Two trains moving in opposite directions around the earth
In summary, two trains are sitting on the equator, one moving east with the rotation of the earth and the other moving west against it. They both accelerate to a speed close to the speed of light using the same amount of energy. An observer on Earth will not notice a difference in speed between the two trains, but an observer not on Earth will observe one train moving faster than the other. However, they will both observe the trains crossing at the same point on the equator, though the location of that point will be different depending on the observer's frame of reference.
MnagurnyIII
You have two trains sitting on the equator (one on each side of the equator so they don't collide -.-). Train one is moving East with the rotation of the earth, train two in moving west against it. both trains accelerate to a speed close to the speed of light, using the same amount of energy. So train one is moving near the speed of light plus the energy of the spin of the earth, train two is moving near the speed of light minus the energy of the spin of the earth.
my question is would an outside observer on Earth be able to measure a difference in the total speed of the two trains, and would an observer who is not on Earth be able to measure a difference?
My understand of this would state that an observe on Earth would not be able to notice a difference and the two trains would cross at the same points, one for each side of the earth. But somebody who was not on Earth would observe train one as moving faster than train two and would observe them as crossing at different points which has me... thinking I need to understand this concept better.
Using the same amount of energy from what starting point? Energy is frame-dependent.
But if they both used the same amount of energy to accelerate, they should have the same amount of energy when the acceleration is done, as long as you measure the energies relative to the same frame. If they have different energies, it must be because you have switched frames of reference between this statement and the previously quoted one.
Also, the difference in energy, in a frame where the energies are different, is not "the energy of the spin of the Earth"--that energy is huge, much, much larger than the energy of a train even if it is moving close to the speed of light. What I think you mean here is the kinetic energy that a train at rest relative to the rotating Earth would have, as measured by an observer who was not rotating with the Earth.
It depends on the answer to the question I asked above. If the answer is that both trains start from rest relative to the (rotating) Earth, and both use the same amount of energy to accelerate relative to the (rotating) Earth, then when the acceleration is done, they will both be moving at the same speed (but in different directions) relative to the (rotating) Earth, so an observer at rest relative to the (rotating) Earth will not measure any difference in their speed, but an observer who is not rotating with the Earth *will* measure a difference in speed (and will measure a difference in energy between the trains as well).
OK you hit what I was asking. The very last part is what I am having issues with. To a person on the earth, the trains are moving at the same speed and have the same energy because they are moving with the earth. To an outside observer who is not on Earth - they are moving at different speeds with different energy. Does that mean the outside observer would observe the trains passing each other at different points then a person standing on the Earth would?
edit: nevermind. the answer is no. He would observe them as crossing at the same point. but that point would be at a different location relative to the rest of the universe because the Earth rotated that point to a different spot - but it is still the same spot on the earth.
If you mean different points in space relative to the two observers, yes, they will. But that's because "space" itself is relative; different observers in different states of motion will assign, in general, different spatial coordinates to the same event.
For example, suppose the trains both start out at 0 degrees longitude and move along Earth's equator. They will cross at 180 degrees longitude on the equator, which, to an observer rotating with the Earth, is a fixed point in space. But to an observer not rotating with the Earth, 180 degrees longitude on the equator moves, so it can't possibly be "the same point in space" as it is for the observer on Earth.
I can provide a response to this scenario based on my understanding of physics and the theory of relativity.
Firstly, it is important to note that the concept of "energy of spin" of the Earth is not well-defined in physics. The Earth's rotation does not add any energy to an object moving on its surface. Therefore, the energy of the trains remains the same regardless of their direction of movement relative to the Earth's rotation.
Now, let's consider the scenario from the perspective of an outside observer who is not on Earth. According to the theory of relativity, the speed of light is constant for all observers, regardless of their relative motion. This means that an outside observer would measure the speed of both trains to be close to the speed of light, regardless of their direction of movement.
However, due to the phenomenon of time dilation, the observer would measure the time on the trains to be passing at different rates. This is because the closer an object moves to the speed of light, the slower time passes for that object. Therefore, the observer would measure train one (moving east with the rotation of the Earth) to be moving faster than train two (moving west against the rotation of the Earth) due to the time dilation effect.
In terms of their crossing points, the observer would also measure a difference. This is because the observer would see train one moving faster than train two, and therefore, train one would reach the opposite side of the Earth sooner than train two. This would result in the two trains crossing at different points as observed from the outside perspective.
In conclusion, an outside observer would measure a difference in the total speed of the two trains due to the phenomenon of time dilation. This is a fundamental aspect of the theory of relativity and has been confirmed through various experiments and observations.
1. How is it possible for two trains to move in opposite directions around the earth?
This scenario is purely hypothetical and is not physically possible. It is used as a thought experiment to understand concepts like relative motion and the effects of gravity.
2. How does the distance between the two trains affect their speed?
The distance between the two trains does not affect their speed. The speed of each train remains constant regardless of their distance from each other.
3. Will the trains ever meet or collide?
No, the trains will never meet or collide as they are both moving in opposite directions and on different tracks. The curvature of the earth also prevents them from meeting.
4. How does the rotation of the earth affect the motion of the trains?
The rotation of the earth does not have any significant effect on the motion of the trains. The trains' speeds and directions remain constant relative to the earth's rotation.
5. What would happen if the trains were to change direction and start moving towards each other?
If the trains were to change direction and start moving towards each other, they would eventually collide due to gravity pulling them towards each other. This is because their relative motion would now be towards each other, rather than away from each other as before.
9K
