip the coin, and the surface on which the coin lands. Additionally, external factors such as air resistance and wind can also impact the outcome of a coin toss.
2. Can the probability of a coin toss not being 50/50 be calculated?
Yes, the probability of a coin toss not being 50/50 can be calculated by taking into account the factors mentioned above. However, it is important to note that these variables can be difficult to measure accurately, making it challenging to determine an exact probability.
3. Is it possible for a coin toss to have a probability of being neither heads nor tails?
No, a coin toss will either result in heads or tails, even if the probability of one outcome is significantly higher than the other. The two possible outcomes are mutually exclusive, meaning only one can occur at a time.
4. How can the probability of a coin toss not being 50/50 be influenced?
The probability of a coin toss not being 50/50 can be influenced by altering the factors mentioned above. For example, using a coin with an uneven weight distribution or applying a stronger force when flipping the coin can increase the chances of one outcome over the other.
5. Are there any real-life situations where the probability of a coin toss is not 50/50?
Yes, there are real-life situations where the probability of a coin toss is not 50/50. For instance, if a coin is damaged or has been tampered with, it may have a higher probability of landing on one side over the other. In sports, the outcome of a coin toss can also be influenced by external factors such as wind, resulting in a non-50/50 probability.
15K
